Email on startup and shutdown
  • Email on startup and shutdown
    Hi guys
    Anyone got any idea how to send email when hs starts or stops.?
    Mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    Check out the startup.txt and shutdown.txt files in the scripts directory. A call to hs.sendmail should work here.
    -Rupp
      You'll need to configure your email in HS first, then add the following line to your scripts/startup.txt:
      hs.sendEmail "toEmail@somewhere.com","fromEmail@somewhere.net","HomeS eer Startup","HomeSeer has started up."
      I'm not sure about shutdown, since it only gets called when HS is shutdown from the menu or script.
      HS3Pro Running on a Raspberry Pi2 (Raspbian)
      64 Z-Wave Nodes, 162 Events, 293 Devices
        Here is mine from my startup.txt script:
        'Send email when HomeSeer starts.
        hs.SendEmail "toemail@something.com", "fromemail@something.com", "HOMESEER ALERT: HomeSeer has restarted.", ""
        This is from my shutdown.txt script:
        ' send email
        hs.SendEmail "toemail@something.com", "fromemail@something.com", "HOMESEER ALERT: HomeSeer is shutting down.", ""
          Thanks guys
          Could I call an event instead that would do a dfew other things too?
          Regards
          Mark
          USB UIRT
          2GIG Thermostat
          BLUPS
          UltraLog (SQL2008)
          Jon00 Plugins
          Global Cache IP2IR
          Foscam FI8918W
            Originally posted by mark_anderson_us View Post
            Thanks guys
            Regards
            Mark
            I think so - that startup.txt should be run right after HS is started and ready to go. Just use hs.triggerEvent "myevent"
              Thanks. Worked a treat!
              USB UIRT
              2GIG Thermostat
              BLUPS
              UltraLog (SQL2008)
              Jon00 Plugins
              Global Cache IP2IR
              Foscam FI8918W
                Someone can confirm to me that works for shutdown?
                For the homeseer startup no problem, i receive the email but for shutdown no mail
                My shutdown vb script:
                HTML Code:
                Sub Main(Parm As Object)
                hs.SendEmail("cris****.****@gmail.com", "do.cris@gmail.com", "", "", "HOMESEER ALERT:", "HomeSeer is shutting down", "")
                End Sub
                (the same for the startup)
