I'm getting started on replacing my Insteon network with Zigbee and just got a Hubitat Elevation C7 and some generic outlets to play with. I've plugged one of the outlets in and can control it from the Hubitat's UI.
I then followed the instructions for getting the mcsHubitat plug-in configured and I can see the outlet device in HS4.
If I control the outlet from the native Hubitat UI, I can see its status change in HomeSeer, but if I click the "on" and "off" buttons for the Homeseer device, nothing happens. I've triple-checked that I followed all of the instructions correctly, so I'm not sure what's going on.
Versions are:
mcsHubitat: 4.4.4.2
Hub platform: 2.3.1.142
I also see in the instructions that A log of bidirectional communication between HS and Hubitat can be collected in the file “habitat_debug.txt”, but I can't find a way to enable this logging, and I assume I have to enable it because that file is currently not being created.
And one last question... I see that the devices found by this plug-in get "HE1-" prepended to their names in HomeSeer. Is there some way to turn that off so I just have the bare device name from the HE?
Thanks.
Versions are:
mcsHubitat: 4.4.4.2
Thanks.
