Error Not Connecting
    Error = "HSTouch Server plug-in is incorrect version, or timeout getting the version from the server, version 1.0.0.58 or later is required. Get the latest plug-in for HomeSeer from www.homeseer.com/dowloads"
    I upgraded to designer version 1.0.72 and HSPro ver 2.5.0.52 and now designer will not connect. When I look into Setup/Interfaces it shows the HSTouch dll as 56 so that is probably the problem but I am not sure how to correct. I have closed, HS, and rebooted the machine, disabled HSTouch, closed HS, restarted HS and reenabled HSTouch and it still shows dll vs 56 in Setup/Interfaces for HSTouch.
    How do I fix the problem for HSTouch designer? Gary
    Try installing the .58 version of the server plugin from here ftp://ftp.homeseer.com/updates/Beta/...h_1_0_0_58.msi and install it. It might still be an older version in the designer install file...
