I'm very interested in this (and in general integration IOT RESTful API WiFi devices into HS) -- thanks for building this!!
I run a setup whereby my HS3 is running strictly CAT6 on an isolated VLAN (ie. WiFi is hardware disabled in the linux config). It has routing to the WiFI VLAN, but it is not the same subnet. I understand the need for mDNS to get it set up, once a static IP has been obtained for the Sonoff device, will this plugin work OK?
Thanks in advance!
Thanks in advance!
