I am running HS 2.5.0.44 The HSPI_ZWAVETHERM.DLL shows as version N/A when it is enabled. Disabled it shows 2.5.0.44. Is this an issue? It seems to be timing out a large amount. --- Changed from win XP to Win 7 system and fighting teething changes.
Start up msg in log:
11/5/2011 14:59:20 Plug-In Found plug-in: ZWave Thermostats, version: 2.5.0.44
11/5/2011 14:59:27 ZWave Thermostats Devices Updated for thermostat: Thermostat
11/5/2011 14:59:38 ZWave Thermostats 1 Thermostats converted Successfully.
then:
11/5/2011 15:04:44 Warning Aborting Z-Wave send, taking too long to send command to node 17 waited 6 seconds
then I am seeing this a lot:
11/5/2011 16:32:45 ZWave Thermostats Aborting poll of this thermostat due to and error retrieving the temperature. Node: 17
then:
