Gateway showing as 'Unauthorised'
    #16
    Well, props for dedication! Lockdown in London, so pretty early nights to cope with home-schooling...
    Am running BETA 3.0.0.21.
    I'm SSHing into the SEL, so not seeing the boot / HS initialisation, if that's what we need? Can get a monitor on it in a squeeze, but assuming there'll be a log the startup somewhere?
    In case you wanted to see my Plugin config page:
    Click image for larger version  Name:	Screenshot 2020-04-05 at 23.56.22.png Views:	0 Size:	28.6 KB ID:	1375336
    Also notice the Device config page now has 'App "key"' on it, if that's a thing.
    Click image for larger version  Name:	Screenshot 2020-04-05 at 23.56.02.png Views:	0 Size:	127.0 KB ID:	1375335
    Thanks for all so far.
    R.
      #17
      How do you start HS? Via SSH?
      When you enter the hub KEY - the plugin should generate the appName - then request the appKey from Gateway. Since you don't even have the appName - means there's some problem before trying to get the appKey.
      Did you try both config pages? I fixed the Device Config, may be you get more lucky.
      I'll have to add more logging to trace the whole path....
        #18
        Yep. Tried both config pages.
        HA runs on its own headless SEL box, and so the server starts automatically at boot.
          #19
          Do you mean HS? Yeah, for troubleshooting probably the easiest is to connect a display. You can try SSH and restart HS from the SSH window too.
            #20
            Ok, please try ver. 3.0.0.22 (BETA) - added more logging, also I generate the appKey earlier.
            If still doesn't work - please send me the logs.
              #21
              Can’t get a display hooked up easily today. Have had a scoot through the logs in usr/local/Homeseer/Logs, and nothing standing out as relevant. Not sure where else I should be looking, to be honest...
              The HS Log itself with 3.0.0.22 (BETA). The two top lines just then log on repeat until stopped:
              Apr-06 11:16:17 AK Ikea [164]: Not ok: hubkey 'XXXXXXXXXXXXXXXX', app '', appkey: ''
              Apr-06 11:16:17 AK Ikea Warning [164]: CheckTradfriController: app '' key '' ok False
              Apr-06 11:16:16 AK Ikea Warning [164]: SaveIkeaDevice receiver: Unknown
              Apr-06 11:16:16 AK Ikea Warning [164]: Set hub key: XXXXXXXXXXXXXXXX, receiver: [newIkea] New Receiver (192.168.1.97)
              Apr-06 11:16:16 AK Ikea [164]: Not ok: hubkey '', app '', appkey: ''
              Apr-06 11:16:16 AK Ikea Warning [164]: CheckTradfriController: app '' key '' ok False
              Apr-06 11:16:15 AK Ikea [164]: Not ok: hubkey '', app '', appkey: ''
              Apr-06 11:16:07 AK Ikea Warning [164]: CheckTradfriController: app '' key '' ok False
              Apr-06 11:16:06 AK Ikea [164]: Not ok: hubkey '', app '', appkey: ''
              Apr-06 11:16:06 AK Ikea Warning [164]: CheckTradfriController: app '' key '' ok False
              Apr-06 11:16:05 AK Ikea [164]: Not ok: hubkey '', app '', appkey: ''
              Apr-06 11:16:05 AK Ikea Warning [164]: CheckTradfriController: app '' key '' ok False
              Apr-06 11:16:04 AK Ikea Warning [164]: SaveIkeaDevice receiver: Unknown
              Apr-06 11:16:04 AK Ikea Warning [164]: Set hub key: , receiver: [newIkea] New Receiver (192.168.1.97)
              Apr-06 11:16:04 AK Ikea Warning [164]: [newIkea] New Receiver (127.0.0.1): Setting new IP address: 192.168.1.97:80
              Apr-06 11:15:53 AK Ikea [0]: * Set Ikea [newIkea] New Receiver (127.0.0.1) (HSPI_AKIkea.DeviceIkeaBridge) Same: False
              Apr-06 11:15:53 AK Ikea Saved device: newIkea (newIkea), id: Unknown, url: 127.0.0.1:80
              Apr-06 11:15:38 AK Ikea Warning Running on 'linux' - using Locator.MonoZeroconf.DeviceLocator
              Apr-06 11:15:38 AK Ikea ERROR Locator.MonoZeroconf.DeviceLocator: FATAL CreateListener: No Zeroconf providers could be found or initialized. Necessary daemon may not be running.
                #22
                Thank you, I'll compare with my logs - what's strange "Set hub key: , " doesn't have any hubKey...
                  #23
                  BTW, if your Zeroconf (mDNS) didn't work - how did you create the bridge device? What's the sequence? I'll try to reproduce.
                  [EDIT]
                  Actually, if I disable mDNS and add receiver manually - I think I can reproduce the problem
                    #24
                    Ok the problem is - from mDNS I get the Gateway ID, but when you add the receiver manually - the ID is empty.
                    So, I will set the ID to the hubKey in this case.
                      #25
                      Yep - that’s it. I’m manually adding the IP and Security Key from the plugin manager, then going to the Device Config.
                      Know it’s not terminal, but bit odd that ZeroConf isn’t working. I wonder if that’s related to the old Mono (it’s back on 3.2.8)?
                      And is the lack of .ini files is because there are no preferences being written yet..?
                        #26
                        I'm fixing manual device creation now, that's the priority.
                        Regarding Zeroconf - we'll sort it out later, but why did you change back to Mono 3? Users are happy with 5.x
                          #27
                          Awesome.
                          I reverted back because the upgrade totally destroyed my Events - seems to be an issue that upgrading from 3 kills all the IF functions, which relied on the old framework, with the worst case being recreating them all from scratch. Which would be a horror. Hope Malcolm from the other thread swerved this.
                          Rolling back and doing a full restore from a mercifully recent backup got them back. I’m a bit too reliant on Events to risk losing them again until I get some time to explore whether an export / import or similar will work / recreate the critical ones... eugh.
                          I don’t know how typical I am, but I’d imagine there would be a certain amount of the user base still on 3.x, as it looks to be what HS’ own systems came with until mid-2018. But I totally understand your frustration at supporting such legacy cruft.
                            #28
                            ok, ver BETA 3.0.0.23 should fix your problem, hopefully
                              #29
                              Well. Yes! Some progress...
                              Nothing initially. Then an error in the plug-in status as before (not listed). A reinstall got it working...
                              Picked up the Gateway, and then had a think. No devices found (should be 6x FUTYR blinds, a couple of remotes and a repeater).
                              Then the warning triangle:
Name:	Screenshot 2020-04-06 at 15.14.25.png
                              Aaaaaaand the log meantime:
                              Apr-06 15:10:11 AK Ikea ERROR [164]: Request failed() : /15004
                              Apr-06 15:10:11 AK Ikea ERROR [164]: ERROR MakeRequest(/15001): System.ArgumentNullException: Argument cannot be null. Parameter name: s at System.Text.Encoding.GetBytes (System.String s) [0x00000] in :0 at Tradfri.TradfriController.MakeDTLSClientEndPoint (System.String Octet_k, System.String KeyIdentifier) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey (System.String appKey, System.String appName) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey () [0x00000] in :0 at Tradfri.TradfriController+d__41.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__39.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__37`1[System.Collections.Generic.List`1[System.Int64]].MoveNext () [0x00000] in :0
                              Apr-06 15:10:11 AK Ikea ERROR [164]: Request failed() : /15001
                              Apr-06 15:10:10 AK Ikea ERROR [164]: ERROR MakeRequest(/15004): System.ArgumentNullException: Argument cannot be null. Parameter name: s at System.Text.Encoding.GetBytes (System.String s) [0x00000] in :0 at Tradfri.TradfriController.MakeDTLSClientEndPoint (System.String Octet_k, System.String KeyIdentifier) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey (System.String appKey, System.String appName) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey () [0x00000] in :0 at Tradfri.TradfriController+d__41.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__39.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__37`1[System.Collections.Generic.List`1[System.Int64]].MoveNext () [0x00000] in :0
                              Apr-06 15:10:10 AK Ikea ERROR [164]: Request failed() : /15004
                              Apr-06 15:10:10 AK Ikea ERROR [164]: ERROR MakeRequest(/15001): System.ArgumentNullException: Argument cannot be null. Parameter name: s at System.Text.Encoding.GetBytes (System.String s) [0x00000] in :0 at Tradfri.TradfriController.MakeDTLSClientEndPoint (System.String Octet_k, System.String KeyIdentifier) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey (System.String appKey, System.String appName) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey () [0x00000] in :0 at Tradfri.TradfriController+d__41.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__39.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__37`1[System.Collections.Generic.List`1[System.Int64]].MoveNext () [0x00000] in :0
                              Apr-06 15:10:10 AK Ikea ERROR [164]: Request failed() : /15001
                              Apr-06 15:10:09 AK Ikea ERROR [164]: ERROR MakeRequest(/15004): System.ArgumentNullException: Argument cannot be null. Parameter name: s at System.Text.Encoding.GetBytes (System.String s) [0x00000] in :0 at Tradfri.TradfriController.MakeDTLSClientEndPoint (System.String Octet_k, System.String KeyIdentifier) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey (System.String appKey, System.String appName) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey () [0x00000] in :0 at Tradfri.TradfriController+d__41.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__39.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__37`1[System.Collections.Generic.List`1[System.Int64]].MoveNext () [0x00000] in :0
                              Apr-06 15:10:09 AK Ikea ERROR [164]: Request failed() : /15004
                              Apr-06 15:10:09 AK Ikea ERROR [164]: ERROR MakeRequest(/15001): System.ArgumentNullException: Argument cannot be null. Parameter name: s at System.Text.Encoding.GetBytes (System.String s) [0x00000] in :0 at Tradfri.TradfriController.MakeDTLSClientEndPoint (System.String Octet_k, System.String KeyIdentifier) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey (System.String appKey, System.String appName) [0x00000] in :0 at Tradfri.TradfriController.ConnectAppKey () [0x00000] in :0 at Tradfri.TradfriController+d__41.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__39.MoveNext () [0x00000] in :0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in :0 at System.Runtime.CompilerServices.TaskAwaiter`1[System.String].GetResult () [0x00000] in :0 at Tradfri.TradfriController+d__37`1[System.Collections.Generic.List`1[System.Int64]].MoveNext () [0x00000] in :0
                              Apr-06 15:10:09 AK Ikea ERROR [164]: Request failed() : /15001
                              Apr-06 15:10:08 AK Ikea ERROR [164]: ConnectGateway: System.MissingMethodException: Method not found: 'System.Array.Empty'. at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erializeConvertable (Newtonsoft.Json.JsonWriter writer, Newtonsoft.Json.JsonConverter converter, System.Object value, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonContainerContract collectionContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erializeValue (Newtonsoft.Json.JsonWriter writer, System.Object value, Newtonsoft.Json.Serialization.JsonContract valueContract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in :0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erializeObject (Newtonsoft.Json.JsonWriter writer, System.Object value, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract collectionContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in :0
                              Apr-06 15:09:51 AK Ikea Warning [164]: [newIkea] New Receiver (127.0.0.1): Setting new IP address: 192.168.1.97:80
                              Apr-06 15:09:38 AK Ikea [0]: * Set Ikea [newIkea] New Receiver (127.0.0.1) (HSPI_AKIkea.DeviceIkeaBridge) Same: False
                              Apr-06 15:09:38 AK Ikea Saved device: newIkea (newIkea), id: Unknown, url: 127.0.0.1:80
                              Apr-06 15:09:34 AK Ikea Warning Running on 'linux' - using Locator.MonoZeroconf.DeviceLocator
                              Apr-06 15:09:34 AK Ikea ERROR Locator.MonoZeroconf.DeviceLocator: FATAL CreateListener: No Zeroconf providers could be found or initialized. Necessary daemon may not be running.
                              Apr-06 15:09:34 Plug-In Finished initializing plug-in AK Ikea
                              Apr-06 15:09:34 Starting Plug-In AK Ikea loaded in 2763 milliseconds
                              Apr-06 15:09:34 Starting Plug-In Plugin AK Ikea started successfully in 840 milliseconds
                                #30
                                That's the .NET version problem. I'll check the dependency of Newtonsoft.Json library - since it's not my code - I don't have much control, unless I compile from source.
