Info plugin ikea icons
    Some days ago I asked you for my problems about my installation of the plugin of Ikea. I said that the signal was low.
    But now I have made a new installation. The signal of zigbee is ok. I got a nice signal in my hole the house.
    I have now installed the hub, 1 remote and 1 bulb. And in HS3 I got a lot of icons after the installation. Can you say what to do with of those icons? And which icon I can use for control the bulb? See pictures below.
    IKEA hub creates groups automatically for each remote control - i.e. if you control multiple bulbs with one remote.
    So normally you use the group (group 2 in your case) to control lights - same way you use the remote.
    But you can also control each bulb separately. In your case - since you have only one bulb - it doesn't matter.
    There's also "Super Group" - to control all lights in the house.
      You'll get even more fun if you have RGB lights
Name:	one light.jpg
        Thanks.
        I bought a set by Ikea to try the zigbee hub and to see what is possible with white light. Also to see how your plugin works in HS3. For me I think it is a fine plugin.
        What can I do with the blue icon and the 2 seconds.
        The pulldown menu for update time in the Ikea config page, is difficult to change. If I open the pulldown menu, it close in 1 or 2 sec. again. That is for me to quick to change something in time. How must I do that.
        Wim
          "What can I do with the blue icon and the 2 seconds" - These are "Transition Time" devices, i.e. duration of changing brightness - 0 for immediate. I think it's ignored when you switch off the light.
          Regarding the pulldown menu - you can change the update rate on each device individual config page without problems.
          In HS4 version it's different:
            BTW, for RGB light there's also separate transition time for color change.
                Originally posted by wim2008 View Post
                NP
