Unable to get the plugin working
    #16
    so I did a bit of quick testing and it recognises the devices as per the screenshots below and the outlet device is able to be controlled. The issue is it makes the system slightly unresponsive and fills the log up as per screen shot 3.
    when I enable the plug in the Jowihue issue reappears. that plug in has the same type of devices associated with it through a the deconz hub rather than the ikea hub
    thanks
    Click image for larger version  Name:	Annotation 2020-04-07 212942.png Views:	0 Size:	174.5 KB ID:	1375873Click image for larger version  Name:	Annotation 2020-04-07 213234.png Views:	0 Size:	251.2 KB ID:	1375874Click image for larger version  Name:	Annotation 2020-04-07 212817.png Views:	0 Size:	414.9 KB ID:	1375875
      #17
      That's great.
      Most devices support "observation" - so you don't need polling at all. Just in case observation fails - I still use the polling timer.
      For remote control and sound controller it's safe to set polling time to 0 - since there's no useful info from them at this time.
      Main device polling is used to detect when new devices/groups are added - so it's safe to disable (or set to 60 sec) when you don't plan to add more devices.
      For other devices you can set polling time to 10 sec. This will improve system responsiveness.
      Please note that main config screen has 2 sec timer - so it's a bit fiddly to change polling time here. Individual config screens are easier.
        #18
        I'll fix the log.
        Regarding the outlet (plug) - does it actually work? i.e.
        1. Reflects the state change when you control it via the Ikea app?
        2. Controls the state with On/Off buttons (and reflects the state change)?
          #19
          Originally posted by mikeeee30 View Post
          the reason I ask about the Jowihue issue is that this error isn't there if your plugin is disabled but is when your plugin is enabled
          If you can reproduce the issue - I can fix it. But may be create an new thread please.
            #20
            Originally posted by alexbk66 View Post
            I'll fix the log.
            Yes it works really well thanks. I will try enabling the plug in again and changing the refresh times
            thanks
              #21
              Great, thank you.
                #22
                Hello, I can't find the beta for this in the Beta Section. I am trying to test the new devices.
                Transitioning to HS3Pro .298 - WinXPEmbedded
                Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
                  #23
                  I think HST just moved from BETA to release 3.0.0.26
                    #24
                    So is it no longer beta? I saw you said you were submitting beta again.
                      #25
                      I can only submit new versions in BETA section, then HST move from BETA to release (when they feel like)
                      In any case there are always release notes links (in both BETA and release)
                      http://plugins.homeseer.com/releasenotes?productid=382
                        #26
                        im having trouble with the plugin. i have to manually type in the Ip adress of the GW. i get the green arrow when i type inn the security code. but nothing happens, when i check the log its full of errors. im using homeseer 3 on hometroller sel. What can be wrong?
Name:	ikea error 2.jpg
ID:	1392239Click image for larger version
Name:	ikea error 1.jpg
                          #27
                          There's a problem on Linux with older Mono versions, and there was a thread about in this forum, I'll find it. What's you Mono?
                          [EDIT]
                          @erdna84 there was similar discussion here https://forums.homeseer.com/forum/li...thorised/page5
                            #28
                            [EDIT]
                            Thank you. i had mono 3.2.8. updated to mono 5, now it works perfekt
                              #29
                              Great, that was easy
                                #30
                                On a side note, you are using your email address as your user name - I don't think it's a good idea, eventually you'll get too much spam
