I've recently started working on scripting control of my 12 zone CAM system and I'm having some plugin problems. First, some background: The system consists of 2 CAM6.6 units and 1 SMS3 media server. The CAMs are set to ID1 and ID2, Out from unit 1 to in on unit 2, out from unit 2 to in on sms3.
1st issue: I've turned debug on in the plugin, and it appears to only be polling zones 1 and 2. The logs and config are attached.
2nd: Every once in a while (I'm still researching it), a zone will not respond to the virtual keypad in Homeseer or event actions. This usually happens after I control a zone using a wakeup script I have that fades on a partcular zone over fifteen minutes. The recurring event is deleted and the zone is SUPPOSED to be shut off when you turn on the closets lights. The event is being deleted, but the zones will not shut off. Any ideas?
Sonny D.
Forgot to mention - running version 1.2.3334.26161 of the plugin.
Sonny D.
