New Stargate flag. How do I get into HS?
This topic is closed.
    All,
    I want to define a new flag in the Stargate and see it in HS. Is there a simple way of just defining the new flag in HS or do I have to go through importing all the devices again?
    Thanks!
    You will need to import at least all your flags again. Be sure to check the box to overwrite so you don't end up with duplicate HS devices. It's a pretty quick process, but a bit of a pain if you are making frequent additions to your SG setup. Fortunately, you will probably find that your SG installation will stabilize before long and importing to HS will become fairly infrequent.
      I thought I read elsewhere in this forum that a reload won't create duplicates?
        Maybe that got fixed. It certainly used to, but that was many versions ago. I've been careful not to forget to check the overwrite box, so I haven't actually tried it in some time. If all goes to plan, I probably never will.
          Another person with whom I collaborate suggested just naming a bunch of extra flags something generic (i.e. Flag_11, Flag_12, etc.) then importing. Then all you have to do is go in and rename the device when you use it in HS, thereby reducing the number of imports.
