Doesn't work pls fix I'm a buyer
  • Blade
    Try 2.0.16 and let me know
  • risquare
    Originally posted by Blade View Post
    Can you explain #3 a little more - maybe show me in a screenshot what is wrong
    I can't show you anything now about 3. until 1. is fixed. Once 1. is fixed than you will see two MC1, two MC2, etc. You need to show their S1/S2 affiliation in order to distinguish between them
    Example
    Now.
    MC1 Family room
    MC1 Master bath
    To be.
    MC1 S1 Family Room
    MC1 S2 Master bath
    RISquare
  • Blade
  • risquare
    Originally posted by risquare View Post
    Hi Blade,
    Thanks for the quick response. There is progress as far as BLRadioRA will allow me to select random numbers now, however major problems still stay.
    1. Will NOT allow same numbers for S1 and S2. This is a major problem. For example I have MC 1,2,3,4,5,6,7 in S1 and MC 1,2,3,4,5,6 in S2. BLRadioRA won't let me enter MC1 of S2 after I entered MC1 of S1.
    2. No MC number changes allowed in "edit". This is not a big deal.
    3. The main display does not show system affiliation S1/S2 for each MC. I think this is important and related to 1. above. Once you fix 1. above than the main display will have two 1s two 2s two 3s etc. one for each S1 and S2. This will be confusing.
    RISquare
    Thanks. Please do not forget item 3. as well.
    RISquare
  • Blade
    OK I will have a look - should be an easy fix once I see it in the log
  • risquare
    attached. Also Noticed this error message on the screen
    The following validation error has occurred:
    Master Control number (1) already exists in the plug-in!
  • risquare
    attachment won't upload maybe too large.
    will do it again by deleting the old large file and create a new one.
  • risquare
    1. Turn on debug logging in the plugin on the options page
    2. Capture the issue with adding the MC
    3. Turn off debug logging
    Attach the BLRadioRA-Detailed.log file zipped
    It is in the HS3 root folder
    Attached per your request.
    I created MC1 in S1 called "Family Rm south"
    I attempted to create MC1 in S2 called "Master bath", which failed.
    The debug mode was active all the time so you may see more history.
    RISquare
  • Blade
  • risquare
    Hi Blade,
    RISquare
    Same problems in version .15
    Attempt to add MC1 S1 fails provided that I do have MC1 S2 already in.
    RISquare
    P.S. MC are similar to zones as far as adding S1/S2 functionality. Best is to apply what you did for zones (two columns table) if this is possible at all.
  • Blade
    Try 2.0.15 and let me know
  • risquare
    Hi Blade,
    RISquare
  • Blade
    Try 2.0.14
  • risquare
    Doesn't work as expected
    1. BLRadioRA is still giving MCs sequential numbers regardless of the number I put in the entry box. Even worse it assigned next sequential number 8 after I put in 7 MC from system2 and started doing system 1 starting from MC #1. Instead of MC#1 S1 I got MC #8 S1. Once a number is assigned it can't be changed in the edit menu.
    RISquare
  • Blade
    Try out 2.0.13
    I made the master control number open so you can enter it
