How to enter time in HST?
    #16
    Thank you for posting those screen shots.
    Seems I had a "Homer" moment when setting up the events.
    Under the script procedure to run, I had ("CheckAlarm") and your screen shots showed me that it should be ("CheckAlarm","") and so now of course everything runs fine.
    Thanks again,
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
      #17
      let me know how you get on with it and whether it all works, I wrote it all in a bit of a rush. I do use it regularly but I generally don't wake up in time (a bomb would struggle to get me up sometimes) to actually turn it off at the screen hence why I have an event to turn it off when I walk in the lounge.
        #18
        It has been working perfect.
        Now for another question. Would it be possible to use the same kind of process to do a recipe screen?
        I found an older post where some guys put together an asp page to read an xml file of drink recipes. I figured out, with trial and error, to get 2 devices in HS to display the title and ingredients of the recipes you choose from a drop down on the asp page.
        Could this be done in HST using the List box and calling the asp page, or would the asp page have to be converted into a script?
        Tim
          #19
          Yes providing you did not want the list box data to change (whilst HSTouch was running), you can put what you want in a list box and then trigger something when you change it. You could trigger a script that finds out what you pressed and then set some devices on the basis of this.
          If your recipes are held on ASP pages then you by way of script can set the URL of a text element to the recipe page.
            #20
            fungun,
            I've fixed the asp page so that the pulldown list shows (and links to) the drink names containing apostrophes (sp?) properly.
            (your 2 lines with the hs.setdevicestring are not included though)
              #21
              This may be a stupid question, but...
              Originally posted by mrhappy View Post
              I've copied it to a new project instead and attached it here (with some of the graphics if they are any good to you) - if all else fails you could open two copies of the designer and copy the list boxes between this project and your own.
              I just stumbled across this clock thread and would like to try it out, but I don't see the project? Was it attached somewhere else and I just don't see it?
              Steve
              (System configuration is in my profile)
                #22
                See comment #2 in this thread http://board.homeseer.com/showthread...863#post843863
                Comment #29 is my package of revised scripts. I use the package without going thru HST and it works great.
                  #23
                  OK, I guess since this thread originally started out talking about HSTouch I expected to see an HSTouch Designer package that I would install to my designer folder.
                  Thanks for all your hard work!
                  Steve
                    #24
                    mrHappy, do you have this running in HS3?
                    I keep getting this long error that a "Sub or Function" can't be found.
                    Tim
                      #25
                      Tim
                      Afraid I have never tried it (my alarm is now automated and I no longer have a touch screen next to the bed) and looking at it at first glance there would need to be some amendments for it to work with HS3. In HS3 it would probably be easier to have a range of hours (0-23) in one device, a range of minutes (0-59) in another device. You'd then just status track the list boxes to the devices in HS, then when you press enable alarm it passed both device values to the script and you could do it that way.
                        #26
                        So I basically have to start over.
                        Hs3 is so complicated.
                        Should I still be able to use the first part of the script where it passes the parms from HSTouch?
                        This part confuses me.
                        You're talking about the Status Graphics tab for devices?
                        Tim
                          #27
                          Last year Colin asked about Zoltar which is a flash file I use with the Joggler and old Chumby. This lead to a discussion relating to clocks and alarm clock flash files.
                          You could just install an alarm clock flash file if you wanted to. No scripting involved.
                          Look here:
                          Zoltar, clocks flash files
                          You can also install an html5 clock / alarm clock today.
                          Here is a simple jquery alarm clock. Just copy the files over to your homeseer html directory.
                          Looks like this:
                          [ATTACH]60913[/ATTACH]
                          Auto mator
