New Insteon Motion Sensor II...beta support available in the Updater
This topic is closed.
  • Just did. Exactly the same result.
    • can you post the hs log snippet of the 'add device' transaction
      Mark
      HS3 Pro 3.0.0.534
      • This one? "Motion Sensor Trap" is an original Motion Sensor, "The Device Type is not.." is version II.
        Log MotionSensor II
        • can you look through the hs log when you added the motion sensor to the plugin. there should be a log entry that reports the 4 digit device type code
          it should be one of the following "1001", "1004", "1005"
          also check the insteon.ini for the [device x] section for devicetype= entry
          Mark
          HS3 Pro 3.0.0.534
          • I let the plugin make an error log file and found an unknown device type 1017 with the Insteon ID of the sensor:
            Click image for larger version  Name:	Insteon error report.png Views:	0 Size:	445.5 KB ID:	1351483
            In the Insteon.ini file I only found DeviceType=1004. This is the original motion sensor.
            • Maybe 1017 is the device type of the European variant?
              • I have posted beta 3.0.7.17 in the Updater. Please shutdown the plugin, update to this version, and then register your devices.
                Mark
                HS3 Pro 3.0.0.534
                • The device was recognized but could not be read. See attached log.
                  • How many devices do you have registered with the plugin using the Hub?
                    The hub seems like its the one having troubles. every message it receives begins with the following which is garage as far as I can tell:
                    "803C3C050021000038000000000000000000000000CF06"
                    do you have any insteon devices that have an ID similar to any 6 digits above?
                    Either way, please run the 'reset and reprogram interface' from the config page. this will clear the hub database, and reprogram it. then manually factory reset the MS II, and register it.
                    Mark
                    HS3 Pro 3.0.0.534
                    • I have 38 devices registered at the hub 24 Insteon, 14 X10
                      Hub 4.8A Build Feb 08 2013
                      PLM version 9C
                      No device ID with any digits resembling anything in the string.
                      Result 'reset and reprogram interface': The PLM did not reset properly. Please try again.
                      Reset motion sensor: No result.
                      After 'Update programming on all new and updated devices' and relocating the motion sensor away from the Hub so it needed an extra hop suddenly the device is recognised and added to the 'Registered Insteon Devices'.
                      The only problem I can see right now is a temperature of 121.6 although I set the unit to Celsius.
                      • you might still try a manual factory reset on the hub, if you still encounter problems. the temp will correct on the next reading.
                        Mark
                        HS3 Pro 3.0.0.534
                        • It seems only one link is set to the motion sensor. The interface reports there are 6 but it stops linking after the first. Maybe this is a problem.
                          Final links:
                          Link #3 Occupancy Sensor controls Badkamer Badkamer Load (45.E3.7A)
                          Link #1 Occupancy Sensor has local control reporting to HomeSeer
                          Link #2 Unknown Group/Button Name #255 has local control reporting to HomeSeer
Name:	Motion sensor.png
                          • i would manually factory reset the MS, and then use the plugin to run the "program device for homeseer" routine. do not remove the device from the plugin.
                            Mark
                            HS3 Pro 3.0.0.534
                            • The last suggestion did the trick. Now I have all links, have received temperature, light level, hearthbeat and of course occupancy. Thanks for the help.
                              • glad you got it working. thanks for reporting back.
                                Mark
                                HS3 Pro 3.0.0.534
                                Unconfigured PHP Module
