My hometroller died, so I downloaded hs2 pro on my cpu, copied some files and I'm back up. Hstouch works fine. I use VNC for accessing HS program, but I can't get past the password. I've tried everything I know to do, but no luck. Where is the PW reset in the program? What else am I missing?
Password problem
This topic is closed.
Solved!
Thanks Rupp, that did it. I'll post this next question in the proper place, but might you know why my Fortrezz WWA01AA water detectors take a long time, 10 to 45 minutes, to register an alarm on HS? They will communicate with associated devices almost instantly and other nearby lamp modules communicate with the HS network immediately. I've tried many jack leg ideas, but no joy. Any ideas?HS4Pro on Windows 10
One install with 2 Ethernet Z-nets
2nd install with 1 Ethernet Z-net
300 devices, 250 events, 8 scripts
6 CT-100 tstats
Serial IT-100 interface to DSC Panel with 8 wired zones
18 Fortrezz water sensors & two valve controls
