Hubitat Reboot
  • Hubitat Reboot
    When Hubitat reboots it looses a connection to Hubitat until I go in and connect and rescan.
    Otherwise things are out of sync.
    What OS? Windows or Linux?
    The websocket should reconnect within a few minutes of HE coming online again and the EventSocket being available. How long are you waiting after the HE hub reboot?
      Windows 10.
      i gave it like 10 minutes before rescanning under the Hubitat plugin.
      im also having it was having the same issues with the HomeKit maker API for Hubitat.
        Windows 10.
        Interesting. I would say it was possibly a Hubitat issue then if two independent services trying to use the same EvenSocket were both having connection issues until they did a fresh reconnect? I'll take a look and see if there's anything I can do for a workaround or not. I've put a lot of time working around websocket issues with .Net and I'm not sure if there's much more that can be done and if a Node.js process is having issues then there's no hope
          Okay thanks
