Hi Mike,
I have just started moving my z-wave locks over to Hubitat due to poor performance on homeseer. Not all of the functions are showing up in homeseer. Here is the information on the device, the screen shot from Hubitat and also from Homeseer.
Is it possible to get the lock functions added? I am using two devices here. The first is the standard lock device. The second is a custom device handler called Reliable Lock. It is an incredible lock handler that monitors when the lock is not responding properly and reissues commands to it. It is a life saver. Thanks.
{"name":"Generic Z-Wave Lock","label":"Basement Door Lock","type":"Generic Z-Wave Lock","id":"1186","date":"2021-04-16T02:56:31+0000","model":null,"manufacturer":null,"capabili ties":["Configuration","LockCodes","Actuator","Refresh","Batter y"," Lock","Sensor"],"attributes":{"battery":"90","dataType":"ENUM","values":["added","changed","deleted","failed"],"codeLength":null,"lastCodeName":null,"lock":"locked","l ock Codes":"{"2":{"code":"1111","name":"Guest"},"1": {"name":"Family","code":"2222"}}","maxCodes":"30","codeCh ang ed":"added"},"commands":[{"command":"configure"},{"command":"deleteCode"},{"comman d": "getCodes"},{"command":"lock"},{"command":"refresh"},{"c omma nd":"setCode"},{"command":"setCodeLength"},{"command":"unl oc k"}]}
{"name":"Reliable-Basement Door Lock","label":"Reliable Basement Door Lock","type":"Reliable Lock Virtual Device","id":"1249","date":"2021-04-15T19:56:31+0000","model":null,"manufacturer":null,"capabili ties":["Lock","Actuator","Refresh","Battery","Sensor"],"attributes":{"battery":"90","dataType":"ENUM","values":["locked","unlocked with timeout","unlocked","unknown"],"lock":"locked"},"commands":[{"command":"lock"},{"command":"markAsLocked"},{"command": "ma rkAsUnlocked"},{"command":"refresh"},{"command":"setBattery" },{"command":"unlock"}]}
