I currently have a script that passes in two parameters. Everything works great in Homeseer events. I would like to use HS Touch run a Homeseer script with values from Elements. I see how it works and I have added both parameters. However, it doesn't work. I think its because in my script I use | to separate both parameters and HS Touch doesn't. So do you know how HS Touch is separating the parameters? What character is HS touch using?
