ZWave thermostats rearrange every restart
    Hello,
    ZWave thermostats randomly rearranged every time when I restart Homeseer. It is unacceptable because HSTouch keep references on thermostat index. And EVERY restart HSTouch show WRONG information because thermostat index was changed.
    How I can keep thermostat index same after restart?
    Dmitry
    funny I was going to report the SAME just now.
    Yesterday I added 3 more Z-Wave thermostats in HS and now all my HST screens are out of whack!
    For example the basement thermostat control/status shows up in master bedroom and so on.
    It is not acceptable as I will end up with about 15 thermostats and I need
    to depend on HST screens to control them.
    Time to submit a ticket?
      What version of HS are you guys running?
        Latest versions for everthing!
        It is pretty easy to notice when you have many thermostats...
        I DON'T think HS will change the order or the Z-stats upon restarts (I have tried that a few times) if NOTHING changes...
        I have determined that HS indexes the Z-stats in ALPHABETICAL order!
        Hence my problem: if you add thermostats OR change a device name
        the indexing will change and HStouch will definitely get confused.
        Would be better to index them based on housecodes!
          I thought this was fixed in the lastest release of HS. If not put in a bug report.
            I had this problem too. I put in a help ticket and Rich sent me a new beta to try. Thus far, it hasn't been a problem.
              I am experiencing the same problem.
              I don't see a reference to the beta as available to try out.
                Are you running HS2 or HomeSeer Pro?
                  Yes, there is a 2.5.0.8 beta that rich sent me. Have not tried yet for fear of betas. Let us know how it goes....
                  Transitioning to HS3Pro .298 - WinXPEmbedded
                  Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
                    Re:
                    I'm running HSPro
                      Is 2.5.0.8 going to be available?
                      Re:
                      I'm running HSPro
                      Is 2.5.0.8 going to be posted under the Beta Releases forum or the Downloader?
                        I've been using the beta for about a week and haven't noticed any problems with any of my homeseer functionality. The thermostats have stayed put since the beta. I would recommend taking the plunge and using the beta.
                          Thank you, Sir!
                          Hey, are you using a DSC alarm panel with the IT-100 by chance?
                            Thank you, Sir!
                            Nope, I have a Concord 4.
                              2.5.0.20 still rearrange thermostats. When you will fix the problem?
