Some time ago, I disabled the Z-Wave Thermostat plugin. The reason is beside the point but was due to underlying problems with data getting from the stat to HS. I'd never actually installed the Z-Wave thermostat and it existed only as a node in Homeseer for testing.
Anyway, since disabling the plugin, I've noticed it's still active and "converting" one Thermostat each time Homeseer restarts. I now have six identical thermostats on the Z-Wave Thermostat Status page, and no way I can find to delete them. Before disabling the plugin, there was only one thermostat represented.
The thermostat temperature is still being updated!
On the next restart, I do intend to delete the plugin, but that won't occur for several more days or, optimistically, weeks.
Point is, a disabled plugin shouldn't be initializing at all, much less running, should it!
