Just wondering if there is a Is there a "Heat pump enabled" mode with Z-wave thermostats as there for my current RCS TX15B? Thanks. Elliott
Is there a "Heat pump enabled" mode with Z-wave thermostats?
Thanks for your response and sorry that I was not as precise as I should have been. I know that the Z-wave thermostats work with heat pumps. However, with the RCS X10 thermostat there is a "Heat Pump Recovery Mode," which is implemented by software (the plug-in). According to the documenation for the RCS X10 thermostat plug-in, this mode "if enabled...limits physical setpoint changes to one degree at a time until desired setpoint is reached." This prevents use of auxiliary heater. Elliott"Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
