Originally posted by stevea
View Post
Plug-in version?
Originally posted by Rupp View PostYes the Z-Wave stat is now built into HS and is controlled by HS. What I'm not sure of is if the .dll is still needed. I need to ask Rick about this. You could do a quick test and delete the .dll and restart HS and see if it is replaced.
Isn't a plug-in for the Z-wave thermostats still listed on the Updater?
Steve
Somewhere a couple versions back I believe that plug-in became part of the Homeseer release itself. Hopefully someone else can confirm my thinking.
Plug-in version?
On my "Setup / Interfaces" tab the ZWave Thermostat plug-in lists as "HSPI_ZWAVETHERM.DLL". However, it says the version is N/A, while every other plug-in as a version numbers. I was curious how to tell what version I have, so I decided to go look at the version properties of the DLL. Imagine my surprise: There is no such file!
Am I missing something?
SteveTags: None
