No MQTT - Plugin for Sonoff DIY devices - Intro / Config / Screenshots
This is a sticky topic.
    #16
      #17
      Next issue, I only have XP on VirtualBox. DIY tool won't run. All my machines is Linux, swapped MS out some years ago.
        #18
        If you have VirtualBox - no reason you can't download Windows 10 image.
        Also I'm doing .NET version of their 'tool' - with minimal functionality, i.e. discovery and setting WiFi.
        But my 3 yo daughter get sick, we spent 6 hrs in ED today, so no ETA
          #19
          No hurry at all, I can wait. Take care of your family
            #20
            alexbk66, your plugin works very well
            I added another SSID to my router with sonoffDiy.
            Status is changing when i switch local on the device.
            If I disconnect the status is changing.
Name:	Skärmbild från 2019-09-02 19-09-35.png
              #21
              just bought your plugin
                #22
                The mini Sonoff has connection in my barn 30m away from router and through a concrete wall. I also tested in my garage ca 40-50m away and through a metal roof. (my router is in a window so signal just passes one wall and glass)
                  #23
                  Yeah, Sonoff devices are pretty good.
                  They just need to simplify the initial paring procedure.
                    #24
                    Updated to 1.0.0.4 Wont work at all.
Name:	Skärmbild från 2019-09-09 20-50-45.png
Name:	Skärmbild från 2019-09-09 20-50-07.png
                      #25
                      Sorry, It woks on linux, reinstalled. Maybe my test device was to long away. Got another device and set up near my router and it is ok.
                        #26
                        I will still check the code, it shouldn't throw exception in TrimNameToId. But it's gonna be hard to test
                          #27
                          News from Sonoff, they are improving their firmware:
                          We are still collecting more suggestions from home automation community.
                          We summarized most of the issue on the Github which you have involved.
                          * simplify the device set up procedure with AP mode
                          * simplify to update the device firmware
                          * API of "Get Device Info" should be an object instead of strings ( maybe optimized but you have the way to transformation)
                          * we are creating a Dimmer, you will see it very soon, maybe next month or Dec
                            #28
                            Will your plugin support the Sonoff 4CH Pro (R2) unit?
                            Scott
                              #29
                              I intend to support all Sonoff devices with DIY firmware. By DIY they mean local control (REST API) - without using cloud server.
                              Currently Sonoff have only three DIY devices:
                              https://www.itead.cc/sonoff-basicr3-...rt-switch.html
                              https://www.itead.cc/sonoff-rfr3.html
                              https://www.itead.cc/sonoff-mini.html
                              Also they are working on dimmer switch, which is very welcome.
                              So my plugin will support new DIY devices when (if) Sonof make DIY firmware for them.
                                #30
                                On their company site they list 10 DIY products, but they wouldn't be the first company to list products that aren't available yet as if they were.
                                https://sonoff.tech/product-category...smart-switches
