Lately I've been having issues with devices not updating HS and missed messages.
I get quite a few of these every day. There had been zero changes in HS and my network. no new electronics..etc.
..Retry #1 required. Pausing 250ms for Hub to clear...
Transmit failed to device Kitchen Island
**Internal transmit attempt failed
Did not get any status response from 2B.CB.6F after 5 tries
Here's a log for the 1 minute or so time frame
Aug-05 11:11:25 PM Insteon ..Finished Scheduled Polling for 2 devices.
Aug-05 11:11:24 PM Insteon Setting status and value for device 2B.CB.6F:1. Old status:35 Old Value:35, New Status:17 New Value: 0
Aug-05 11:11:24 PM Insteon Did not get any status response from 2B.CB.6F after 5 tries. No change to database delta value.
Aug-05 11:11:24 PM Insteon Transmit failed to device Kitchen Island (2B.CB.6F) for cmd 00 00 00 2B CB 6F 0F 19 00 after 5 tries.
Aug-05 11:11:24 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 2B CB 6F 0F 19 00
Aug-05 11:11:24 PM Insteon PLMBuffer_Clean - Cleared 34 7C AA 45 4E D7 23 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E to locate next possible STX
Aug-05 11:11:24 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:24 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
Aug-05 11:11:24 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:24 PM Insteon ..My XML buffer begins with: 15151515025C347CAA454ED7232E
Aug-05 11:11:23 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:23 PM Insteon ..Retry #2 required. Pausing 300ms for Hub to clear...
Aug-05 11:11:23 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
Aug-05 11:11:23 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:23 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:23 PM Insteon ..My XML buffer begins with: 15151515
Aug-05 11:11:22 PM Insteon Setting value for 34.7C.AA:5
Aug-05 11:11:22 PM Insteon Did not receive a response from Master Bedroom Deck Keypad (34.7C.AA). Try #5 failed.
Aug-05 11:11:22 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:22 PM Insteon ..Retry #1 required. Pausing 250ms for Hub to clear...
Aug-05 11:11:22 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:22 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A to locate next possible STX
Aug-05 11:11:22 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:22 PM Insteon ..My XML buffer begins with: 1515151515
Aug-05 11:11:21 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:21 PM Insteon Sending command 02 62 2B CB 6F 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:21 PM Insteon ..Got Hub Response 02 62 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01 06
Aug-05 11:11:21 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E to locate next possible STX
Aug-05 11:11:21 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:21 PM Insteon ..My XML buffer begins with: 0262347CAA1F2E000009C8000000000000000000000106
Aug-05 11:11:21 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 2B CB 6F 0F 19 00
Aug-05 11:11:20 PM Insteon Sending http://192.168.1.123:25105/3?0262347...0000000001=I=3
Aug-05 11:11:20 PM Insteon Sending command 02 62 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:20 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 2B CB 6F 0F 19 00
Aug-05 11:11:20 PM Insteon PLMBuffer_Clean - Cleared 34 7C AA 45 4E D7 23 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E to locate next possible STX
Aug-05 11:11:20 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
Aug-05 11:11:20 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:20 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:20 PM Insteon ..My XML buffer begins with: 15151515025C347CAA454ED7232E
Aug-05 11:11:19 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01
Aug-05 11:11:19 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:19 PM Insteon ..Retry #2 required. Pausing 300ms for Hub to clear...
Aug-05 11:11:19 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
Aug-05 11:11:19 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:19 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:19 PM Insteon ..My XML buffer begins with: 15151515
Aug-05 11:11:18 PM Insteon Did not receive a response from Master Bedroom Deck Keypad (34.7C.AA). Try #3 failed.
Aug-05 11:11:18 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:18 PM Insteon ..Retry #1 required. Pausing 250ms for Hub to clear...
Aug-05 11:11:18 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A to locate next possible STX
Aug-05 11:11:18 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:18 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:18 PM Insteon ..My XML buffer begins with: 1515151515
Aug-05 11:11:17 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:17 PM Insteon Sending command 02 62 2B CB 6F 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:17 PM Insteon ..Got Hub Response 02 62 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01 06
Aug-05 11:11:17 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E to locate next possible STX
Aug-05 11:11:17 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:17 PM Insteon ..My XML buffer begins with: 0262347CAA1F2E000009C8000000000000000000000106
Aug-05 11:11:17 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 2B CB 6F 0F 19 00
Aug-05 11:11:16 PM Insteon Sending http://192.168.1.123:25105/3?0262347...0000000001=I=3
Aug-05 11:11:16 PM Insteon Sending command 02 62 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:16 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 2B CB 6F 0F 19 00
Aug-05 11:11:16 PM Insteon PLMBuffer_Clean - Cleared 34 7C AA 45 4E D7 23 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E to locate next possible STX
Aug-05 11:11:16 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:16 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
Aug-05 11:11:16 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:16 PM Insteon ..My XML buffer begins with: 15151515025C347CAA454ED7232E
Aug-05 11:11:15 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01
Aug-05 11:11:15 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:15 PM Insteon ..Retry #2 required. Pausing 300ms for Hub to clear...
Aug-05 11:11:15 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
Aug-05 11:11:15 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:15 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:15 PM Insteon ..My XML buffer begins with: 15151515
Aug-05 11:11:14 PM Insteon Did not receive a response from Master Bedroom Deck Keypad (34.7C.AA). Try #1 failed.
Aug-05 11:11:14 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:14 PM Insteon ..Retry #1 required. Pausing 250ms for Hub to clear...
Aug-05 11:11:14 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
Aug-05 11:11:14 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:14 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:14 PM Insteon ..My XML buffer begins with: 15151515
Aug-05 11:11:13 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:13 PM Insteon Sending command 02 62 2B CB 6F 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:13 PM Insteon ..Got Hub Response 02 62 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01 06
Aug-05 11:11:13 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E to locate next possible STX
Aug-05 11:11:13 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:13 PM Insteon ..My XML buffer begins with: 0262347CAA1F2E000009C8000000000000000000000106
Aug-05 11:11:12 PM Insteon Sending http://192.168.1.123:25105/3?0262347...0000000001=I=3
Aug-05 11:11:12 PM Insteon Attempting to update the status for Kitchen Island (2B.CB.6F)
Aug-05 11:11:12 PM Insteon Requesting Insteon status (Polling) for device Kitchen Island (2B.CB.6F)
Aug-05 11:11:12 PM Insteon Process ACK Message for device Family Room Keypad 1 (3D.87.61)
Aug-05 11:11:12 PM Insteon Timed poll for Insteon device Kitchen Island (2B.CB.6F), Last contact 8/5/2017 11:11:02 PM. Polling interval of 0 min. reached, polling...
Aug-05 11:11:12 PM Insteon Received a Direct ACK from Family Room Keypad 1 (3D.87.61): 3D 87 61 45 4E D7 2F 2E 00
Aug-05 11:11:12 PM Insteon Sending command 02 62 34 7C AA 1F 2E 00 00 09 C8 00 00 00 00 00 00 00 00 00 00 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:12 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 to locate next possible STX
Aug-05 11:11:12 PM Insteon ..Got Hub Response 02 62 3D 87 61 1F 2E 00 00 09 E4 00 00 00 00 00 00 00 00 00 00 E5 06
Aug-05 11:11:12 PM Insteon Received STX 0x50 (Raw Insteon Rec):3D 87 61 45 4E D7 2F 2E 00
Aug-05 11:11:12 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:12 PM Insteon ..My XML buffer begins with: 02623D87611F2E000009E400000000000000000000E50602503D8761454E D72F2E
Aug-05 11:11:11 PM Insteon Sending http://192.168.1.123:25105/3?02623D8...00000000E5=I=3
Aug-05 11:11:11 PM Insteon Checking for keypadlinc button sync on device 34.7C.AA src index 1, SrcIsSyncTarget=False...
Aug-05 11:11:11 PM Insteon Setting status and value for device 34.7C.AA:1. Old status:0 Old Value:0, New Status:3 New Value:0
Aug-05 11:11:11 PM Insteon Sending command 02 62 3D 87 61 1F 2E 00 00 09 E4 00 00 00 00 00 00 00 00 00 00 E5 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:11 PM Insteon Checking for keypadlinc button sync on device 34.7C.AA src index 5, SrcIsSyncTarget=True...
Aug-05 11:11:11 PM Insteon Process ACK Message for device Master Bedroom Deck Keypad (34.7C.AA)
Aug-05 11:11:11 PM Insteon Setting status and value for device 34.7C.AA:5. Old status:0 Old Value:0, New Status:3 New Value:0
Aug-05 11:11:11 PM Insteon Received a Direct ACK from Master Bedroom Deck Keypad (34.7C.AA): 34 7C AA 45 4E D7 2F 14 C8
Aug-05 11:11:11 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Aug-05 11:11:11 PM Insteon ..Got Hub Response 02 62 34 7C AA 0F 19 01 06
Aug-05 11:11:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):34 7C AA 45 4E D7 2F 14 C8
Aug-05 11:11:11 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:11 PM Insteon ..My XML buffer begins with: 0262347CAA0F1901060250347CAA454ED72F14C8
Aug-05 11:11:10 PM Insteon Sending http://192.168.1.123:25105/3?0262347CAA0F1901=I=3
Aug-05 11:11:10 PM Insteon Setting status and value for device 30.BF.2D:1. Old status:15 Old Value:15, New Status:4 New Value:15
Aug-05 11:11:10 PM Insteon Process ACK Message for device Kitchen Side (30.BF.2D)
Aug-05 11:11:10 PM Insteon StandardDeviceClass ProcessStatus called with Level:39
Aug-05 11:11:10 PM Insteon Received a Direct ACK from Kitchen Side (30.BF.2D): 30 BF 2D 45 4E D7 2F 07 27
Aug-05 11:11:10 PM Insteon Database delta value of 7 for device 30.BF.2D is current. No changes since last database update.
Aug-05 11:11:10 PM Insteon Database recently heard delta value for device 30.BF.2D is current.
Aug-05 11:11:10 PM Insteon Sending command 02 62 34 7C AA 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:10 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Aug-05 11:11:10 PM Insteon Received STX 0x50 (Raw Insteon Rec):30 BF 2D 45 4E D7 2F 07 27
Aug-05 11:11:10 PM Insteon ..Got Hub Response 02 62 30 BF 2D 0F 19 00 06
Aug-05 11:11:10 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:10 PM Insteon ..My XML buffer begins with: 026230BF2D0F190006025030BF2D454ED72F0727
Aug-05 11:11:09 PM Insteon Sending http://192.168.1.123:25105/3?026230BF2D0F1900=I=3
Aug-05 11:11:09 PM Insteon Attempting to get a KPL LED status response from Insteon device 34.7C.AA
Aug-05 11:11:09 PM Insteon Sending sync command to linked responder device: Master Bedroom Deck Keypad Button C: (34.7C.AA)
Aug-05 11:11:09 PM Insteon Checking for keypadlinc button sync on device 3D.87.61 src index 5, SrcIsSyncTarget=True...
Aug-05 11:11:09 PM Insteon Process ACK Message for device Family Room Keypad 1 (3D.87.61)
Aug-05 11:11:09 PM Insteon Setting status and value for device 3D.87.61:5. Old status:0 Old Value:0, New Status:3 New Value:0
Aug-05 11:11:09 PM Insteon Received a Direct ACK from Family Room Keypad 1 (3D.87.61): 3D 87 61 45 4E D7 2F 5E E4
Aug-05 11:11:09 PM Insteon Sending command 02 62 30 BF 2D 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:09 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E to locate next possible STX
Aug-05 11:11:09 PM Insteon Received STX 0x50 (Raw Insteon Rec):3D 87 61 45 4E D7 23 5E E4 Debouncing repeat.
Aug-05 11:11:09 PM Insteon ..Got Hub Response 02 62 3D 87 61 0F 19 01 06
Aug-05 11:11:09 PM Insteon Received STX 0x50 (Raw Insteon Rec):3D 87 61 45 4E D7 2F 5E E4
Aug-05 11:11:09 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:09 PM Insteon ..My XML buffer begins with: 02623D87610F19010602503D8761454ED72F5EE402503D8761454ED7235E E4
Aug-05 11:11:08 PM Insteon Attempting to update the status for Kitchen Side (30.BF.2D)
Aug-05 11:11:08 PM Insteon Requesting Insteon status (Polling) for device Kitchen Side (30.BF.2D)
Aug-05 11:11:08 PM Insteon Timed poll for Insteon device Kitchen Side (30.BF.2D), Last contact 8/5/2017 11:11:00 PM. Polling interval of 0 min. reached, polling...
Aug-05 11:11:08 PM Insteon Starting Scheduled Polling...
Aug-05 11:11:08 PM Insteon Sending http://192.168.1.123:25105/3?02623D87610F1901=I=3
Aug-05 11:11:08 PM Insteon Sending command 02 62 3D 87 61 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:08 PM Insteon Attempting to get a KPL LED status response from Insteon device 3D.87.61
Aug-05 11:11:08 PM Insteon Setting status and value for device 38.E4.87:1. Old status:0 Old Value:0, New Status:3 New Value:0
Aug-05 11:11:08 PM Insteon Sending sync command to linked responder device: Family Room Keypad 1 Button C: Outside LED - Button C (3D.87.61)
Aug-05 11:11:08 PM Insteon SyncResponderDevices called for device code: 38.E4.87:1
Aug-05 11:11:08 PM Insteon Process ACK Message for device Family Room Outside LED (38.E4.87)
Aug-05 11:11:08 PM Insteon Received a Direct ACK from Family Room Outside LED (38.E4.87): 38 E4 87 45 4E D7 2F 13 00
Aug-05 11:11:08 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Aug-05 11:11:08 PM Insteon ..Got Hub Response 02 62 38 E4 87 0F 13 00 06
Aug-05 11:11:08 PM Insteon Received STX 0x50 (Raw Insteon Rec):38 E4 87 45 4E D7 2F 13 00
Aug-05 11:11:08 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:08 PM Insteon ..My XML buffer begins with: 026238E4870F130006025038E487454ED72F13
Aug-05 11:11:07 PM Insteon Sending http://192.168.1.123:25105/3?026238E4870F1300=I=3
Aug-05 11:11:07 PM Insteon Setting status and value for device 38.E4.87:1. Old status:0 Old Value:0, New Status:3 New Value:0
Aug-05 11:11:07 PM Insteon Sending command 02 62 38 E4 87 0F 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:07 PM Insteon Process ACK Message for device Family Room Outside LED (38.E4.87)
Aug-05 11:11:07 PM Insteon Setting status and value for device 38.E4.87:1. Old status:100 Old Value:100, New Status:3 New Value:0
Aug-05 11:11:07 PM Insteon Received a Direct ACK from Family Room Outside LED (38.E4.87): 38 E4 87 45 4E D7 2F 13 00
Aug-05 11:11:07 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E to locate next possible STX
Aug-05 11:11:07 PM Insteon Received STX 0x50 (Raw Insteon Rec):38 E4 87 45 4E D7 23 13 00 Debouncing repeat.
Aug-05 11:11:07 PM Insteon ..Got Hub Response 02 62 38 E4 87 0F 13 00 06
Aug-05 11:11:07 PM Insteon Received STX 0x50 (Raw Insteon Rec):38 E4 87 45 4E D7 2F 13 00
Aug-05 11:11:07 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:07 PM Insteon ..My XML buffer begins with: 026238E4870F130006025038E487454ED72F1300025038E487454ED72313
Aug-05 11:11:06 PM Insteon Sending http://192.168.1.123:25105/3?026238E4870F1300=I=3
Aug-05 11:11:06 PM Insteon Process ACK Message for device Family Room Keypad 1 (3D.87.61)
Aug-05 11:11:06 PM Insteon Received a Direct ACK from Family Room Keypad 1 (3D.87.61): 3D 87 61 45 4E D7 2F 2E 00
Aug-05 11:11:06 PM Insteon Sending command 02 62 38 E4 87 0F 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:06 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A to locate next possible STX
Aug-05 11:11:06 PM Insteon Received STX 0x50 (Raw Insteon Rec):3D 87 61 45 4E D7 23 2E 00 Debouncing repeat.
Aug-05 11:11:06 PM Insteon ..Got Hub Response 02 62 3D 87 61 1F 2E 00 00 09 E4 00 00 00 00 00 00 00 00 00 00 E5 06
Aug-05 11:11:06 PM Insteon Received STX 0x50 (Raw Insteon Rec):3D 87 61 45 4E D7 2F 2E 00
Aug-05 11:11:06 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:06 PM Insteon ..My XML buffer begins with: 02623D87611F2E000009E400000000000000000000E50602503D8761454E D72F2E0002503D8761454ED7232E
Aug-05 11:11:05 PM Insteon Sending http://192.168.1.123:25105/3?02623D8...00000000E5=I=3
Aug-05 11:11:05 PM Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
Aug-05 11:11:05 PM Insteon Sending sync command to linked responder device: Family Room Outside LED (38.E4.87)
Aug-05 11:11:05 PM Insteon SyncResponderDevices called for device code: 3D.87.61:5
Aug-05 11:11:05 PM Insteon Sending command 02 62 3D 87 61 1F 2E 00 00 09 E4 00 00 00 00 00 00 00 00 00 00 E5 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:05 PM Insteon Checking for keypadlinc button sync on device 3D.87.61 src index 5, SrcIsSyncTarget=True...
Aug-05 11:11:05 PM Insteon Process ACK Message for device Family Room Keypad 1 (3D.87.61)
Aug-05 11:11:05 PM Insteon Setting status and value for device 3D.87.61:5. Old status:100 Old Value:100, New Status:3 New Value:0
Aug-05 11:11:05 PM Insteon Received a Direct ACK from Family Room Keypad 1 (3D.87.61): 3D 87 61 45 4E D7 2F 5E F4
Aug-05 11:11:05 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Aug-05 11:11:05 PM Insteon ..Got Hub Response 02 62 3D 87 61 0F 19 01 06
Aug-05 11:11:05 PM Insteon Received STX 0x50 (Raw Insteon Rec):3D 87 61 45 4E D7 2F 5E F4
Aug-05 11:11:05 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:05 PM Insteon ..My XML buffer begins with: 02623D87610F19010602503D8761454ED72F5EF4
Aug-05 11:11:04 PM Insteon Sending http://192.168.1.123:25105/3?02623D87610F1901=I=3
Aug-05 11:11:04 PM Insteon ..Retry #1 required. Pausing 250ms for Hub to clear...
Aug-05 11:11:04 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E to locate next possible STX
Aug-05 11:11:04 PM Insteon ..Got NAK from the Hub for command
Aug-05 11:11:04 PM Insteon Received STX 0x50 (Raw Insteon Rec):2D 47 43 13 01 01 CB 06 00
Aug-05 11:11:04 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:04 PM Insteon ..My XML buffer begins with: 1515151502502D4743130101CB06
Aug-05 11:11:03 PM Device Control Device: Family Room Outside LED to Off (0) by/from: CAPI Control Handler
Aug-05 11:11:03 PM Insteon Sending http://192.168.1.123:25105/3?02623D87610F1901=I=3
Aug-05 11:11:03 PM Insteon Sending command 02 62 3D 87 61 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:03 PM Insteon Attempting to get a KPL LED status response from Insteon device 3D.87.61
Aug-05 11:11:03 PM Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
Aug-05 11:11:03 PM Device Control Device: Family Room Outside LED - Button C to Off (0) by/from: CAPI Control Handler
Aug-05 11:11:02 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2C to locate next possible STX
Aug-05 11:11:02 PM Insteon Received STX 0x50 (Raw Insteon Rec):2D 47 43 13 01 01 CB 06 00
Aug-05 11:11:02 PM Insteon Received STX 0x50 (Raw Insteon Rec):2D 47 43 45 4E D7 46 13 01
Aug-05 11:11:02 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:02 PM Insteon ..My XML buffer begins with: 02502D4743454ED746130102502D4743130101CB06
Aug-05 11:11:02 PM Insteon Process ACK Message for device Kitchen Island (2B.CB.6F)
Aug-05 11:11:02 PM Insteon Received a Direct ACK from Kitchen Island (2B.CB.6F): 2B CB 6F 45 4E D7 2F 0B 59
Aug-05 11:11:02 PM Event Event Trigger "Automation Motion Outside Lights Off"
Aug-05 11:11:02 PM Insteon Setting status and value for device 2D.47.43:1. Old status:100 Old Value:100, New Status:3 New Value:0
Aug-05 11:11:02 PM Insteon ProcessGroupBroadcast: Device Garage Door Motion Sensor (2D.47.43) is group broadcast source (tgt group/button:1) sending cmd 13
Aug-05 11:11:02 PM Insteon Received 2D.47.43:1 (Garage Door Motion Sensor - Occupancy Sensor) Go OFF
Aug-05 11:11:02 PM Insteon Process ACK Message for device Kitchen Side (30.BF.2D)
Aug-05 11:11:02 PM Insteon Received a Direct ACK from Kitchen Side (30.BF.2D): 30 BF 2D 45 4E D7 2F 07 27
Aug-05 11:11:02 PM Insteon Setting NeedsPoll flag for Kitchen Island (2B.CB.6F) because a stop-ramp broadcast was detected.
Aug-05 11:11:02 PM Insteon Setting status and value for device 2B.CB.6F:1. Old status:35 Old Value:35, New Status:4 New Value:35
Aug-05 11:11:02 PM Insteon Setting status and value for device 2B.CB.6F:1. Old status:50 Old Value:50, New Status:4 New Value:35
Aug-05 11:11:01 PM Insteon StandardDeviceClass ProcessStatus called with Level:89
Aug-05 11:11:01 PM Insteon Database delta value of 11 for device 2B.CB.6F is current. No changes since last database update.
Aug-05 11:11:01 PM Insteon Database recently heard delta value for device 2B.CB.6F is current.
Aug-05 11:11:01 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E to locate next possible STX
Aug-05 11:11:01 PM Insteon Received STX 0x50 (Raw Insteon Rec):2B CB 6F 45 4E D7 23 0B 59 Debouncing repeat.
Aug-05 11:11:01 PM Insteon Received STX 0x50 (Raw Insteon Rec):2B CB 6F 45 4E D7 2F 0B 59
Aug-05 11:11:01 PM Insteon ..Got Hub Response 02 62 2B CB 6F 0F 19 00 06
Aug-05 11:11:01 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:01 PM Insteon ..My XML buffer begins with: 02622BCB6F0F19000602502BCB6F454ED72F0B5902502BCB6F454ED7230B 59
Aug-05 11:11:01 PM Insteon Sending http://192.168.1.123:25105/3?02622BCB6F0F1900=I=3
Aug-05 11:11:01 PM Insteon Sending command 02 62 2B CB 6F 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:01 PM Insteon Attempting to update the status for Kitchen Island (2B.CB.6F)
Aug-05 11:11:01 PM Insteon Requesting Insteon status (Polling) for device Kitchen Island (2B.CB.6F)
Aug-05 11:11:01 PM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:2B.CB.6F link record #10 target channel 1
Aug-05 11:11:01 PM Insteon Checking for keypadlinc button sync on device 34.62.0A src index 3, SrcIsSyncTarget=False...
Aug-05 11:11:01 PM Insteon Setting status and value for device 34.62.0A:3. Old status:100 Old Value:100, New Status:2 New Value:100
Aug-05 11:11:01 PM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:34.62.0A link record #20 target channel 3
Aug-05 11:11:01 PM Insteon Setting NeedsPoll flag for Kitchen Side (30.BF.2D) because a stop-ramp broadcast was detected.
Aug-05 11:11:01 PM Insteon Setting status and value for device 30.BF.2D:1. Old status:15 Old Value:15, New Status:4 New Value:15
Aug-05 11:11:01 PM Insteon ..Finished Scheduled Polling for 2 devices.
Aug-05 11:11:00 PM Insteon Setting status and value for device 30.BF.2D:1. Old status:80 Old Value:80, New Status:4 New Value:15
Aug-05 11:11:00 PM Insteon StandardDeviceClass ProcessStatus called with Level:39
Aug-05 11:11:00 PM Insteon Database delta value of 7 for device 30.BF.2D is current. No changes since last database update.
Aug-05 11:11:00 PM Insteon Database recently heard delta value for device 30.BF.2D is current.
Aug-05 11:11:00 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E to locate next possible STX
Aug-05 11:11:00 PM Insteon Received STX 0x50 (Raw Insteon Rec):2D 47 43 00 00 01 C7 13 01
Aug-05 11:11:00 PM Insteon Received STX 0x50 (Raw Insteon Rec):30 BF 2D 45 4E D7 2F 07 27
Aug-05 11:11:00 PM Insteon ..Got Hub Response 02 62 30 BF 2D 0F 19 00 06
Aug-05 11:11:00 PM Insteon Sending http://192.168.1.123:25105/1?XB=M=1
Aug-05 11:11:00 PM Insteon ..My XML buffer begins with: 026230BF2D0F190006025030BF2D454ED72F072702502D4743000001C713 01
Aug-05 11:11:00 PM Insteon Sending http://192.168.1.123:25105/3?026230BF2D0F1900=I=3
Aug-05 11:11:00 PM Insteon Sending command 02 62 30 BF 2D 0F 19 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Aug-05 11:11:00 PM Insteon Attempting to update the status for Kitchen Side (30.BF.2D)
Aug-05 11:11:00 PM Insteon Requesting Insteon status (Polling) for device Kitchen Side (30.BF.2D)
Aug-05 11:11:00 PM Insteon ProcessGroupBroadcast: Device Kitchen Side (30.BF.2D) is group broadcast source (tgt group/button:1) sending cmd 18
Aug-05 11:11:00 PM Insteon Received 30.BF.2D:1 (Kitchen Side) Stop Ramp
