mega controller logging
This topic is closed.
    Hello All,
    Does anyne know of a way to keep the giberish outputed from homeseer from showing up on stargate megacontroller?
    I'm guessing that you have both WinEVM and HS attached to SG using a serial splitter. What 'giberish' are you referring to? Is it the hex code exchange with the SG plug-in to sync device states when HS starts up? Or is there something else?
      It is hex, but I get it all the time, not just on startup. I need to close homeseer everytime I want to download a stargate schedule because it interferes.
        I take that back. It is not hex just ramdom numbers, mostlt 0,8,9's.
          I have not seen that in my setup, but I do find that shutting down HS when I download a new SG schedule is helpful, so maybe I'm just not seeing them in the log, but they're still there.
          I think the SG plug-in is emulating WinEVM to some degree as a means for communicating with SG. SG was not written to interface to HS, after all. So I didn't find it surprising that the plug-in might interfere with some kinds of communication between WinEVM and SG. I've decided to live with the need to close HS when I'm downloading a schedule as a cost of having them work together. After a flurry of changes as I was getting the combination working together, I'm not changing the SG schedule very often any more, so it's not much of a bother.
