Hello All,
I have a Trane Z-Wave thermostat which has a run mode of Hold. When set to this mode, the thermostat will keep the current temperature (e.g. it overrides the setback schedule programmed into the thermostat). I would like to be able to change the run mode to Hold using an HomeSeer event. However, Hold is not an option in the drop down list when setting up the event. Is it possible to change the run mode to hold from a script?
Thank you,
Michael
Thank you,
Michael
