I setup Tuya a while back. It was working awesome, then it didn't.
I had issues and tried to uninstall it. Now, it doesn't work at all. If I try to modify the plugins config, I get "Error: An unknown error has occured, please check for an exception file in the HomeSeer directory."
From startup. There are a ton of these.
Warning Issue checking parent device (395) Cps Tuya Cps Tuya Smart Plug, Energy Monitoring
Nov-11 7:08:37 PM Warning Device (396) Cps Tuya Cps Tuya Smart Plug, Energy Monitoring switch_1 is marked as child, but does not reference any parent
N
I was able to setup one test device with the smart life app, so something is working. I remember having to remove the devices from the app in order to load them into HS.
Thanks for the help!
N
