I just added one of these thermostats. The Hubitat plugin created only one device - TemperatureMeasurement. Can the additional options be added? I added Maker output and what I see in Hubitat and Homeseer at the end. Thanks.
[{"name":"Amy's iPhone","label":"Amy's iPhone","type":"Mobile App Device","id":"36","date":"2019-10-13T19:47:47+0000","model":null,"manufacturer":null,"capabilities":["PresenceSensor","Sensor","Notification"],"attributes":{"notificationText":null,"dataType":"ENUM","values":["present","not present"],"presence":"not present"},"commands":[{"command":"arrived"},{"command":"departed"},{"command":"deviceNotification"}]},{"name":"AnnaPhone","label":"AnnaPhone","type":"Mobile App Device","id":"6","date":"2019-08-24T14:08:20+0000","model":null,"manufacturer":null,"capabilities":["PresenceSensor","Sensor","Notification"],"attributes":{"notificationText":null,"dataType":"ENUM","values":["present","not present"],"presence":"not present"},"commands":[{"command":"arrived"},{"command":"departed"},{"command":"deviceNotification"}]},{"name":"Breakfast Room Lamp","label":"Breakfast Room Lamp","type":"Generic Zigbee Outlet","id":"12","date":"2019-10-12T20:05:31+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","PowerMeter","Sensor","Actuator","Outlet"],"attributes":{"power":null,"dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Generic Zigbee Bulb","label":"Dad Bedside Light","type":"Generic Zigbee Bulb","id":"35","date":"2019-10-13T17:05:11+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","SwitchLevel","Refresh","Actuator","Light","ChangeLevel"],"attributes":{"level":"99","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"},{"command":"setLevel"},{"command":"startLevelChange"},{"command":"stopLevelChange"}]},{"name":"Aeon Multisensor 6","label":"Dining Room Multi Sensor","type":"Aeon Multisensor 6","id":"41","date":"2019-10-12T00:09:21+0000","model":null,"manufacturer":null,"capabilities":["IlluminanceMeasurement","TemperatureMeasurement","RelativeHumidityMeasurement","Battery","MotionSensor","Configuration","AccelerationSensor","Sensor","UltravioletIndex"],"attributes":{"acceleration":null,"dataType":"NUMBER","values":null,"battery":"56","humidity":"25","illuminance":"0","motion":"active","temperature":"66.4","ultravioletIndex":null},"commands":[{"command":"configure"}]},{"name":"evie\u2019s iphone ","label":"evie\u2019s iphone ","type":"Mobile App Device","id":"37","date":"2019-10-13T20:09:13+0000","model":null,"manufacturer":null,"capabilities":["PresenceSensor","Sensor","Notification"],"attributes":{"notificationText":null,"dataType":"ENUM","values":["present","not present"],"presence":"not present"},"commands":[{"command":"arrived"},{"command":"departed"},{"command":"deviceNotification"}]},{"name":"Device","label":"Garage Door Lights","type":"Generic Zigbee Outlet","id":"38","date":null,"model":null,"manufacturer":null,"capabilities":["Switch","Configuration","PowerMeter","Sensor","Actuator","Outlet"],"attributes":{"power":null,"dataType":"ENUM","values":["on","off"],"switch":null},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Heartbeat","label":"Heartbeat","type":"Virtual Switch","id":"65","date":"2019-10-13T20:10:57+0000","model":null,"manufacturer":null,"capabilities":["Switch","Refresh"],"attributes":{"switch":"on","dataType":"ENUM","values":["on","off"]},"commands":[{"command":"off"},{"command":"on"},{"command":"refresh"}]},{"name":"Fibaro Motion Sensor ZW5","label":"Home Theater Sensor","type":"Fibaro Motion Sensor ZW5","id":"40","date":"2019-10-13T19:22:49+0000","model":null,"manufacturer":null,"capabilities":["IlluminanceMeasurement","TemperatureMeasurement","Battery","MotionSensor","Configuration","ThreeAxis","AccelerationSensor","Refresh","Sensor","TamperAlert"],"attributes":{"acceleration":"inactive","dataType":"VECTOR3","values":null,"battery":"100","illuminance":"16","motion":"inactive","pendingChanges":"0","tamper":"clear","temperature":"72.2","threeAxis":"[x:-2,y:-4,z:8]"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Sinope TH1300ZB Thermostat","label":"Master Bathroom Floor","type":"Sinope TH1300ZB Thermostat","id":"98","date":"2019-10-13T19:55:37+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Configuration","Refresh","Thermostat","Sensor","Actuator"],"attributes":{"coolingSetpoint":null,"dataType":"NUMBER","values":null,"heatingSetpoint":"75","schedule":null,"supportedThermostatFanModes":null,"supportedThermostatModes":null,"temperature":"74.1","thermostatFanMode":null,"thermostatMode":"heat","thermostatOperatingState":"idle","thermostatSetpoint":"75"},"commands":[{"command":"auto"},{"command":"configure"},{"command":"cool"},{"command":"emergencyHeat"},{"command":"fanAuto"},{"command":"fanCirculate"},{"command":"fanOn"},{"command":"heat"},{"command":"off"},{"command":"refresh"},{"command":"setClockTime"},{"command":"setCoolingSetpoint"},{"command":"setHeatingSetpoint"},{"command":"setSchedule"},{"command":"setThermostatFanMode"},{"command":"setThermostatMode"}]},{"name":"2","label":"MasterBedroomDad","type":"Lutron Fast Pico","id":"10","date":"2019-10-13T03:39:35+0000","model":null,"manufacturer":null,"capabilities":["Actuator","PushableButton","ReleasableButton"],"attributes":{"numberOfButtons":"5","dataType":"NUMBER","values":null,"pushed":"5","released":"5"},"commands":[{"command":"push"},{"command":"release"}]},{"name":"3","label":"MasterBedroomMom","type":"Lutron Fast Pico","id":"13","date":"2019-10-13T04:07:12+0000","model":null,"manufacturer":null,"capabilities":["Actuator","PushableButton","ReleasableButton"],"attributes":{"numberOfButtons":"5","dataType":"NUMBER","values":null,"pushed":"5","released":"5"},"commands":[{"command":"push"},{"command":"release"}]},{"name":"4","label":"MasterBedroomWall","type":"Lutron Fast Pico","id":"14","date":"2019-10-13T03:25:39+0000","model":null,"manufacturer":null,"capabilities":["Actuator","PushableButton","ReleasableButton"],"attributes":{"numberOfButtons":"5","dataType":"NUMBER","values":null,"pushed":"1","released":"1"},"commands":[{"command":"push"},{"command":"release"}]},{"name":"Generic Zigbee Bulb","label":"Mom Bedside Light","type":"Generic Zigbee Bulb","id":"34","date":"2019-10-13T17:05:11+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","SwitchLevel","Refresh","Actuator","Light","ChangeLevel"],"attributes":{"level":"100","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"},{"command":"setLevel"},{"command":"startLevelChange"},{"command":"stopLevelChange"}]},{"name":"SimonPhone","label":"SimonPhone","type":"Mobile App Device","id":"1","date":"2019-10-13T01:56:29+0000","model":null,"manufacturer":null,"capabilities":["PresenceSensor","Sensor","Notification"],"attributes":{"notificationText":null,"dataType":"ENUM","values":["present","not present"],"presence":"present"},"commands":[{"command":"arrived"},{"command":"departed"},{"command":"deviceNotification"}]},{"name":"Device","label":"Tessa Bedroom Lights","type":"Generic Zigbee Outlet","id":"15","date":"2019-10-05T18:41:07+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","PowerMeter","Sensor","Actuator","Outlet"],"attributes":{"power":"0","dataType":"ENUM","values":["on","off"],"switch":"on"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Tessa\u2019s iphone","label":"Tessa\u2019s iphone","type":"Mobile App Device","id":"8","date":"2019-10-13T19:47:33+0000","model":null,"manufacturer":null,"capabilities":["PresenceSensor","Sensor","Notification"],"attributes":{"notificationText":null,"dataType":"ENUM","values":["present","not present"],"presence":"not present"},"commands":[{"command":"arrived"},{"command":"departed"},{"command":"deviceNotification"}]}]
