Adding Shelly devices manually (if mDNS discovery fails)
This is a sticky topic.
    Version 3.0.0.10 (in Beta section) has the ability to add Shelly devices manually.
    Click image for larger version  Name:	AddManually1.jpg Views:	0 Size:	151.1 KB ID:	1339729
    Simply click green "+" button and then enter the new device IP address in the IP field.
    Note: sometimes the screen may misbehave, i.e. after clicking the "+" button the new "empty" device doesn't show, or the IP field gets duplicated.
    Just refresh the page please.
    Ver 3.0.0.62 - added support for Bonjour and TmDs Zeroconf (mDNS) discovery on Windows. The best discovery is selected when plugin starts, i.e. if you have Apple Bonjour service installed - the plugin will use Mono.Zeroconf with Bonjour provider automatically.
    The new discovery services should make it more reliable, so hopefully you won't need to add the devices manually.
    Apple Bonjour service is installed on Windows if you have any Apple app installed, i.e. iTunes. In case you don't have it and you want to use - install Bonjour Print Services for Windows
