HS3 Insteon 2413S and Global Cache
  • mstrickland
    Thanks. I will keep that in mind about multiple Com ports.
  • sparkman
    As an FYI, if you need more than 1 com port redirected, Lantronix has a good redirector here: http://ltxfaq.custhelp.com/app/answers/detail/a_id/928. It's free and allows many com ports to be redirected. The one that Global Cache shows only does 1 port in the free version.
    Cheers
    Al
  • mstrickland
    started a topic HS3 Insteon 2413S and Global Cache
    Is it possible to use a Global Cache iTach to create a connection to a serial PowerLink Modem that is a serial unit?
    I don't see any HS3 config settings and I cannot find any Windows drivers to just emulate a COM port with the Global Cache unit.
    Thanks.
    UPDATE
    After some digging I found a Windows client that lets you connect a Virtual Com Port via the Global Cache iTach unit. Here is the link to the driver and instructions to set it up.
    https://globalcache.zendesk.com/entr...tual-COM-port-
    I set it up and it does work. I configured the Insteon serial modem to use a standard COMx port that is attached to the iTach device that is connected to my LAN via WiFi.
