santoal what does it show on the device config page in HS? What Dimmer settings do you think is necessary to implement in HS? Definitely user/password.
Original Plugin for Shelly devices - Intro / Config / Screenshots [No MQTT]
This is a sticky topic.
Originally posted by santoal View PostDimmer control looks ok.
This is what it shows for the dimmer control in HS.
Originally posted by santoal View PostI would just use the Shelly app for settings. Perhaps fade rate and auto off/on timer if that is what you mean.
We have control!
Just a few issues:
1) Off Status not showing correctly in HS3. Changes momentarily but then goes back to % dim value. I think because its re-reading the dim status % from Shelly which then overrides off. Pressing off does turn it off though.
2) Can only seem to slide dim to 99% max in HS
3) Temperature log errorDec-06 12:32:14 AM AK Shelly ERROR [746]: shellydimmer (SHDM-1): HandleDeviceStatus for (Ref: 749) F3A91D.Temperature (Unknown) Dec-06 12:32:14 AM AK Shelly [746]: shellydimmer (SHDM-1): *** {"wifi_sta":{"connected":true,"ssid":"Karoo Springs","ip":"192.168.1.164","rssi":-55},"cloud":{"enabled":true,"connected":true},"mqtt":{"conne cted":false},"time":"00:32","serial":3604,"has_update":false ,"mac":"CC50E3F3A91D","lights":[{"ison":false,"mode":"white","brightness":99}],"meters":[{"power":0.00, "is_valid":true, "timestamp":1575592334,"counters":[0.020, 0.015, 0.001],"total":95}],"inputs":[{"input":0},{"input":0}],"tmp":{"tC":46.24,"tF":115.23, "is_valid":"true"},"calib_progress":0,"overtemperature":fals e,"loaderror":false,"overload":false,"update":{"status":"idl e","has_update":false,"new_version":"20191127-095929/v1.5.6@0d769d69","old_version":"20191127-095929/v1.5.6@0d769d69"},"ram_total":39600,"ram_free":28232,"fs_siz e":233681,"fs_free":140560,"uptime":214656} Dec-06 12:32:14 AM AK Shelly [746]: shellydimmer (SHDM-1): Execute cmd: status
Originally posted by santoal View Post1) Off Status not showing correctly in HS3. Changes momentarily but then goes back to % dim value. I think because its re-reading the dim status % from Shelly which then overrides off. Pressing off does turn it off though.
Shelly do have separate control for on/off and brightness - which is good. May be it makes sense to separate them?
Originally posted by alexbk66 View Post
Yeah, the problem is - I didn't want to create two HS devices - one for on/off, one for dim level. Tried to combine them in one. I'll think more... I don't like two separate devices...
Originally posted by alexbk66 View PostIn the mean time... Since HST can't fix their portal. Attached the version 3.0.0.26.
You need to copy the zip file to "C:\Program Files (x86)\HomeSeer HS3\Updates3\Zips" and the updater_override.txt to the root HS installation.
Scrap that. Update didn't install properly. Updates from Shelly web page to HS3 work ok. Turning off dimmer in HS3 has no effect and produces an error. I think a "last" button still makes sense as per previous post.Dec-08 9:24:12 AM AK Shelly ERROR [758]: shellydimmer (SHDM-1): [SHDM-1] F3A91D (192.168.1.164): Execute '/light/0?brightness=0&turn=off': Status: 'Error' Error: 'Data at the root level is invalid. Line 1, position 1.' response: 'Bad brightness value!' code: 'BadRequest/Bad Request' '' Dec-08 9:24:12 AM AK Shelly [758]: shellydimmer (SHDM-1): *** Bad brightness value! Dec-08 9:24:12 AM AK Shelly [758]: shellydimmer (SHDM-1): Execute cmd: /light/0?brightness=0&turn=off Dec-08 9:24:12 AM AK Shelly [758]: shellydimmer (SHDM-1): SetBrightness to 0
Originally posted by santoal View PostAlso I have a temp of 48 deg causing the warning symbol to appear. I assume 48 deg is ok still? Everything else working ok.
Originally posted by santoal View PostTurning off dimmer in HS3 has no effect and produces an error. I think a "last" button still makes sense as per previous post.
I can add "Last=255". We'll see...
