yup, we will review all of them. I will discuss with my team for a better DIY MODE.
No MQTT - Plugin for Sonoff DIY devices - Intro / Config / Screenshots
This is a sticky topic.
I've got an email from Sonoff, so hopefully the pairing procedure will be improved:
We agreed to your point to optimize the device pairing procedure, there is some of other platforms feedback for such. the AP mode is recommended. Our team will discuss and give a solution.
- Likes 2
Originally posted by lunkan View PostI'm on Linux, Rpi
[EDIT]
Sonoff use mDNS record to update data (i.e. switch state). Which is cool - doesn't require polling devices for status (like Shelly). Problem is on Linux Mono.Zeroconf doesn't support that. So to fix status update I must implement polling, for now at least.
- Likes 1
I hope Sonoff will simplify pairing procedure.
Any issues with devices - please open a ticket with Sonoff https://github.com/itead/Sonoff_Devices_DIY_Tools/issues - it will let them know if users are struggling...
Ver. 3.0.0.7 - Added manual Sonoff devices registration (in case mDNS discovery doesn't work).
1. Simply click green "+" button and then
2. Enter the new device IP address in the IP field
4. Normally Sonoff status is updated from mDNS message. If mDNS doesn't work and the device is added manually - the "Update" field should be set to non-zero value to enable update timer.
Note 1: sometimes the screen may misbehave, i.e. after clicking the "+" button the new "empty" device doesn't show, or the IP field gets duplicated.
Just refresh the page please.
Connecting new device procedure (DIY Mode V2.0 - FW 3.5.0)
No Tasmota And EWeLink Cloud To Control The SONOFF Device? YES!
SONOFF DIY Mode Overview
https://www.youtube.com/watch?v=1TmgJnvtV0s
Steps to switch SONOFF devices to DIY mode - from the above links, but with my own experience:
1. First need to connect the device to eWeLink software to update firmware to 3.5.0
2. Once update is complete - switch the device to "Compatible Pairing Mode (AP)"- Power OFF and ON the device
- Reset by holding the button for 5 seconds (LED changes to 3 flashes with pause)
- Switch to "Compatible Pairing Mode" by holding the button again for 5 seconds (LED changes to constant flash)
Beware: because the AP doesn't have Internet access - Windows PC or mobile phone may switch to another WiFi network automatically.
4. Visits http://10.10.7.1/ and set your WiFi (only 2.4 GHz)
Note 1: The device is ready when the LED changes to two short flashes. You don't need to wait for confirmation.
Note 2: For new Sonoff dimmer D1 paring procedure is slightly different as it doesn't have buttons, use remote instead:
http://developers.sonoff.tech/sonoff...-POST%EF%BC%89
2. Once update is complete - switch the device to "Compatible Pairing Mode (AP)"- First pair the remote with the dimmer
After powering the switch on, long press any button on RM433/4-button 433MHz RF Remote until you hear a “Beep” sound within 5s. - Entering the Compatible Pairing Mode (AP) by long press the paring button for 5 seconds after power on
4. Browser visits http://10.10.7.1/
5. Filling in the existing WiFi network SSID and password. You don't need to wait for confirmation.
Below is the original procedure for older devices with FW 3.3.
You don't need it if you have FW 3.5.0 (see above)
OLD. Connecting new device procedure (FW 3.3.0)
.My plugins:
AK IKEA
AKSquare
AKBond
AKSonoff
AKShelly
AKRemootio
AKEnphaseEnvoy
AKGoogleCast
AKGoogleCalendar
AKSmartDevice
AKHeatmiserNeo
AKTracdown
Great news - Sonoff started a line of devices with local REST control API - they call them Sonoff DIY. The new plugin for Sonoff DIY devices:
https://shop.homeseer.com/products/a...lug-in-for-hs3
Currently Sonoff DIY line includes:.Note 1: The Sonoff DIY firmware is still in active development, so the protocol, instructions, etc. may change often at this stage.
Note 2: The procedure for connecting new DIY device to the WiFi network is for latest firmware version 3.5.0
Note 3: For more info on choosing Zeroconf device discovery and setting Update rate see https://forums.homeseer.com/forum/li...e-update-rates.
Config screen:
Device Config:
Tags: None
- Stuck
- Likes 1
