Hi Guys-
Wow you post fast! The correct syntax is:
hs.plugin("ZWave Thermostats").GetTemp([Thermostat ID],[Sensor ID])
For the purposes of this plugin, the Thermostat ID is the HomeSeer DeviceCode number assiged to the thermostat device. The sensor ID will always be 1, as there are no ZWave Thermostats that support sensors. It is an optional parameter, so you could leave it out if you want to:
hs.plugin("ZWave Thermostats").GetTemp([Thermostat ID])
This will work just as well. If you are still seeing the Object Reference errors, be sure that you have the latest version from the updater. This was an issue in older builds, but it should be resolved in the latest (1.0.2407.something I think...)
