Plugin expired again
    Last night none of my WiFi devices turned off only to find that the plugin expired. Can the expiration date be published so we do not run into this as a surprise. Where do I get the latest plugin?
    -Rupp
    Sorry Rupp, the latest is set to expire at the end of Feb 2020 and you can update from the same place. I will add a log message with the date at each startup, thanks for the suggestion. I am literally just publishing an update as well which speeds startup a bit on later HS builds. Updater file is here: http://download.casapiedrasoftware.i...ates3/CpsTuya/
      Thanks for the fix and the fast response. Do I just grab the latest updater_override.txt file from this link?
      -Rupp
        Yep, just drop the text file in your HS directory and HS will pick it up and make it available to you.
          Got it. Thanks. Any plans to release this so these update can come via the HS3 updater?
          -Rupp
            Back up and running. Thanks.
            -Rupp
              I do, I honestly have not made much progress due to my fighting of an HS internals bug that has rendered my system (and I strongly suspect some others) effectively unusable. Its been on / off issue for about 1.5 years, I finally have source code from Rich for part of the problematic area and am working on permanent fix. Its nasty and manifests itself as all kinds of plugin crashes on larger configurations. Once that is nailed, I should be much more focussed on moving my plugins forward.
                This plugin has expired again. Was an update made to make the plugin work without expiring?
                -Rupp
                  Yes, same updater link has had a newer version since the beginning of the month.
                    Thanks Bill.
                    -Rupp
                      Hi guys, Tuya appeared to quit working on my side today too. I was able to update to the newer version 1.5.1.0, but only one of the three devices that I have setup are working. We use these three lights several times a day so it's weird only one can be controlled. Any advice would be great!
                      BTW thanks so much for this plugin, it is great! Does anyone know of any similar wifi plug-ins that have the old x-10 feature that allows the lamp light switch to be used to turn on the light (like x-10)? That functionality would be super helpful for my family today :-).
                        What status do the devices that aren't working show?
                          I'm not really sure how to check the status. From the device management tab, the working one and not working one look identical but that appears to be all timer stuff. I can say that from the device page, when I click on and off of the broken one it acts like it works with the indicator turning on/off, but nothing happens at the actual device.
                          From the plug-in --> Cps_Tuya config --> Devices, the good and bad ones look identical with green check marks. I can try and re-add the devices if that is what is required, but if you could let me know how to do this without reprogramming them in all my HS3 events, that would be very helpful :-).
                            Please let me know if there is some other way that I should be checking status. I don't think there is anything I can check from the phone app as I was pretty sure that the devices transferred over to the homeseer server.
                            I'm taking heat from the family about but being able to control a couple lights so any help would be great :-).
                              Can you post a screen shot of your devices page with the Tuya device and all of its children?
