Since there are so many things that you can do with the Hubitat Elevation plugin and a Hubitat Hub I thought I'd start a Topic to find out how everyone is using the Hubitat Elevation plugin to get additional ideas on what is possible. For me I am either using or have tested the following and the plugin is creating Homeseer devices for:
Hubitat Hub
1. Zigbee Devices including switches and motion sensors
2. Zwave Devices including switches and motion sensors (tested but using Homeseer for this)
3. Hubitat Integrations Including Rachio, TP-Link (tested but using Homeseer for this)
4. Hubitat Presence Sensor
5. Virtual Devices and Routines using Rule Machine
HubConnect with a Smartthings Hub for the following: (I have a Hubitat Hub Client and Smartthings Hub Client and use them similar to a Homeseer ZNet Zwave Network for Zigbee)
2. Ring
3. Smartthings Presence Sensor
4. Virtual Devices and Routines using Webcore
So there are tons of more possibilities with device drivers and Integrations in Hubitat that can be used with the Hubitat Elevation plugin in Homeseer. What is everyone doing?
Hubitat Hub
2. Ring
