What do you have in "ls /usr/lib/mono/"?
Gateway showing as 'Unauthorised'
And yes. Also been through Domoticz, OpenHAB etc. A lot of tinkering. I suspect a hybrid approach will be the way. Bit of tinkering, but something solid for when I just want to turn the lights off...
They’re obviously going through a huge reorg at the moment. Lots of promises. I guess we’ll see!
Output from mono --version:
Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: x86
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
Originally posted by rahaaas View PostThanks... that sounds like it might be a good solution. For now, just getting the plugin working would be great. There is also huge ire at the Ikea software, which makes HSS look cutting-edge... absolute shambles that randomly reconfigures and forgets the system, and then denies all knowledge of anything. Support from Ikea when £1000 worth of stuff stops working is ‘Oh, that’s an internet thing isn’t it? Sorry. No idea. Take it back, maybe?’
Regarding Home Assistant - before choosing HS I also looked at free automation software, inc. OpenHAB, Domoticz, etc. I found they take too much tinkering, and most integration created by enthusiasts, not Software Engineers. But it was a few years ago, now Home Assistant is way more popular.
Regarding the system dlls - I need to think where to start. It looks like you have ver. 4.5 - but I'm not sure if it's Mono version or .NET version?
Can please you check "mono --version" and "ls /usr/lib/mono/"
HS4 probably won’t be happening by default after this. I’m frankly going to look at Home Assistant when I get some time. If I’m going to have to mess about with things, I may as well get my hands dirty, and it seems way more flexible. Imagine having a mobile interface that propagates across users? Madness.
So yes. If you’d be happy to bung some DLLs over, I’d happily receive them. And pony up for the plug-in!
[Code:169]: [newIkea] New Receiver (127.0.0.1): Setting new IP address: 192.168.1.97:80 System.Net.Sockets.SocketOptionName 0x1b is not supported at IPv6 level Missing method System.Array::Empty<[1]>() in assembly /usr/lib/mono/4.5/mscorlib.dll, referenced in assembly /usr/local/HomeSeer/HSPI_AKIkea.exe [169]: ConnectGateway: System.MissingMethodException: Method not found: 'System.Array.Empty'. at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeConvertable (Newtonsoft.Json.JsonWriter writer, Newtonsoft.Json.JsonConverter converter, System.Object value, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonContainerContract collectionContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in <filename unknown>:0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeValue (Newtonsoft.Json.JsonWriter writer, System.Object value, Newtonsoft.Json.Serialization.JsonContract valueContract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in <filename unknown>:0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeObject (Newtonsoft.Json.JsonWriter writer, System.Object value, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract collectionContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in <filename unknown>:0
Originally posted by rahaaas View PostMissing method System.Array::Empty<[1]>() in assembly /usr/lib/mono/4.5/mscorlib.dll, referenced in assembly /usr/local/HomeSeer/HSPI_AKIkea.exe
Originally posted by rahaaas View PostA quick SSH in produced some output, attached. This any use? Obviously some missing files...
[EDIT: Running 3.0.0.26]
But it does show "Could not find org.freedesktop.Avahi" meaning that you don't have avahi-daemon.
Then:
Code:[COLOR=#FF8C00]System.Net.Sockets.SocketOptionName 0x1b is not supported at IPv6 level[/COLOR] [COLOR=#FF0000]Missing method System.Array::Empty<[1]>() in assembly /usr/lib/mono/4.5/mscorlib.dll, referenced in assembly /usr/local/HomeSeer/HSPI_AKIkea.exe[/COLOR] [169]: [COLOR=#FF0000]ConnectGateway: System.MissingMethodException: Method not found: 'System.Array.Empty'. at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erializeConvertable (Newtonsoft.Json.JsonWriter writer, Newtonsoft.Json.JsonConverter converter, System.Object value, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonContainerContract collectionContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in <filename unknown>:0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erializeValue (Newtonsoft.Json.JsonWriter writer, System.Object value, Newtonsoft.Json.Serialization.JsonContract valueContract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in <filename unknown>:0 at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.S erializeObject (Newtonsoft.Json.JsonWriter writer, System.Object value, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract collectionContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty) [0x00000] in <filename unknown>:0[/COLOR] [169]: Request failed() : /15001 [169]: ERROR MakeRequest<List`1>(/15001): System.ArgumentNullException: Argument cannot be null. Parameter name: s
[EDIT: Running 3.0.0.26]Attached Files
Yep. That thread is what got me into trouble. It worked, but doesn't mention the issue with Events, and only at the end does it correct the issue with deleting the latest version marker... Was in touch with HS about it, and they acknowledged the upgrade issue with the IF statements, and have said they'll update the support article on it.
Originally posted by rahaaas View Post. Can’t believe it’s not come up before.
https://forums.homeseer.com/forum/ho...89#post1284089
pointing to
https://www.google.com/url?q=https:/...QfCNbuQxXBSEsA
That’s great. Thanks. Should get a chance to get on this in the next couple of days. Will let you know what occurs!
