I'm getting the following errors when starting up:
10/10/2020 2:20:21 PM
HomeSeer
Info
Plugin AK Shelly with ID: and Instance: has disconnected
10/10/2020 2:20:19 PM
Legacy-Plugin
AK Shelly ERROR
Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: <. Path '', line 0, position 0. at: Newtonsoft.Json.JsonTextReader.ParseValue() at: Newtonsoft.Json.JsonTextReader.Read() at: Newtonsoft.Json.Linq.JObject.Load(JsonReader reader, JsonLoadSettings settings) at: Newtonsoft.Json.Linq.JObject.Parse(String json, JsonLoadSettings settings) at: HSPI_AKShelly.DeviceShellyRoot.Execute[T](String command, Object json, Int32 timeout, Method method, Boolean dontClearErr) at: HSPI_AKShelly.DeviceShellyRoot.GetSettings(String cmd) at: HSPI_AKShelly.DeviceShellyRoot.InitCallback(Object state) at: System.Threading.TimerQueueTimer.CallCallbackInContext(Objec t state) at: System.Threading.ExecutionContext.RunInternal(ExecutionConte xt executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at: System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at: System.Threading.TimerQueueTimer.CallCallback() at: System.Threading.TimerQueueTimer.Fire() at: System.Threading.TimerQueue.FireNextTimers() at: System.Threading.TimerQueue.AppDomainTimerCallback(Int32 id)
Legacy-Plugin
AK Shelly ERROR
Legacy-Plugin
AK Shelly ERROR
UnhandledException!!!
I have tried to disable plugin, reboot and start again, but same issue. If I leave the plugin active, eventually it reports a plugin error and sometimes shows "loaded remotely". Either way, I can't access the config page etc.
What's my best course of action?
HomeSeer
Info
Legacy-Plugin
AK Shelly ERROR
Legacy-Plugin
AK Shelly ERROR
Legacy-Plugin
AK Shelly ERROR
