Plugin for IKEA TRÃ…DFRI smart home devices Introduction / Configuration
This is a sticky topic.
    My plugins: Click image for larger version  Name:	ikea_64.png Views:	0 Size:	2.1 KB ID:	1421180​​​ Click image for larger version  Name:	Square64.jpg Views:	0 Size:	2.8 KB ID:	1421181​​​ Click image for larger version  Name:	Bond64.png Views:	0 Size:	5.1 KB ID:	1421176​​​ Click image for larger version  Name:	Sonoff64.png Views:	0 Size:	5.6 KB ID:	1421182​​​ ​​​ Click image for larger version  Name:	gates  - 3.jpg Views:	0 Size:	93.7 KB ID:	1423325​​​
    ​​​AK IKEA AKSquare AKBond AKSonoff AKShelly AKRemootio
    ​ Click image for larger version  Name:	AKEnphaseEnvoy64.png Views:	0 Size:	8.7 KB ID:	1421179​​​ Click image for larger version  Name:	AKGoogleCast64.png Views:	0 Size:	1.5 KB ID:	1421178​​​ ​​ ​​ ​ Click image for larger version  Name:	AKHeatmiserNeo64.jpg Views:	0 Size:	2.1 KB ID:	1421185​​​ Click image for larger version  Name:	AKTracdown500 - New.png Views:	0 Size:	300.3 KB ID:	1423326​​​
    AKWeather AKEnphaseEnvoy AKGoogleCast ​AKGoogleCalendar AKSmartDevice AKHeatmiserNeo AKTraccar
    Configuration
    After installing the plugin you need to configure the Gateway -
    1. After a few seconds the plugin should discover the Tradfri Gateway (using mDNS/Zeroconf) and create root HS device.
    Note 1: If mDNS/Zeroconf Discovery doesn't work - please install Bonjour Print Services for Windows, after restarting the plugin - it should automatically use the provider (MonoZeroconf)
    Note 2: If mDNS/Zeroconf Bonjour Discovery still doesn't work - you can add new device manually
    2. Enter Ikea Gateway Key (found on the bottom of Gateway).
    3. Plugin should generate "App Name" and request "App Key" automatically.
    4. That's it. AK IKEA plugin will discover the devices and create HS devices.
    Click image for larger version  Name:	settings.png Views:	0 Size:	64.6 KB ID:	1505436
    5. Device update rates and Log:
    Click image for larger version  Name:	MyDevices1.png Views:	0 Size:	99.6 KB ID:	1505437
      Note on Update rate settings
      1. Update rate for the Bridge (Gateway):
      Controls scan time for new devices / groups / moods (scenes)
      If you don't plan adding new devices - it can be disabled (set to 0)
      2. Update rate for the Groups:
      Similar to the Bridge - scanning for new devices and moods (scenes) in the group
      3. Update rate for the Lights:
      The light devices support Observation (immediate notifications), but just in case I also scan them for changes.
      Can be disabled also (set to 0).
        Created ROOT devices:
        1. The Gateway (Bridge)
        2. Lights
        3. LED Drivers
        4. Groups
        5. Remote Controls
        For each RGB Light:
        1. Brightness slider, On/Off
        2. Color devices: Hue/Sat/X/Y
        3. Predefined (named) Tradfri colors
        4. Custom RGB color - note that Tradfri protocol doesn't support RGB setting, so the plugin converts the custom color to Color XY - which may produce slight variation in colors
        5. Transition time (ramp rate) - separate for the Brightness and the Color changes
        For White spectrum lights:
        There's no Color controls,
        1. only color temperature (if supported) - WarmGlow, WarmWhite, CoolWhite and
        2. related color temperature (in Mireds) - i.e. CoolWhite = 250M, WarmGlow = 454M
        For each Group:
        1. Similar devices to each group member
        2. Mood (Scene) i.e. Everyday, Relax, Focus (scenes are created in Ikea Home app)
        For Tradfri remote:
        1. Battery level
          Ver 4.0.0.39 - Added Ikea Starkvind Air purifier
            Is 4.0.0.39 on its way to the updater?
                Ah - I didn't realise it was beta. Have you a timetable for it be non-beta?
                  The way HS updater works - I can submit the new version immediately as BETA. Then HST move it to the release. So it's up-to-them when it happens.
                  So technically it doesn't matter that it's in BETA now.
