Integrate Grandstream gds3710 video doorbell
    #61
ID:	1391619Click image for larger version
    No errors but the door does not open. I added the# to the remote pin also. I was wondering about the 0 after the md5 on line 2 of the log if that means anything
      #62
      O.K. the good news is that you've got the split under control now and it is solid updates every time.
      Pls. show a screenshot of your GET profile with the URL scrolled to the rightmost part.
      Also a screenshot of your action box of Big5 HTTP action that is supposed to open the door.
      Last but not least did you do what I asked you to do in p.3 above and what is the result of it (here it is again).
      3. Copy the result from the sandbox and add it to the URL from the Big5 profile replacing ${input} with it. Use the resulting URL in a browser. Does the door open. If yes, than Big5 will open it for you, if not than you have to go back to Grandstream Documentation and see what you are doing wrong.
        #63
ID:	1391640Click image for larger version
        The 3rd item is difficult because i only have 30 seconds to generate the codes and then paste them into the url but so far I dont think I did it right yet.
        I did notice that the line in the above log about "has the right to do this" is not the same result as mentioned in the grandstream instructions I uploaded see [ATTACH]n1391642[/ATTACH]
          #64
          Client âž” Server
          [http|https]://<servername>/goform/apicmd?cmd=1&user=admin&authcode=<authcodes
          tring>&idcode=<idcodestring>&type=opt_type
          This is what the documentation says. Yours is different. For example you have an extra ? after the word admin in the profile. It should be & not ?
            #65
            I made the change thanks Here is the log which looks better but the door did not open. In the instructions it says something about getting "authorization ok" response
            which we are not seeing. And should it be opt_type=1 or just type=1 Thank you I think we are close
              #66
              I said
              "For example you have an extra ? after the word admin in the profile. It should be & not ?"
              which means that it is an example only one of several. There are other mismatches like missing & characters in front of every word.
              Try this expression and make sure no one enters the house when the door opens, which it should do this time around
              ${"authcode="+"md5("+val1229+":2191#:laser)"+"&idcode="+val1 2 30+"&type=1"}
              BEWARE this forum does funky stuff to text not only it introduces curly quotes but also I caught it introducing spaces. Apply cautious and common sense when copy/paste
                #67
                I ran the new expression but it did not open the door. I did notice that even if you click both events very quickly the log show different authenticifation strings.
                If I take out cmd=0 I do get the same string but the door does not open. I tried cmd=1 but it gives an error
                Click image for larger version  Name:	raw.JPG Views:	0 Size:	134.8 KB ID:	1391698
                  #68
                  risquare Use the forum's code tags (marked # in the format menu) when posting your strings. You won't have issues with spaces, changes of characters or emoticons.
                  Just highlight the string you type and press the # button.
                  Example:
                  ${"authcode="+"md5("+val1229+":2191#:laser)"+"&idcode="+val1230+"&type=1"}
                  Jon
                    #69
                    jon00
                    Thanks.
                      #70
                      The get was suppose to have cmd=1 and we had been using cmd=0 like the post but Cmd=1 gives an error
                        #71
                        Here is the latest with the command error using cmd=1 as per grandstream iinstructions
                        If I use cmd=0 I get a different input. If i eliminate cmd totally I do get the same input but no open door
                          #72
                          Do you have any other ideas. I dont think this one is going to work. The authentification process is too complex
                            #73
                            Big5 does what it is supposed to do. You may consider talking to Grandstream support and tell them that you are getting
                            -1Request cmd error
                            and ask them what does that mean and what to do to fix it.
                              #74
                              I would love to see this work too as I have 2 of the gds3710's in service.
                                #75
                                +1
