Wireless tags http://wirelesstag.net/ are wireless battery powered sensors for motion, temperature and humidity that are reliable (I'm using them for 3+ years). Coin type batteries last 1+ years.
I'll explain below how to integrate them in HS3 easily using Big5 plug-in.
Each of the sensors can be setup to produce HTTP call like this one (real life example from my sensors) on pre scheduled interval or when temperature changes or motion is detected.
192.168.1.242:84/wireless.asp?temp=25.238101747300856&name=T1&event=0&hilo=1& hum=53.1583251953125
Where temp and hum are temperature and humidity readings event is motion sensing and hilo is reading about temperature crossing two thresholds for low and hi temperature.
All you need to do is go to Big5 setup page and setup http profile like this
Basically you specify the URL address and VERY IMPORTANT the field that will provide the name. This field will be used for naming HS3 devices
Do not check "locked" in the beginning. Let Big5 create your HS3 devices for all sensors first. You may "lock" it thereafter to prevent new devices being created by occasional "noise" or tests you do with different sensors. Check "listen" mode. This is important and distinguishes input vs output modes.
That's all you need to do. Big5 will "listen" to the specified port and will automatically create/update HS3 devices each time it receives the HTTP call from the sensors.
Here is a screenshot of the HS3 devices created (the names of my sensors are T7, T6, T5, etc.
