Contacting HomeSeer This Week
See more
See less
A10 on/off command not recognized
  • A10 on/off command not recognized
    I'm using the CTX35 plugin to read data from my Honeywell home automation system (Hometronic)
    This system sends A10 data to control the light switches etc.
    I want to intergrate the system with Zwave using Homeseer.
    Until now i am able to receive commands, but only the dim commands.
    So i can dim from 1 till 99 %. But when i sent a 0% or 100% command, homeer does not recognize the command. I says, Raw received, invalid checksum.
    What can i do to make this work?
    See log file:
    jun-21 20:44:28 A10 Line Read (part): G[1]133F31
    jun-21 20:44:28 A10 Line Read (part): 001
    jun-21 20:44:28 A10 Line Read (part): >28
    jun-21 20:44:28 A10 Line Read: >28001G[1]133F31
    jun-21 20:44:28 A10 Raw received: $>28001G[1]133F31CE#
    jun-21 20:43:40 A10 Line Read (part): G[1]130031
    jun-21 20:43:40 A10 Line Read (part): 001
    jun-21 20:43:40 A10 Line Read (part): >28
    jun-21 20:43:40 A10 Line Read: >28001G[1]130031
    jun-21 20:43:40 A10 Raw received: $>28001G[1]130031B5#
    jun-21 20:42:01 A10 Raw received (invalid checksum): $>28001G13GOFF2A#$>28001G[1]130031B5#
    jun-21 20:41:02 A10 Line Read (part): G[1]132031
    jun-21 20:41:02 A10 Line Read (part): 001
    jun-21 20:41:02 A10 Line Read (part): >28
    jun-21 20:41:02 A10 Line Read: >28001G[1]132031
    jun-21 20:41:02 A10 Raw received: $>28001G[1]132031B7#
    jun-21 20:39:51 A10 New A10 device table: >28 001 G13
    jun-21 20:39:51 A10 Old A10 device table: >28 001 G13
    jun-21 20:39:46 A10 Raw received (invalid checksum): $>28001G13GONEC#$>28001G[1]133F31CE# (command dim 100 percent)
    jun-21 20:39:45 A10 Raw received (invalid checksum): $>28001G13GOFF2A#$>28001G[1]130031B5# (command dim 0 percent)
    jun-21 20:39:37 A10 Line Read (part): G[1]130631
    jun-21 20:39:37 A10 New device found and created: A10-001 (SAIX12)
    This is interesting. I haven't changed this plugin for the last four year. Hard to believe anyone would find a issue with it after such a long time
    However, this issue seems that it is concatenating multiple commands. For instance:
    Should be two separate commands, "$>28001G13GONEC#" and "$>28001G[1]133F31CE#". I don't understand why the plugin is doing this... let me look into that.
    stefxx
      Can you please try the version attached? Just unzip and overwrite the current file. Make sure to stop the plugin first.
      stefxx
        Thank you so much for responding om my post.
        I have tested some more and i come to the following conclusion:
        dim 0 % gives a checksum fault
        dim 1 % is actual the off command
        dim 2 % is actual dimming 2 %
        dim 3% is actual dimming 3 %
        and so on till
        dim 98% is actual dim 98%
        dim 99% is actual the on command
        dim 100% is checksum fault.
        Because i am using hometronic just to sent scenes to Homeseer it does not really matter to me if i have to give a 100% or a 99% command.
        But if there is a easy way to solve this it would be nice. I will try the version you sent me.
        Thank you!
          Did the new version work better? Any differences? Thanks!
          stefxx
