Update 3.0.6.0 Issue
  • Update 3.0.6.0 Issue
    I installed 3.0.6.0 today and with this version I can no longer turn on/off my 3210-L Plug from Homeseer. I still have control with Hubitat itself. Went back to version 3.0.3.0 and can again turn the device on/off from inside Homeseer. Just thought I would let you know
    Can you enable debut on the the plugin config page, control your device from HS, post the debug file at \Data\hubitat or email it to mcsSolutions at CenturyTel dot net.
      I will try and get that information for you tonight when I get home.
        This is what I see when running 3.0.3.0
        11/4/2019 7:21:17 PM 983 | HubitatDevice:[{"name":"Generic Zigbee Outlet","label":"Basement - Outlet","type":"Generic Zigbee Outlet","id":"39","date":"2019-11-04T02:36:30+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Configuration","PowerMeter","Sensor","Actuator","O utlet"],"attributes":{"power":"0","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"}, {"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Bedroom - Motion","type":"Generic Zigbee Motion Sensor","id":"38","date":"2019-11-04T19:18:39+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"68.09"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Furnace - Motion","type":"Generic Zigbee Motion Sensor","id":"66","date":"2019-11-04T23:20:03+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values": null,"motion":"inactive","temperature":"72.79"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Office - Motion","type":"Generic Zigbee Motion Sensor","id":"65","date":"2019-11-05T01:20:58+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"active","temperature":"69.17"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement South - Motion","type":"Generic Zigbee Motion Sensor","id":"1","date":"2019-11-05T01:17:40+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"65.95"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Stairs - Motion","type":"Generic Zigbee Motion Sensor","id":"2","date":"2019-11-05T01:19:28+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"72.92"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Storage - Motion","type":"Generic Zigbee Motion Sensor","id":"67","date":"2019-11-04T21:51:35+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values": null,"motion":"inactive","temperature":"69.68"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement TV - Motion","type":"Generic Zigbee Motion Sensor","id":"3","date":"2019-11-05T01:16:42+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"63.31"},"commands":[{"command":"configure"},{"command":"refresh"}]}]
        11/4/2019 7:21:18 PM 2032 | HubitatDevice:[{"name":"Generic Zigbee Outlet","label":"Basement - Outlet","type":"Generic Zigbee Outlet","id":"39","date":"2019-11-04T02:36:30+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Configuration","PowerMeter","Sensor","Actuator","O utlet"],"attributes":{"power":"0","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"}, {"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Bedroom - Motion","type":"Generic Zigbee Motion Sensor","id":"38","date":"2019-11-04T19:18:39+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"68.09"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Furnace - Motion","type":"Generic Zigbee Motion Sensor","id":"66","date":"2019-11-04T23:20:03+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values": null,"motion":"inactive","temperature":"72.79"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Office - Motion","type":"Generic Zigbee Motion Sensor","id":"65","date":"2019-11-05T01:20:58+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"active","temperature":"69.17"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement South - Motion","type":"Generic Zigbee Motion Sensor","id":"1","date":"2019-11-05T01:17:40+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"65.95"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Stairs - Motion","type":"Generic Zigbee Motion Sensor","id":"2","date":"2019-11-05T01:19:28+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"72.92"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Storage - Motion","type":"Generic Zigbee Motion Sensor","id":"67","date":"2019-11-04T21:51:35+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values": null,"motion":"inactive","temperature":"69.68"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement TV - Motion","type":"Generic Zigbee Motion Sensor","id":"3","date":"2019-11-05T01:16:42+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"63.31"},"commands":[{"command":"configure"},{"command":"refresh"}]}]
        11/4/2019 7:21:19 PM 2963 | HubitatDevice:[{"name":"Generic Zigbee Outlet","label":"Basement - Outlet","type":"Generic Zigbee Outlet","id":"39","date":"2019-11-04T02:36:30+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Configuration","PowerMeter","Sensor","Actuator","O utlet"],"attributes":{"power":"0","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"}, {"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Bedroom - Motion","type":"Generic Zigbee Motion Sensor","id":"38","date":"2019-11-04T19:18:39+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"68.09"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Furnace - Motion","type":"Generic Zigbee Motion Sensor","id":"66","date":"2019-11-04T23:20:03+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values": null,"motion":"inactive","temperature":"72.79"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Office - Motion","type":"Generic Zigbee Motion Sensor","id":"65","date":"2019-11-05T01:20:58+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"active","temperature":"69.17"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement South - Motion","type":"Generic Zigbee Motion Sensor","id":"1","date":"2019-11-05T01:17:40+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"65.95"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Stairs - Motion","type":"Generic Zigbee Motion Sensor","id":"2","date":"2019-11-05T01:19:28+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"72.92"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement Storage - Motion","type":"Generic Zigbee Motion Sensor","id":"67","date":"2019-11-04T21:51:35+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values": null,"motion":"inactive","temperature":"69.68"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Basement TV - Motion","type":"Generic Zigbee Motion Sensor","id":"3","date":"2019-11-05T01:16:42+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"99","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"63.31"},"commands":[{"command":"configure"},{"command":"refresh"}]}]
        11/4/2019 7:21:19 PM 2964 | Switch: off
        11/4/2019 7:21:27 PM 10757 | Message received: {"source":"DEVICE","name":"motion","displayName":"Basemen t Office - Motion","value":"inactive","unit":null,"deviceId":65,"hubId" :null,"locationId":null,"installedAppId":null,"descriptionTe xt":"Basement Office - Motion is inactive"}
        11/4/2019 7:21:38 PM 22498 | SetIOMulti triggered, checking CAPI 'On' on device 1263 controlValue 255
        11/4/2019 7:21:38 PM 22500 | http://192.168.1.9/apps/api/8/device...8-4a5ec73eaa57
        11/4/2019 7:21:39 PM 22789 | Message received: {"source":"DEVICE","name":"switch","displayName":"Basemen t - Outlet","value":"on","unit":null,"deviceId":39,"hubId":null, "locationId":null,"installedAppId":null,"descriptionText":"B asement - Outlet was turned on"}
        11/4/2019 7:21:43 PM 27260 | SetIOMulti triggered, checking CAPI 'Off' on device 1263 controlValue 0
        11/4/2019 7:21:43 PM 27264 | http://192.168.1.9/apps/api/8/device...8-4a5ec73eaa57
        11/4/2019 7:21:43 PM 27511 | Message received: {"source":"DEVICE","name":"power","displayName":"Basement - Outlet","value":"0","unit":"W","deviceId":39,"hubId":null,"l ocationId":null,"installedAppId":null,"descriptionText":null }
        And this is what I get with version 3.0.6.0
        11/4/2019 7:18:12 PM 0 | SetIOMulti triggered, checking CAPI 'On' on device 1263 controlValue 255
        11/4/2019 7:18:12 PM 2 | http://###IP###/apps/api/8/devices/39/on?###Token###
        11/4/2019 7:18:12 PM 7 | SetIoMulti no update from Hubitat device 1263 set to control of 255
        11/4/2019 7:18:16 PM 3901 | SetIOMulti triggered, checking CAPI 'Off' on device 1263 controlValue 0
        11/4/2019 7:18:16 PM 3905 | http://###IP###/apps/api/8/devices/39/off?###Token###
        11/4/2019 7:18:16 PM 3905 | SetIoMulti no update from Hubitat device 1263 set to control of 0
        11/4/2019 7:18:51 PM 39679 | Message received: {"source":"DEVICE","name":"motion","displayName":"Basemen t Stairs - Motion","value":"active","unit":null,"deviceId":2,"hubId":nu ll,"locationId":null,"installedAppId":null,"descriptionText" :"Basement Stairs - Motion is active"}
        11/4/2019 7:19:25 PM 73644 | Message received: {"source":"DEVICE","name":"motion","displayName":"Basemen t Stairs - Motion","value":"inactive","unit":null,"deviceId":2,"hubId": null,"locationId":null,"installedAppId":null,"descriptionTex t":"Basement Stairs - Motion is inactive"}
          Just tried 3.0.6.1 and the outlet works under that version
            Thank you for the info. It confirms that the plugin should ignore status returned on the command acknowledge from Hubitat and only use the device event messages for updates following the initial synchronization.
              Just curious what changed on 3.7.0. I have a Sylvania led light strip that no longer responds to commands from HomeSeer. It works fine in Hubitat
                There is a release notes thread at https://forums.homeseer.com/forum/li...-release-notes
                3.0.6.2 to 3.0.7.0 was the Greenwave powerstrip and final iteration of the ramp rate feature. The debug log from the plugin is what is best to investigate issues. Post or email to mcsSolutions at CenturyTel dot net.
                  Thanks.. I just disabled the plugin and reenabled it and all is well again.
                    It started not working again. Not sure if this log will help or not..
                    11/12/2019 6:40:33 PM 0 | SetIOMulti triggered, checking CAPI 'On' on device 2244 controlValue 255
                    11/12/2019 6:40:33 PM 6 | http://###IP###/apps/api/1155/device...on?###Token###
                    11/12/2019 6:40:50 PM 17096 | Message received: {"source":"DEVICE","name":"schedule","displayName":"Orbit Hose Water Timer","value":"on","unit":null,"deviceId":1537,"hubId":null ,"locationId":null,"installedAppId":null,"descriptionText":n ull}
                    11/12/2019 6:40:50 PM 17096 | Hubitat Device not in Device Map: schedule
                    11/12/2019 6:41:08 PM 35094 | Message received: {"source":"DEVICE","name":"mode","displayName":"Orbit Hose Water Timer","value":"auto","unit":null,"deviceId":1537,"hubId":nu ll,"locationId":null,"installedAppId":null,"descriptionText" :null}
                    11/12/2019 6:41:08 PM 35094 | Hubitat Device not in Device Map: mode
                    11/12/2019 6:41:29 PM 55966 | Message received: {"source":"DEVICE","name":"temperature","displayName":"Hu e Outdoor Motion Sensor","value":"40.86","unit":"\u00b0F","deviceId":1816,"hu bId":null,"locationId":null,"installedAppId":null,"descripti onText":"Hue Outdoor Motion Sensor temperature is 40.86\u00b0F"}
                    11/12/2019 6:41:57 PM 84105 | Message received: {"source":"DEVICE","name":"schedule","displayName":"Orbit Hose Water Timer","value":"on","unit":null,"deviceId":1537,"hubId":null ,"locationId":null,"installedAppId":null,"descriptionText":n ull}
                    11/12/2019 6:41:57 PM 84105 | Hubitat Device not in Device Map: schedule
                    11/12/2019 6:42:08 PM 95074 | Message received: {"source":"DEVICE","name":"illuminance","displayName":"Hu e Motion Sensor Wall","value":"0","unit":"Lux","deviceId":1763,"hubId":null, "locationId":null,"installedAppId":null,"descriptionText":"H ue Motion Sensor Wall illuminance is 0 Lux"}
                    11/12/2019 6:42:15 PM 102095 | Message received: {"source":"DEVICE","name":"mode","displayName":"Orbit Hose Water Timer","value":"auto","unit":null,"deviceId":1537,"hubId":nu ll,"locationId":null,"installedAppId":null,"descriptionText" :null}
                    11/12/2019 6:42:15 PM 102095 | Hubitat Device not in Device Map: mode
                      Heres one from just now.
                      11/13/2019 4:22:18 PM 1 | HubitatDevice:[{"active":true,"id":1,"name":"Day"},{"active":false,"id":2," name":"Evening"},{"active":false,"id":3,"name":"Night"},{"ac tive":false,"id":4,"name":"Away"}]
                      11/13/2019 4:22:19 PM 887 | HubitatDevice:[{"name":"Orbit Hose Water Timer","label":"Orbit Hose Water Timer","type":"Orbit Hose Water Timer","id":"1537","date":"2019-11-10T00:20:39+0000","model":null,"manufacturer":null,"capabili ties":["Battery","Configuration","Refresh","Valve"],"attributes":{"battery":"66","dataType":"ENUM","values":["open","closed"],"mode":"auto","schedule":"on","valve":"closed"},"command s":[{"command":"cancelSchedule"},{"command":"close"},{"command": "configure"},{"command":"delaySchedule"},{"command":"open"}, {"command":"open"},{"command":"refresh"},{"command":"resumeS chedule"},{"command":"waterEveryXDays"},{"command":"waterOnE venDays"},{"command":"waterOnOddDays"}]},{"name":"Water Softener Salt Tank","label":"Water Softener Salt Tank","type":"Salt Tank Device","id":"1701","date":"2019-11-13T20:56:43+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Initialize"],"attributes":{"Salt Level":"6","dataType":"ENUM","values":["on","off"],"SaltTile":"<style>img.salttankImage { max-width:80%;height:auto;}div#salttankImgWrapper {width=100%}div#salttankWrapper {font-size:13px;margin: 30px auto; text-align:center;}</style><div id='salttankWrapper'><div id='salttankImgWrapper'><center><img src='https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/support/images/null' class='saltankImage'></center></div>Salt Level: 25%</div>","delay":null,"distance":"18","dwDriverInfo":"SaltTankD river:1.0.3","switch":"off"},"commands":[{"command":"initialize"},{"command":"off"},{"command":"on"}, {"command":"publishMsg"},{"command":"updateVersion"}]},{"name":"Generic Zigbee Motion Sensor","label":"Bathroom Motion Sensor","type":"Generic Zigbee Motion Sensor","id":"1729","date":"2019-11-13T22:17:33+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"58.46"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Master Bedroom Zigbee Motion Sensor","type":"Generic Zigbee Motion Sensor","id":"1762","date":"2019-11-13T22:13:45+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"75","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"66.35"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Hue Motion Sensor","label":"Hue Motion Sensor Wall","type":"Hue Motion Sensor","id":"1763","date":"2019-11-13T22:13:23+0000","model":null,"manufacturer":null,"capabili ties":["IlluminanceMeasurement","TemperatureMeasurement","Battery", "MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"77","dataType":"NUMBER","values":n ull,"illuminance":"0","motion":"inactive","temperature":"57. 15"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"mZone-Master Bedroom Motion Zone","label":"mZone-Master Bedroom Motion Zone","type":"Motion Zone Motion Sensor","id":"1764","date":"2019-11-13T22:14:00+0000","model":null,"manufacturer":null,"capabili ties":["MotionSensor"],"attributes":{"motion":"inactive","dataType":"ENUM","values ":["inactive","active"]},"commands":[]},{"name":"Generic Zigbee CT Bulb (dev)","label":"Bathroom Light","type":"Generic ZigBee RGBW Light","id":"1815","date":"2019-11-13T14:50:23+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Configuration","SwitchLevel","Refresh","ColorContr ol","Actuator","ColorTemperature","Light","ChangeLevel","Col orMode"],"attributes":{"RGB":null,"dataType":"ENUM","values":["on","off"],"color":null,"colorMode":"RGB","colorName":"Blue","colorTem perature":"2702","hue":"67","level":"45","saturation":"100", "switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"}, {"command":"on"},{"command":"on"},{"command":"refresh"},{"co mmand":"setColor"},{"command":"setColorTemperature"},{"comma nd":"setHue"},{"command":"setLevel"},{"command":"setSaturati on"},{"command":"startLevelChange"},{"command":"stopLevelCha nge"}]},{"name":"Hue Motion Sensor","label":"Hue Outdoor Motion Sensor","type":"Hue Motion Sensor","id":"1816","date":"2019-11-13T22:18:16+0000","model":null,"manufacturer":null,"capabili ties":["IlluminanceMeasurement","TemperatureMeasurement","Battery", "MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"88","dataType":"NUMBER","values":n ull,"illuminance":"128","motion":"inactive","temperature":"4 3.92"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Wet Bar Motion Sensor ","type":"Generic Zigbee Motion Sensor","id":"1827","date":"2019-11-13T21:57:33+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"64.60"},"commands":[{"command":"configure"},{"command":"refresh"}]}]
                      11/13/2019 4:22:20 PM 1874 | HubitatDevice:[{"name":"Orbit Hose Water Timer","label":"Orbit Hose Water Timer","type":"Orbit Hose Water Timer","id":"1537","date":"2019-11-10T00:20:39+0000","model":null,"manufacturer":null,"capabili ties":["Battery","Configuration","Refresh","Valve"],"attributes":{"battery":"66","dataType":"ENUM","values":["open","closed"],"mode":"auto","schedule":"on","valve":"closed"},"command s":[{"command":"cancelSchedule"},{"command":"close"},{"command": "configure"},{"command":"delaySchedule"},{"command":"open"}, {"command":"open"},{"command":"refresh"},{"command":"resumeS chedule"},{"command":"waterEveryXDays"},{"command":"waterOnE venDays"},{"command":"waterOnOddDays"}]},{"name":"Water Softener Salt Tank","label":"Water Softener Salt Tank","type":"Salt Tank Device","id":"1701","date":"2019-11-13T20:56:43+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Initialize"],"attributes":{"Salt Level":"6","dataType":"ENUM","values":["on","off"],"SaltTile":"<style>img.salttankImage { max-width:80%;height:auto;}div#salttankImgWrapper {width=100%}div#salttankWrapper {font-size:13px;margin: 30px auto; text-align:center;}</style><div id='salttankWrapper'><div id='salttankImgWrapper'><center><img src='https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/support/images/null' class='saltankImage'></center></div>Salt Level: 25%</div>","delay":null,"distance":"18","dwDriverInfo":"SaltTankD river:1.0.3","switch":"off"},"commands":[{"command":"initialize"},{"command":"off"},{"command":"on"}, {"command":"publishMsg"},{"command":"updateVersion"}]},{"name":"Generic Zigbee Motion Sensor","label":"Bathroom Motion Sensor","type":"Generic Zigbee Motion Sensor","id":"1729","date":"2019-11-13T22:17:33+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"58.46"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Master Bedroom Zigbee Motion Sensor","type":"Generic Zigbee Motion Sensor","id":"1762","date":"2019-11-13T22:13:45+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"75","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"66.35"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Hue Motion Sensor","label":"Hue Motion Sensor Wall","type":"Hue Motion Sensor","id":"1763","date":"2019-11-13T22:13:23+0000","model":null,"manufacturer":null,"capabili ties":["IlluminanceMeasurement","TemperatureMeasurement","Battery", "MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"77","dataType":"NUMBER","values":n ull,"illuminance":"0","motion":"inactive","temperature":"57. 15"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"mZone-Master Bedroom Motion Zone","label":"mZone-Master Bedroom Motion Zone","type":"Motion Zone Motion Sensor","id":"1764","date":"2019-11-13T22:14:00+0000","model":null,"manufacturer":null,"capabili ties":["MotionSensor"],"attributes":{"motion":"inactive","dataType":"ENUM","values ":["inactive","active"]},"commands":[]},{"name":"Generic Zigbee CT Bulb (dev)","label":"Bathroom Light","type":"Generic ZigBee RGBW Light","id":"1815","date":"2019-11-13T14:50:23+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Configuration","SwitchLevel","Refresh","ColorContr ol","Actuator","ColorTemperature","Light","ChangeLevel","Col orMode"],"attributes":{"RGB":null,"dataType":"ENUM","values":["on","off"],"color":null,"colorMode":"RGB","colorName":"Blue","colorTem perature":"2702","hue":"67","level":"45","saturation":"100", "switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"}, {"command":"on"},{"command":"on"},{"command":"refresh"},{"co mmand":"setColor"},{"command":"setColorTemperature"},{"comma nd":"setHue"},{"command":"setLevel"},{"command":"setSaturati on"},{"command":"startLevelChange"},{"command":"stopLevelCha nge"}]},{"name":"Hue Motion Sensor","label":"Hue Outdoor Motion Sensor","type":"Hue Motion Sensor","id":"1816","date":"2019-11-13T22:18:16+0000","model":null,"manufacturer":null,"capabili ties":["IlluminanceMeasurement","TemperatureMeasurement","Battery", "MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"88","dataType":"NUMBER","values":n ull,"illuminance":"128","motion":"inactive","temperature":"4 3.92"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Wet Bar Motion Sensor ","type":"Generic Zigbee Motion Sensor","id":"1827","date":"2019-11-13T21:57:33+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"64.60"},"commands":[{"command":"configure"},{"command":"refresh"}]}]
                      11/13/2019 4:22:21 PM 2681 | HubitatDevice:[{"name":"Orbit Hose Water Timer","label":"Orbit Hose Water Timer","type":"Orbit Hose Water Timer","id":"1537","date":"2019-11-10T00:20:39+0000","model":null,"manufacturer":null,"capabili ties":["Battery","Configuration","Refresh","Valve"],"attributes":{"battery":"66","dataType":"ENUM","values":["open","closed"],"mode":"auto","schedule":"on","valve":"closed"},"command s":[{"command":"cancelSchedule"},{"command":"close"},{"command": "configure"},{"command":"delaySchedule"},{"command":"open"}, {"command":"open"},{"command":"refresh"},{"command":"resumeS chedule"},{"command":"waterEveryXDays"},{"command":"waterOnE venDays"},{"command":"waterOnOddDays"}]},{"name":"Water Softener Salt Tank","label":"Water Softener Salt Tank","type":"Salt Tank Device","id":"1701","date":"2019-11-13T20:56:43+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Initialize"],"attributes":{"Salt Level":"6","dataType":"ENUM","values":["on","off"],"SaltTile":"<style>img.salttankImage { max-width:80%;height:auto;}div#salttankImgWrapper {width=100%}div#salttankWrapper {font-size:13px;margin: 30px auto; text-align:center;}</style><div id='salttankWrapper'><div id='salttankImgWrapper'><center><img src='https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/support/images/null' class='saltankImage'></center></div>Salt Level: 25%</div>","delay":null,"distance":"18","dwDriverInfo":"SaltTankD river:1.0.3","switch":"off"},"commands":[{"command":"initialize"},{"command":"off"},{"command":"on"}, {"command":"publishMsg"},{"command":"updateVersion"}]},{"name":"Generic Zigbee Motion Sensor","label":"Bathroom Motion Sensor","type":"Generic Zigbee Motion Sensor","id":"1729","date":"2019-11-13T22:17:33+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"58.46"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Master Bedroom Zigbee Motion Sensor","type":"Generic Zigbee Motion Sensor","id":"1762","date":"2019-11-13T22:13:45+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"75","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"66.35"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Hue Motion Sensor","label":"Hue Motion Sensor Wall","type":"Hue Motion Sensor","id":"1763","date":"2019-11-13T22:13:23+0000","model":null,"manufacturer":null,"capabili ties":["IlluminanceMeasurement","TemperatureMeasurement","Battery", "MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"77","dataType":"NUMBER","values":n ull,"illuminance":"0","motion":"inactive","temperature":"57. 15"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"mZone-Master Bedroom Motion Zone","label":"mZone-Master Bedroom Motion Zone","type":"Motion Zone Motion Sensor","id":"1764","date":"2019-11-13T22:14:00+0000","model":null,"manufacturer":null,"capabili ties":["MotionSensor"],"attributes":{"motion":"inactive","dataType":"ENUM","values ":["inactive","active"]},"commands":[]},{"name":"Generic Zigbee CT Bulb (dev)","label":"Bathroom Light","type":"Generic ZigBee RGBW Light","id":"1815","date":"2019-11-13T14:50:23+0000","model":null,"manufacturer":null,"capabili ties":["Switch","Configuration","SwitchLevel","Refresh","ColorContr ol","Actuator","ColorTemperature","Light","ChangeLevel","Col orMode"],"attributes":{"RGB":null,"dataType":"ENUM","values":["on","off"],"color":null,"colorMode":"RGB","colorName":"Blue","colorTem perature":"2702","hue":"67","level":"45","saturation":"100", "switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"}, {"command":"on"},{"command":"on"},{"command":"refresh"},{"co mmand":"setColor"},{"command":"setColorTemperature"},{"comma nd":"setHue"},{"command":"setLevel"},{"command":"setSaturati on"},{"command":"startLevelChange"},{"command":"stopLevelCha nge"}]},{"name":"Hue Motion Sensor","label":"Hue Outdoor Motion Sensor","type":"Hue Motion Sensor","id":"1816","date":"2019-11-13T22:18:16+0000","model":null,"manufacturer":null,"capabili ties":["IlluminanceMeasurement","TemperatureMeasurement","Battery", "MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"88","dataType":"NUMBER","values":n ull,"illuminance":"128","motion":"inactive","temperature":"4 3.92"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Motion Sensor","label":"Wet Bar Motion Sensor ","type":"Generic Zigbee Motion Sensor","id":"1827","date":"2019-11-13T21:57:33+0000","model":null,"manufacturer":null,"capabili ties":["TemperatureMeasurement","Battery","MotionSensor","Configura tion","Refresh","Sensor"],"attributes":{"battery":"87","dataType":"NUMBER","values":n ull,"motion":"inactive","temperature":"64.60"},"commands":[{"command":"configure"},{"command":"refresh"}]}]
                        And now its back to working fine again. I can turn the light on and off from homeseer. Crazy light..
                          It is better to attach files than pasting text. If text is pasted then enclose it in code tags so it does not get reformatted as HTML.
                          The following is a HS control that resulted in sending "on" command to hubitat device "1155". There was no response from hubitat. The next input from hubitat was 17 seconds later about Orbit Hose water and that device was not mapped into a HS device.
                          In the second posting it showed the devices that MakerAPI reported as being available from Hubitat.
                          These are "Orbit Hose Water Timer", "Water Softener Salt Tank", "Generic Zigbee Motion Sensor", "Generic Zigbee Motion Sensor", "mZone-Master Bedroom Motion Zone", "Generic Zigbee CT Bulb (dev)", "Hue Motion Sensor", and "Generic Zigbee Motion Sensor". I assume your Sylvania is the Bulb and Hubitat reports it as being device "1815". There were no Hubitat device "1155" in the list.
                          The question becomes where did the plugin get device "1155". I looked at the code and see that at startup the plugin looks in \Config\hubitat-devicemap.json to restore the prior state. This is the mapping of Hubitit IDs (start of line until _) and HS Device Ref (end of line). It will take some more research to understand under what conditions this file gets updated. For your particular problem the Bulb needs to be 1815 rather than 1155 in this file when the plugin starts. You should be able to edit this file to achieve this objective. This is only a short term solution as we need to understand why Hubitat no longer uses 1155 and how proper sync will not get us in this situation again.
                          It could be the case that your prior restart of the plugin did achieve a proper resync, but Hubitat again changed the ID. This is an investigation than you need to do on your side now that there is an understanding of what is happening.
