I just imported all of my X-10 settings from Stargate. I have a cheap X-10 dimmable switch in the wall in the basement. I can dim it in WinEVM using the % setting 10, 20, 30, etc. But from Homeseer I cannot get the % setting to work - only the ON and OFF commands work?
Can't get dim level to work for X10 switch
This topic is closed.
I'm using devices that support Preset Dim, so have no experience with conventional dim, but have you tried &hs.ExecX10 "A1", "Dim", 50, for example? or maybe &hs.ExecX10 "A1", "DDim", 50?Mike____________________________________________________________ __________________
Originally posted by simonmason View PostNeither of these commands seem to work. It is a simple WS12A X-10 switch. Stargate can dim it just fine but I get either no response to Homeseer dim commands, or erratic things such as the light turning full on no matter what dim level I send it.
Originally posted by simonmason View PostIt is a simple WS12A X-10 switch. Stargate can dim it just fine but I get either no response to Homeseer dim commands, or erratic things such as the light turning full on no matter what dim level I send it.
So you can dim the light using a SG event, eg. X10:A-1 Set Level 50% ?
If you can, you could probably use HS to set a SG flag that triggers the event. It might even be possible to dim to a level in a variable. If that's the case, then you could have a HS event that puts the level in the SG variable, then sets the trigger flag.Mike____________________________________________________________ __________________
