[BUG] Device String line break causes Hubitat's Echo Speaks app to crash *logs*
    Michael McSharry -- hopfully this is an easy fix.
    I found out why I was having really inconsistent results on speaking text. Hubitat app was crashing (logs below). After 1.5 hrs of troubleshooting / trying everything, I determined my device string has a line break in it and when you send that to Hubitat... boom.
    I made notes on a few log lines. Took be a while since I set the Device String (to speak) using text pulled from another Homeseer device, which had a line break.
    Hubitat crashes and it seems to loop for a while trying to process it or something. Its dead until the system resets/stops erroring on its own (takes about 25 min) or you reboot the Hubitat.
    SpeakCommand = working proper
    speechCmd = bad
    dev:82021-01-17 05:10:50.922 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (Greg Unlocked) | Runtime: (4 sec) | QueueItems: (0)   ***  worked correctly; text puleld from device without line break
    dev:82021-01-17 05:10:35.153 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (Greg Unlocked) | Runtime: (4 sec) | QueueItems: (0)
    dev:132021-01-17 05:09:45.198 pm info Socket (v3.3.1.1) | Alexa WS Connection is Open
    dev:132021-01-17 05:09:16.495 pm infoinitialize() called
    dev:132021-01-17 05:06:48.837 pm warn Socket (v3.3.1.1) | WebSocket connection closing.     *** rebooted Hubitat
    dev:82021-01-17 05:06:45.743 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 05:06:41.703 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 05:06:37.681 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 05:06:33.637 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    ******GOES ON FOR A WHILE******
    dev:82021-01-17 04:51:04.343 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:51:00.317 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:50:54.198 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:50:47.173 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:50:43.151 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:50:39.144 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null     *** crash : text sent from HS3 event
    dev:82021-01-17 04:48:44.059 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (test) | Runtime: (4 sec) | QueueItems: (0)    ***  worked correctly; text entered manually & device Submit button clicked
    dev:82021-01-17 04:46:52.121 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:46:48.085 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:46:44.034 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:34:48.888 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:34:44.827 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:34:40.821 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null   *** crash : text sent from HS3 event
    dev:82021-01-17 04:34:29.345 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (test) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 04:33:57.852 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 04:26:23.237 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:26:19.184 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:26:15.113 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    ******GOES ON FOR A WHILE******​​​​​​​
    dev:82021-01-17 04:17:48.738 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:17:42.572 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:17:38.587 pm errorEcho (v3.6.4.1) | speechCmd | Status: (400) | Message: Bad Request | Data: null
    dev:82021-01-17 04:17:21.099 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (testing) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 04:01:52.181 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (take a shower smelly lady) | Runtime: (3 sec) | QueueItems: (0)
    dev:82021-01-17 03:58:56.279 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (take a shower smelly lady) | Runtime: (3 sec) | QueueItems: (0)
    dev:82021-01-17 03:58:49.970 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (take a shower smelly lady) | Runtime: (3 sec) | QueueItems: (0)
    dev:82021-01-17 01:28:54.801 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (take a shower smelly lady) | Runtime: (3 sec) | QueueItems: (0)
    dev:82021-01-17 01:26:45.475 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (lift that ***) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 01:25:52.667 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (nice job mom... so proud of you) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 01:25:34.525 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (good workout) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 01:24:56.629 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    app:42021-01-17 11:24:45.226 am info EchoApp (v3.6.4.4) | wakeupServer Completed... | Process Time: (10697ms) | Source: (healthCheck)
    dev:82021-01-17 11:18:36.420 am info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 11:18:25.885 am info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 11:18:18.529 am info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 11:17:55.589 am info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-17 11:17:43.822 am info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:132021-01-17 11:16:04.300 am info Socket (v3.3.1.1) | Alexa WS Connection is Open
    dev:132021-01-17 11:15:41.699 am infoinitialize() called
    dev:82021-01-16 10:48:13.653 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (Hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-16 10:48:06.309 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (Hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-16 10:47:58.934 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (Hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-16 10:47:50.232 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (hi) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-16 10:47:40.815 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (hi) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-16 10:43:20.757 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    dev:82021-01-16 10:42:33.849 pm info Echo (v3.6.4.1) | SpeakCommand Sent | (hello) | Runtime: (4 sec) | QueueItems: (0)
    I can filter out the CR and LF in the plugin if you think that will help.
      Please. If you replace them with a space, it would stop the Hubitat plugin from crashing. I'm wondering if all escape code/characters will crash it. I didnt test others but it might be best to remove any non-standard characters?
        See if the attached helps. Replaced CR, LF and TAB with space.
          I tested a ton of variations. Hubitat no longer crashes with your latest mods. Please see my below test results. Maybe there are some easy mods to remove some other characters causing it to not speak. Like... ? / # ,
          I will also open an issue with the Hubitat app now that we know what the issues are. thx for maintaining this -- ypur PI is the only reason I bought the Hubitat!
          No Audio spoken, but did not crash Hubitat...
          testing?
          3 #
          1/18/2021
           Offline For 9 mins, 19 secs *** Note: space is the first character (see below on what worked for more)
          Offline For 9 mins, 19 secs *** Note: NO space is the first character
          0 m/s^2
          1260, E South Boulder Rd, Lafayette, Boulder County, Colorado, 80026, USA
          https://www.google.com/maps/search/?api=1&query=39.9867186,-105.0729787
          9 mins, 19 secs
          https://
          1260,
          1/18
          /12
          maps/search
          Boulder County, Colorado **Note: comma is a problem - see below
          ?api
          &query ******* This triggers an odd voice command for skills
          ?api
          Worked fine...
          -105.0729787°
          8:53:23 AM
          9 mins
           Offline For                    *** Note: space is the first character - this worked but the larger version above did not
          www.google.com
          80026 USA **Note: NO comma
          Boulder County Colorado
          https
          https:
            I can remove all non-alpha and non-number characters as well as remove leading and trailing white space. Normally speech engines handle comma and period to provide a pause in the speech, but if Hubitat cannot handle it then should not be included.
              ! works but # ? and others seem not to
                In the attached I have changed CR, LF, TAB to space and removed other non-alpha/non-numeric.
                  A few quirks...
                  A) any non-alphanumberic (&, # , ?) on its own causes the PI to send status text from the 'volume' device in that room - and Echo Speaks speaks the volume number.
                  B) 1/18 becomes 118 instead of 1 18
                  C) 1/18/2021 becomes 1 million 180 2021
                  D) 39.9867186,-105.0729787 becomes one huge number
                  Also, can you exclude ! and the - sign from being removed? they worked fine previously
                    Rather than iterating this can you provide the list of characters you want removed, those you want to converted to space and any other special case that should be processed?
                      In the attached I have implemented the following. Edit the removables and replaceables strings as you find appropriate. The empty string response is now "nothing".
                      string Speakable(string sText)
                      // keep 0-9 A-Z, a-z  space and . ! - /
                      string[] removables = new[] { "\"", "$", "%", "&","'", "(", ")", "*", "+", ",", "/", ":", ";", "<", ">", "?", "@", "[", "\\","]","^", "`", "{","|","}","~" };
                      string[] replaceables = new[] { "\n", "\r", "\t", "_"};
                      string rxString = string.Join("|", removables.Select(s => Regex.Escape(s)));
                      string text = Regex.Replace(sText, rxString, string.Empty);
                      rxString = string.Join("|", replaceables.Select(s => Regex.Escape(s)));
                      text = Regex.Replace(text, rxString, " ");
                      if (text == "") text = "nothing";
                      return text;
                        Sorry, it was necessary. Your first update fixed the crashing that didnt allow me to test the characters until after that stopped. I have not tested all non-alphas. I'll try to get time for that in the next few days.
                        based on my prior test comments...
                        ...I dont know how to fix this, or what causes it. I suspect I'll need to test more after we update for the below items.
                        ... Looks like the 'slash' should be replaced with 'space'
                        ... Looks like the 'comma' should be replaced with 'space'
                          The ! and - are not in either of the two lists so they are left alone. The slash can be moved to the replaceable list.
                            I did the / to space in (13). I see I forgot to post the other (12). They are attached here.
                              Tested...
                              not working...
                              @ * , $ % ^ & ? + | " ; : { } [ ] .. by themselves, they all make it speak the word "nothing". Wondering if you leave them (not remove them) add a space before and after, if it will speak the name of the character, like the ones below? I think that might be best - instead of removing them?
                              # no speaking
                              / no speaking
                              working...
                              = "equals"
                              ! "exclamation mark"
                              - "dash"
                              . "dot"
                              &query "query" (no longer triggers an odd voice command for skills)
                              https:// "https"
                              1/18/2021 "1 18 2021"
