I made a typo when entering the IP address for the broker. I left out a period (.) There does not seem to be any sanity checking for the data being entered.
As a feature request would you consider adding the following checks? All the following fields are required so you should not be able to save unless they are correctly populated.
1. Valid IP address
2. Valid port number in the range 1 to 65535
1. Valid IP address
