I followed the help and
1) Drag a text element to your screen and click on the "StatusTrackingNormal" button, the Element Associations dialog will display. Check the "Use the same for Normal/Pressed, select "HomeSeer Devices" for the Normal Association Type
Select "Use Status Image" then click OK to close the dialog.
Set the properties of your Text elelment as follows:
Your Text element will now use the status of the HomeSeer device as its background image and will look like this
Till now it works OK.
Then I assign 2 images from graphic folder for ON and OFF and...NOTHING. Still the original HS image.
I feel there has to be the "DUH!" somewhere..
