Plugin showing zero effects
    Spud I seem to be missing the master effects. It looks like the plugin is finding and connecting to the raspberry.
    DEBUG Reply {"info":{"activeEffects":[],"activeLedColor":[],"adjustment":[{"blueAdjust":[0,0,255],"greenAdjust":[0,255,0],"id":"default","redAdjust":[255,0,0]}],"correction":[{"correctionValues":[255,255,255],"id":"default"}],"effects":[],"hostname":"raspberrypi","hyperion_build":[{"time":"Apr 5 2018 01:57:21","version":"V1.03.4 (brindosch-c750c41/dc6a602-1522918225"}],"priorities":[{"duration_ms":121,"priority":900},{"priority":990}],"temperature":[{"correctionValues":[255,255,255],"id":"default"}],"transform":[{"blacklevel":[0.0,0.0,0.0],"gamma":[1.0,1.0,1.0],"id":"default","luminanceGain":1.0,"luminanceMinimum":0.0," saturationGain":1.0,"saturationLGain":1.0,"threshold":[0.0,0.0,0.0],"valueGain":1.0,"whitelevel":[1.0,1.0,1.0]}]},"success":true}
    Sep-30 10:32:49 AM Hyperion DEBUG Command {"command":"serverinfo"}
    Sep-30 10:32:49 AM Plug-In Finished initializing plug-in Hyperion
    Sep-30 10:32:49 AM Starting Plug-In Hyperion loaded in 9752 milliseconds
    Sep-30 10:32:49 AM Starting Plug-In Plugin Hyperion started successfully in 8991 milliseconds
    Sep-30 10:32:49 AM Hyperion INFO Get server info
    Sep-30 10:32:40 AM Hyperion INFO Hyperion version 3.0.0.9
    Sep-30 10:32:40 AM Starting Plug-In Initializing plugin Hyperion ...
    the raspberry pi is reporting zero effects installed:
    "effects":[]
      at what path does the plugin look for the effects spud. I did notice a folder with the effect files at user/share/hyperion/effects
        the plugin does not look for the effects directly, the hyperion server is supposed to publish them in the "serverinfo" response.
        do you have some files in /usr/share/hyperion/effects ?
        check that the effect path is correct in your hyperion config file: https://hyperion-project.org/threads...ects-path.186/
