MakerAPI Url does not update
    Due to change of IP, I need to update the MakerAPI Url in the setting. Unfortunately, the new Url does not update and remains the same. Is there a way to remove previous Url or is there a solution how to force update the old Url? Hoop someone can assist me. Many thanks in advance.
    Don't know why it will not save from config screen. The URL is saved in HS subfolder \Config\hubitat.ini for HS3 or \Config\mcsHubitat.ini for HS4. You can disable the plugin, manually edit this file and then start the plugin
