Insteon Open/Close Sensor
This topic is closed.
    I bought a new Insteon Open/Close sensor. Insteon read it in without a problem and I was able to send e-mails upon open and close situations.
    However, I tried 12 times to add it as an Insteon device in my HomeSeer Sandler plugin and it kept balking and I could not add it.
    I'm sure I have the 6 character code correct.
    I tried rebooting both the Insteon Hub and the HomeSeer itself, but neither strategy made any difference.
    Any ideas on how to solve?
    Please enable detailed logging in the plugin. Then try to register it again. Then post the log snippet (copy and paste from HS log)
    I need to see how the plugin is responding
    Mark
    HS3 Pro 4.2.19.5
      Don't know how to copy/paste the log file
      I only have access through the HomeSeer system tools. I do not now how to 1) find the log file and 2) copy and paste it into a reply.
      If I had guidance on how to accomplish that I would be happy to spend the time.
        Mark
        you can copy what i need from the HS View/Log web screen. you don't need to access the hs log file from the file system.
        Mark
        HS3 Pro 4.2.19.5
          Log
          I'll try to copy that for you. Meanwhile, I had bought a second Door Sensor just in case and it is undergoing the identical error:
          The Insteon device at 37.05.F0 did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
          I'll send up the material you need shortly.
            from the View Log
            Feb-10 3:44:57 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
            Feb-10 3:43:49 PM Event Event Trigger "MK 1 Golden Globe Open"
            Feb-10 3:43:49 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
            Feb-10 3:43:24 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
            Feb-10 3:43:09 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go OFF
            Feb-10 3:42:44 PM Event Event Trigger "MK 1 Golden Globe Open"
            Feb-10 3:42:44 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
            Feb-10 3:42:28 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
            Feb-10 3:42:15 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go OFF
            Feb-10 3:42:05 PM Insteon The Insteon device at 37.05.F0 did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
            Feb-10 3:41:17 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
            Feb-10 3:40:16 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
            Feb-10 3:40:07 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go ON
            Feb-10 3:40:05 PM Event Event Trigger "MK 1 Banister Motion"
            Feb-10 3:40:05 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go ON
            Feb-10 3:40:05 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go ON
            Feb-10 3:40:03 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go ON
            Feb-10 3:39:21 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go OFF
            Feb-10 3:37:11 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go ON
            Feb-10 3:27:53 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go OFF
            Feb-10 3:25:13 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go ON
            Feb-10 3:16:27 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go OFF
            Feb-10 3:12:43 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go ON
            Feb-10 3:12:17 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go OFF
            Feb-10 3:10:49 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go OFF
            Feb-10 3:07:45 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go ON
            Feb-10 3:07:43 PM Event Event Trigger "MK 1 Banister Motion"
            Feb-10 3:07:43 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go ON
            Feb-10 3:07:33 PM Event Event Trigger "MK 1 Golden Globe Open"
            Feb-10 3:07:33 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
            Feb-10 3:06:31 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
              error message related to 1st door sensor
              Feb-09 3:45:22 PM Insteon The Insteon device at 36.E5.CC did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
                Please enable detailed logging in the plugin. Then try to register it again. Then post the log snippet (copy and paste from HS log) from when you started the registration process to when you get the above message
                Mark
                HS3 Pro 4.2.19.5
                  Registration and Detailed Log
                  I will do that.
                    detailed logging
                    I found the "detailed HS Logging" checkbox and am resetting the system to make sure it locks in.
                      Detailed Log
                      Feb-10 5:43:27 PM HSTouch Server Debug 05:43:27:5281 ~ Value change ref:367 Address:OMNI-Q13 NewVal: 0OldVal: 0
                      Feb-10 5:43:27 PM HSTouch Server Debug 05:43:27:2452 ~ Value change ref:366 Address:OMNI-Q12 NewVal: 2OldVal: 2
                      Feb-10 5:43:25 PM Event Event MK 1 Maids Door, Action of Control a Device could not be carried out because its configuration is not complete.
                      Feb-10 5:43:25 PM Event Event Trigger "MK 1 Maids Door"
                      Feb-10 5:43:25 PM HSTouch Server Debug 05:43:25:2347 ~ Value change ref:547 Address:22.6F.8B:1 NewVal: 100OldVal: 0
                      Feb-10 5:43:25 PM HSTouch Server Debug 05:43:25:2290 ~ Value change ref:474 Address:OMNI-Q88 NewVal: 100OldVal: 100
                      Feb-10 5:43:25 PM Event Event Trigger "MK 1 Golden Globe Open"
                      Feb-10 5:43:25 PM HSTouch Server Debug 05:43:25:1601 ~ Value change ref:318 Address:4A.67.63:1 NewVal: 100OldVal: 0
                      Feb-10 5:43:25 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
                      Feb-10 5:43:00 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
                      Feb-10 5:42:45 PM HSTouch Server Debug 05:42:45:4456 ~ Value change ref:475 Address:OMNI-Q89 NewVal: 100OldVal: 100
                      Feb-10 5:42:45 PM HSTouch Server Debug 05:42:45:2848 ~ Value change ref:171 Address:2E.D7.70:1 NewVal: 75OldVal: 0
                      Feb-10 5:42:45 PM Event Event Trigger "MK 1 Banister Motion"
                      Feb-10 5:42:45 PM HSTouch Server Debug 05:42:45:2173 ~ Value change ref:439 Address:45.FB.6E:1 NewVal: 100OldVal: 0
                      Feb-10 5:42:45 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go ON
                      Feb-10 5:42:40 PM HSTouch Server Debug 05:42:40:2286 ~ Value change ref:558 Address:OMNI-Q163 NewVal: 0OldVal: 0
                      Feb-10 5:42:40 PM HSTouch Server Debug 05:42:40:2224 ~ Value change ref:557 Address:OMNI-Q162 NewVal: 0OldVal: 0
                      Feb-10 5:42:33 PM HSTouch Server Debug 05:42:33:5544 ~ Value change ref:541 Address:OMNI-Q156 NewVal: 0OldVal: 0
                      Feb-10 5:42:33 PM HSTouch Server Debug 05:42:33:5453 ~ Value change ref:540 Address:OMNI-Q155 NewVal: 0OldVal: 0
                      Feb-10 5:42:29 PM Insteon Received Banister Banister Globe Occupancy Sensor: (45.FB.6E) Go OFF
                      Feb-10 5:42:22 PM Insteon The Insteon device at 36.E5.CC did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
                      Feb-10 5:41:53 PM Insteon Received Mhaha Vestibule Inst Occupancy Sensor: (4A.56.5C) Go OFF
                      Feb-10 5:41:29 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
                      Feb-10 5:40:54 PM OMNI Synchronizing OMNI devices with HomeSeer...
                      Feb-10 5:40:54 PM OMNI Requesting initial system troubles
                      Feb-10 5:40:53 PM HSTouch Server Debug 05:40:53:1537 ~ Value change ref:454 Address:4A.4B.51:21 NewVal: 162OldVal: 0
                      Feb-10 5:40:53 PM HSTouch Server Debug 05:40:53:1126 ~ Value change ref:448 Address:4A.4B.51:2 NewVal: 0OldVal: 100
                      Feb-10 5:40:53 PM Insteon Device Basement Bath White Globe (4A.4B.51) sent a dusk/dawn message.
                      Feb-10 5:40:47 PM OMNI Requesting Output status...
                      Feb-10 5:40:46 PM OMNI Requesting Area status...
                      Feb-10 5:40:46 PM OMNI All configuration and properties retrieved.
                      Feb-10 5:40:45 PM OMNI -->Reading properties...
                      Feb-10 5:40:17 PM Web Server Web Server authorized local login successful from: 10.0.1.7 User: admin
                      Feb-10 5:40:08 PM Startup Start up complete.
                      Feb-10 5:40:08 PM Info System connected to MyHS Service successfully with license ID 104995.
                      Feb-10 5:40:08 PM Info Latest BETA update available is: 3.0.0.409
                      Feb-10 5:40:08 PM Info Latest update available is: 3.0.0.368
                      Feb-10 5:40:08 PM Info System connected to MyHS Service, waiting for acknowledge...
                      Feb-10 5:40:08 PM TTS Speak ():Welcome to Home-Seer
                      Feb-10 5:40:08 PM Startup Scripting is OK and is now running Startup.vb
                      Feb-10 5:40:08 PM Info Checking for updates...
                      Feb-10 5:40:08 PM Startup HSSentry is disabled in Setup, sentry will not be started.
                      Feb-10 5:40:08 PM Startup Starting Event Scheduler...
                      Feb-10 5:40:07 PM HSTouch Server Debug 05:40:07:2027 ~ Value change ref:172 Address:2E.46.25:1 NewVal: 100OldVal: 0
                      Feb-10 5:40:07 PM HSTouch Server Debug 05:40:07:1470 ~ Value change ref:309 Address:37.B0.8F:1 NewVal: 100OldVal: 0
                      Feb-10 5:40:07 PM Insteon Received Yellow Bath Yellow Motion Occupancy Sensor: (37.B0.8F) Go ON
                      Feb-10 5:40:05 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
                      Feb-10 5:40:03 PM Insteon External Device Registration complete.
                      Feb-10 5:40:03 PM Startup Running the startup script Startup.vb
                      Feb-10 5:40:03 PM Startup Starting Find service...
                      Feb-10 5:40:03 PM Startup Updater services starting...
                      Feb-10 5:40:03 PM HSTouch Server Debug 05:40:03:2568 ~ Value change ref:318 Address:4A.67.63:1 NewVal: 0OldVal: 100
                      Feb-10 5:40:03 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
                      Feb-10 5:40:02 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd
                      Feb-10 5:40:02 PM Speech Listening for remote speaker connections on port 10401
                      Feb-10 5:40:02 PM Startup Initializing Speaker Client Interface
                      Feb-10 5:40:02 PM Startup Start automation engine...
                      Feb-10 5:40:02 PM Web Server Web Server started on port 80
                      Feb-10 5:40:02 PM Web Server Local IP address is: 10.0.1.102
                      Feb-10 5:40:02 PM Startup HStouch server started, waiting for clients to connect.
                      Feb-10 5:40:02 PM HSTouch Server Server started on port 10200
                      Feb-10 5:40:02 PM Plug-In Finished initializing plug-in MyQ
                      Feb-10 5:40:01 PM MyQ Initializing version 1.1.17344.311
                      Feb-10 5:40:00 PM Info Plugin MyQ has connected. IP:127.0.0.1:33299
                      Feb-10 5:39:59 PM Plug-In Finished initializing plug-in Insteon
                      Feb-10 5:39:59 PM Insteon Waiting to initialize External Devices...
                      Feb-10 5:39:53 PM OMNI -->Reading configuration...
                      Feb-10 5:39:53 PM Insteon Hub contacted on 10.0.1.22:25105 with an Insteon address of 30.1E.73 and firmware version A3
                      Feb-10 5:39:47 PM Insteon Insteon Support library (Insteon.dll) version: 1.0.6.28
                      Feb-10 5:39:46 PM Info Plugin Insteon has connected. IP:127.0.0.1:33256
                      Feb-10 5:39:45 PM Plug-In Finished initializing plug-in OMNI
                      Feb-10 5:39:43 PM Info Plugin OMNI has connected. IP:127.0.0.1:33254
                      Feb-10 5:39:42 PM Startup Initializing Plug-Ins
                        i don't think detailed logging is set properly. it should look like the following. Make sure to Save Settings
                        you should then see msgs like the following in the log
                        Feb-10 10:20:26 PM Insteon ..Got RF PLM Response 02 62 2A 56 C1 0F 19 00 06
                        Feb-10 10:20:26 PM Insteon Sending command 02 62 2A 56 C1 0F 19 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload
                        Mark
                        HS3 Pro 4.2.19.5
                          Better log detail after changed config
                          Feb-11 12:00:44 AM Insteon Received a Direct ACK from House White Linc Module (2E.49.A4): 2E 49 A4 30 1E 73 25 02 00
                          Feb-11 12:00:44 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                          Feb-11 12:00:43 AM Insteon Received STX 0x50 (Raw Insteon Rec):2E 49 A4 30 1E 73 25 02 00
                          Feb-11 12:00:43 AM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 2E 49 A4 05 19 00 06
                          Feb-11 12:00:43 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                          Feb-11 12:00:43 AM Insteon ..My XML buffer begins with: 02622E49A40519000602502E49A4301E732502
                          Feb-11 12:00:43 AM Insteon Received a Direct ACK from House Main (32.08.7A): 32 08 7A 30 1E 73 25 02 00
                          Feb-11 12:00:43 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                          Feb-11 12:00:42 AM Insteon Received STX 0x50 (Raw Insteon Rec):32 08 7A 30 1E 73 25 02 00
                          Feb-11 12:00:42 AM Insteon PLMBuffer_Clean - Cleared 37 B0 83 30 1E 73 23 19 00 to locate next possible STX
                          Feb-11 12:00:42 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                          Feb-11 12:00:42 AM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 37 B0 83 05 19 00 06
                          Feb-11 12:00:42 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                          Feb-11 12:00:42 AM Insteon ..My XML buffer begins with: 026237B08305190006025C37B083301E73231900026232087A0519000602 5032087A301E732502
                          Feb-11 12:00:39 AM Insteon PLMBuffer_Clean - Cleared 1E 73 23 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                          Feb-11 12:00:39 AM Insteon Received a Direct ACK from House Micro (2E.FE.2D): 2E FE 2D 30 1E 73 25 01 00
                          Feb-11 12:00:39 AM Insteon PLMBuffer_Clean - Cleared 27 to locate next possible STX
                          Feb-11 12:00:39 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                          Feb-11 12:00:39 AM Insteon Received STX 0x50 (Raw Insteon Rec):2E FE 2D 30 1E 73 25 01 00
                          Feb-11 12:00:39 AM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 2E FE 2D 05 19 00 06
                          Feb-11 12:00:39 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                          Feb-11 12:00:39 AM Insteon ..My XML buffer begins with: 02622EFE2D0519000602502EFE2D301E73250100026227B6670519000602 5C27B667301E732319
                          Feb-11 12:00:36 AM Insteon Received a Direct ACK from Mhaha Old Lamp Module (12.04.2A): 12 04 2A 30 1E 73 25 01 00
                          Feb-11 12:00:35 AM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 01 00
                          Feb-11 12:00:35 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                          Feb-11 12:00:35 AM Insteon Received STX 0x50 (Raw Insteon Rec):12 04 2A 30 1E 73 25 01 00
                          Feb-11 12:00:35 AM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 01 00
                          Feb-11 12:00:35 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            More log lines
                            Log 2/11/2018 12:02:26 AM Sunrise: 7:21 AM Sunset: 5:32 PM User: admin
                            HOME
                            VIEW
                            TOOLS
                            PLUG-INS
                            Filter
                            Auto Update
                            Refresh
                            Log settings
                            Date/Time Pri Type/Error Message/Source
                            Feb-11 12:02:20 AM Insteon PLMBuffer_Clean - Cleared 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 to locate next possible STX
                            Feb-11 12:02:20 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-11 12:02:20 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-11 12:02:19 AM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-11 12:02:19 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-11 12:02:19 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:19 AM Insteon ..My XML buffer begins with: 027F0006027F0206027F0006
                            Feb-11 12:02:18 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-11 12:02:18 AM Insteon Received a Direct ACK from House Yellow Link (2E.46.25): 2E 46 25 30 1E 73 21 01 00
                            Feb-11 12:02:18 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-11 12:02:17 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-11 12:02:17 AM Insteon Received STX 0x50 (Raw Insteon Rec):2E 46 25 30 1E 73 21 01 00
                            Feb-11 12:02:17 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:17 AM Insteon ..My XML buffer begins with: 02622E46250519000602502E4625301E73210100027F0206
                            Feb-11 12:02:16 AM Insteon Received a Direct ACK from House White Linc Module (2E.49.A4): 2E 49 A4 30 1E 73 25 02 00
                            Feb-11 12:02:15 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-11 12:02:15 AM Insteon Received STX 0x50 (Raw Insteon Rec):2E 49 A4 30 1E 73 25 02 00
                            Feb-11 12:02:15 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:15 AM Insteon ..My XML buffer begins with: 02622E49A40519000602502E49A4301E732502
                            Feb-11 12:02:14 AM Insteon Received a Direct ACK from House Main (32.08.7A): 32 08 7A 30 1E 73 25 02 00
                            Feb-11 12:02:14 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 to locate next possible STX
                            Feb-11 12:02:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):32 08 7A 30 1E 73 25 02 00
                            Feb-11 12:02:14 AM Insteon PLMBuffer_Clean - Cleared 37 B0 83 30 1E 73 23 19 00 to locate next possible STX
                            Feb-11 12:02:14 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-11 12:02:14 AM Insteon PLMBuffer_Clean - Cleared 1E 73 23 19 00 to locate next possible STX
                            Feb-11 12:02:14 AM Insteon Received a Direct ACK from House Micro (2E.FE.2D): 2E FE 2D 30 1E 73 25 01 00
                            Feb-11 12:02:14 AM Insteon PLMBuffer_Clean - Cleared 27 to locate next possible STX
                            Feb-11 12:02:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):2E FE 2D 30 1E 73 25 01 00
                            Feb-11 12:02:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 2E FE 2D 05 19 00 06
                            Feb-11 12:02:14 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:14 AM Insteon ..My XML buffer begins with: 02622EFE2D0519000602502EFE2D301E73250100026227B6670519000602 5C27B667301E73231900026237B0830519000602
                            Feb-11 12:02:08 AM Insteon Received a Direct ACK from Mhaha Old Lamp Module (12.04.2A): 12 04 2A 30 1E 73 25 01 00
                            Feb-11 12:02:08 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-11 12:02:07 AM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 01 00
                            Feb-11 12:02:07 AM Insteon Received STX 0x50 (Raw Insteon Rec):12 04 2A 30 1E 73 25 01 00
                            Feb-11 12:02:07 AM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 01 00
                            Feb-11 12:02:07 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:07 AM Insteon ..My XML buffer begins with: 026231FE4A05190006025031FE4A301E73250100026212042A0519000602 5012042A301E732501
                            Feb-11 12:02:06 AM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-11 12:02:06 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-11 12:02:06 AM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 2E D7 70 05 19 00 06
                            Feb-11 12:02:06 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:06 AM Insteon ..My XML buffer begins with: 02622ED77005190006025C2ED770301E732319
                            Feb-11 12:02:04 AM Insteon Received a Direct ACK from 37.57.3E: 37 57 3E 30 1E 73 25 05 00
                            Feb-11 12:02:04 AM Insteon Received a Direct ACK from House IO Linc (3B.97.AB): 3B 97 AB 30 1E 73 25 00 00
                            Feb-11 12:02:03 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-11 12:02:03 AM Insteon Received STX 0x50 (Raw Insteon Rec):37 57 3E 30 1E 73 25 05 00
                            Feb-11 12:02:03 AM Insteon Received STX 0x50 (Raw Insteon Rec):3B 97 AB 30 1E 73 25 00 00
                            Feb-11 12:02:03 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:02:03 AM Insteon ..My XML buffer begins with: 02623B97AB0519000602503B97AB301E73250000026237573E0519000602 5037573E301E732505
                            Feb-11 12:02:00 AM Insteon Setting status and value for device 22.6F.8B:1. Old status:100 Old Value:100, New Status:2 New Value:100
                            Feb-11 12:02:00 AM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:22.6F.8B link record #3 target channel 1
                            Feb-11 12:02:00 AM Insteon Setting status and value for device 4A.67.63:1. Old status:100 Old Value:100, New Status:2 New Value:100
                            Feb-11 12:02:00 AM Insteon ProcessGroupBroadcast: Device Mhaha Golden Globe (4A.67.63) is group broadcast source (tgt group/button:1) sending cmd 11
                            Feb-11 12:02:00 AM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-11 12:02:00 AM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
                            Feb-11 12:02:00 AM Insteon PLM_ProcessInBuffer received STX 0x58 (Group Cleanup Success)
                            Feb-11 12:02:00 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-11 12:02:00 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 11 01 01 CF 06 00 Debouncing repeat.
                            Feb-11 12:02:00 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 30 1E 73 40 11 01
                            Feb-11 12:02:00 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 00 00 01 CF 11 01
                            Feb-11 12:01:59 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:01:59 AM Insteon ..My XML buffer begins with: 02504A6763000001CF110102504A6763301E7340110102504A6763110101 CF060002504A6763110101CF06
                            Feb-11 12:01:58 AM Event Event Trigger "MK 1 Maids Door"
                            Feb-11 12:01:58 AM HSTouch Server Debug 12:01:58:1272 ~ Value change ref:547 Address:22.6F.8B:1 NewVal: 100OldVal: 0
                            Feb-11 12:01:58 AM Insteon Setting status and value for device 22.6F.8B:1. Old status:0 Old Value:0, New Status:2 New Value:100
                            Feb-11 12:01:58 AM HSTouch Server Debug 12:01:58:1042 ~ Value change ref:474 Address:OMNI-Q88 NewVal: 100OldVal: 100
                            Feb-11 12:01:58 AM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:22.6F.8B link record #3 target channel 1
                            Feb-11 12:01:58 AM HSTouch Server Debug 12:01:58:0783 ~ Value change ref:318 Address:4A.67.63:1 NewVal: 100OldVal: 0
                            Feb-11 12:01:58 AM Event Event Trigger "MK 1 Golden Globe Open"
                            Feb-11 12:01:58 AM Insteon Setting status and value for device 4A.67.63:1. Old status:0 Old Value:0, New Status:2 New Value:100
                            Feb-11 12:01:58 AM Insteon ProcessGroupBroadcast: Device Mhaha Golden Globe (4A.67.63) is group broadcast source (tgt group/button:1) sending cmd 11
                            Feb-11 12:01:58 AM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
                            Feb-11 12:01:58 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-11 12:01:57 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 00 00 01 C3 11 01
                            Feb-11 12:01:57 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:01:57 AM Insteon ..My XML buffer begins with: 02504A6763000001C31101
                            Feb-11 12:00:50 AM Insteon PLMBuffer_Clean - Cleared 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
                            Feb-11 12:00:49 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-11 12:00:49 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:49 AM Insteon ..My XML buffer begins with: 027F0006
                            Feb-11 12:00:48 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 to locate next possible STX
                            Feb-11 12:00:48 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-11 12:00:47 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-11 12:00:47 AM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-11 12:00:47 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:47 AM Insteon ..My XML buffer begins with: 027F0006027F0206
                            Feb-11 12:00:46 AM Insteon Received a Direct ACK from House Yellow Link (2E.46.25): 2E 46 25 30 1E 73 26 01 00
                            Feb-11 12:00:46 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2C to locate next possible STX
                            Feb-11 12:00:46 AM Insteon Received STX 0x50 (Raw Insteon Rec):2E 46 25 30 1E 73 26 01 00
                            Feb-11 12:00:46 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:46 AM Insteon ..My XML buffer begins with: 02622E46250519000602502E4625301E732601001515
                            Feb-11 12:00:35 AM Insteon ..My XML buffer begins with: 026231FE4A05190006025031FE4A301E73250100026212042A0519000602 5012042A301E732501
                            Feb-11 12:00:34 AM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-11 12:00:34 AM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-11 12:00:34 AM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 2E D7 70 05 19 00 06
                            Feb-11 12:00:34 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:34 AM Insteon ..My XML buffer begins with: 02622ED77005190006025C2ED770301E732319
                            Feb-11 12:00:32 AM Insteon Received a Direct ACK from 37.57.3E: 37 57 3E 30 1E 73 25 05 00
                            Feb-11 12:00:32 AM Insteon Received a Direct ACK from House IO Linc (3B.97.AB): 3B 97 AB 30 1E 73 25 00 00
                            Feb-11 12:00:32 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-11 12:00:31 AM Insteon Received STX 0x50 (Raw Insteon Rec):37 57 3E 30 1E 73 25 05 00
                            Feb-11 12:00:31 AM Insteon Received STX 0x50 (Raw Insteon Rec):3B 97 AB 30 1E 73 25 00 00
                            Feb-11 12:00:31 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:31 AM Insteon ..My XML buffer begins with: 02623B97AB0519000602503B97AB301E73250000026237573E0519000602 5037573E301E732505
                            Feb-11 12:00:28 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 42 to locate next possible STX
                            Feb-11 12:00:27 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 13 01 01 CF 06 00 Debouncing repeat.
                            Feb-11 12:00:27 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 30 1E 73 40 13 01
                            Feb-11 12:00:27 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:27 AM Insteon ..My XML buffer begins with: 02504A6763301E7340130102504A6763130101CF060002504A6763130101 CF06
                            Feb-11 12:00:26 AM HSTouch Server Debug 12:00:26:1688 ~ Value change ref:547 Address:22.6F.8B:1 NewVal: 0OldVal: 100
                            Feb-11 12:00:26 AM Insteon Setting status and value for device 22.6F.8B:1. Old status:100 Old Value:100, New Status:3 New Value:0
                            Feb-11 12:00:26 AM Insteon ProcessGroupBroadcastUpdateResponders: Located remote link record match for group broadcast - Device:22.6F.8B link record #3 target channel 1
                            Feb-11 12:00:26 AM HSTouch Server Debug 12:00:26:1222 ~ Value change ref:318 Address:4A.67.63:1 NewVal: 0OldVal: 100
                            Feb-11 12:00:26 AM Insteon Setting status and value for device 4A.67.63:1. Old status:100 Old Value:100, New Status:3 New Value:0
                            Feb-11 12:00:26 AM Insteon ProcessGroupBroadcast: Device Mhaha Golden Globe (4A.67.63) is group broadcast source (tgt group/button:1) sending cmd 13
                            Feb-11 12:00:26 AM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
                            Feb-11 12:00:26 AM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2C to locate next possible STX
                            Feb-11 12:00:26 AM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 00 00 01 CF 13 01 Debouncing repeat.
                            Feb-11 12:00:26 AM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-11 12:00:26 AM Insteon ..My XML buffer begins with: 02504A6763000001CF130102504A6763000001CF1301
                            Feb-10 11:59:48 PM Insteon Saved ini file. msecs=56
                            Feb-10 11:59:45 PM Insteon ..finished saving comm stats.
                            Feb-10 11:59:45 PM Insteon Saving comm stats...
                            Feb-10 11:59:36 PM Insteon BackgroundUpdate Thread Complete...
                            Feb-10 11:59:36 PM Insteon The Insteon device at 36.E5.CC did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
                            Feb-10 11:59:36 PM Insteon Scheduled polling resumed.
                            Feb-10 11:59:36 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 to locate next possible STX
                            Feb-10 11:59:35 PM Insteon ..Got Hub Response 02 6F 80 22 01 36 E5 CC 00 00 00 06
                            Feb-10 11:59:35 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:35 PM Insteon ..My XML buffer begins with: 026F80220136E5CC00000006
                            Feb-10 11:59:35 PM Insteon Sending http://10.0.1.22:25105/3?026F80220136E5CC000000=I=3
                            Feb-10 11:59:35 PM Insteon Sending command 02 6F 80 22 01 36 E5 CC 00 00 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
                            Feb-10 11:59:35 PM Insteon Calling PLM_RemoveID for 36.E5.CC 1 True
                            Feb-10 11:59:35 PM Insteon Did not get any device type broadcast for Insteon device 36.E5.CC
                            Feb-10 11:59:33 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:33 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:33 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:33 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:31 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:31 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:31 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:31 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:31 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:31 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:30 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:29 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:29 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:29 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:27 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:27 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:27 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:27 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:27 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:27 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:26 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:25 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:25 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:25 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:23 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:23 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:23 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:23 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:23 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:23 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:21 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:21 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:21 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:21 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:19 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:19 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:19 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:19 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:19 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:19 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:17 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:17 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:17 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:17 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:16 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:15 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:15 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:15 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:15 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:15 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:13 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:13 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:13 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:13 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:11 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:11 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:11 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:11 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:11 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:11 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:10 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:09 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:09 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:09 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:07 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:07 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:07 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:07 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:07 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:07 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:05 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:05 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:05 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:05 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:03 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:59:03 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:59:03 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:03 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:59:03 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:59:03 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:59:01 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:59:01 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:59:01 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:59:01 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:59:00 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:58:59 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:58:59 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:59 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:58:59 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:58:59 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:58:57 PM Insteon PLMBuffer_Clean - Cleared 36 E5 CC 30 1E 73 23 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 to locate next possible STX
                            Feb-10 11:58:57 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:57 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:57 PM Insteon ..My XML buffer begins with: 025C36E5CC301E73231
                            Feb-10 11:58:55 PM Insteon ..Got Hub Response 02 62 36 E5 CC 0F 10 00 06
                            Feb-10 11:58:55 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 to locate next possible STX
                            Feb-10 11:58:55 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:55 PM Insteon ..My XML buffer begins with: 026236E5CC0F100006
                            Feb-10 11:58:55 PM Insteon Sending http://10.0.1.22:25105/3?026236E5CC0F1000=I=3
                            Feb-10 11:58:54 PM Insteon Sending command 02 62 36 E5 CC 0F 10 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                            Feb-10 11:58:54 PM Insteon Sending Insteon ID Broadcast for '36.E5.CC'
                            Feb-10 11:58:53 PM Insteon ..Got Hub Response 02 6F 41 A2 01 36 E5 CC 00 00 00 15
                            Feb-10 11:58:53 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 to locate next possible STX
                            Feb-10 11:58:53 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:53 PM Insteon ..My XML buffer begins with: 026F41A20136E5CC00000015
                            Feb-10 11:58:52 PM Insteon Sending http://10.0.1.22:25105/3?026F41A20136E5CC000000=I=3
                            Feb-10 11:58:52 PM Insteon ..Retry #1 required. Pausing 250ms for Hub to clear...
                            Feb-10 11:58:52 PM Insteon ..Got junk instead of ACK/NAK for command 02 62 31 FE 4A 05 19 00 06
                            Feb-10 11:58:52 PM Insteon Sending command 02 6F 41 A2 01 36 E5 CC 00 00 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:True
                            Feb-10 11:58:52 PM Insteon Calling AddRecord for 36.E5.CC 1 True
                            Feb-10 11:58:52 PM Insteon Scheduled polling temporarily stopped.
                            Feb-10 11:58:52 PM Insteon Attempting to add Device 36.E5.CC
                            Feb-10 11:58:52 PM Insteon In BackgroundUpdate Thread...
                            Feb-10 11:58:52 PM Insteon Launching new BackgroundUpdate Thread with job type 20...
                            Feb-10 11:58:52 PM Insteon Set add job data : Name:Menards
                            Feb-10 11:58:52 PM Insteon Confirm Add Device Selected
                            Feb-10 11:58:52 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 to locate next possible STX
                            Feb-10 11:58:52 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:52 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:52 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:52 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:52 PM Insteon ..My XML buffer begins with: 027F0006027F0206
                            Feb-10 11:58:50 PM Insteon Received a Direct ACK from House Yellow Link (2E.46.25): 2E 46 25 30 1E 73 26 01 00
                            Feb-10 11:58:50 PM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-10 11:58:50 PM Insteon PLM_ProcessInBuffer received STX 0x54 (Button Event Report): 00
                            Feb-10 11:58:50 PM Insteon Received a Direct ACK from House White Linc Module (2E.49.A4): 2E 49 A4 30 1E 73 25 02 00
                            Feb-10 11:58:50 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:58:50 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E 46 25 30 1E 73 26 01 00
                            Feb-10 11:58:50 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E 49 A4 30 1E 73 25 02 00
                            Feb-10 11:58:50 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:50 PM Insteon ..My XML buffer begins with: 02622E49A40519000602502E49A4301E7325020002622E46250519000602 502E4625301E732601001515
                            Feb-10 11:58:47 PM Insteon Received a Direct ACK from House Main (32.08.7A): 32 08 7A 30 1E 73 25 02 00
                            Feb-10 11:58:47 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:47 PM Insteon Received STX 0x50 (Raw Insteon Rec):32 08 7A 30 1E 73 25 02 00
                            Feb-10 11:58:47 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:47 PM Insteon ..My XML buffer begins with: 026232087A05190006025032087A301E732502
                            Feb-10 11:58:46 PM Insteon PLMBuffer_Clean - Cleared 37 B0 83 30 1E 73 23 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:46 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:46 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:46 PM Insteon ..My XML buffer begins with: 026237B08305190006025C37B083301E732319
                            Feb-10 11:58:44 PM Insteon PLMBuffer_Clean - Cleared 1E 73 23 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:44 PM Insteon PLMBuffer_Clean - Cleared 27 to locate next possible STX
                            Feb-10 11:58:44 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:44 PM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 27 B6 67 05 19 00 06
                            Feb-10 11:58:44 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:44 PM Insteon ..My XML buffer begins with: 026227B66705190006025C27B667301E732319
                            Feb-10 11:58:42 PM Insteon Received a Direct ACK from House Micro (2E.FE.2D): 2E FE 2D 30 1E 73 25 01 00
                            Feb-10 11:58:42 PM Insteon Received a Direct ACK from Mhaha Old Lamp Module (12.04.2A): 12 04 2A 30 1E 73 25 01 00
                            Feb-10 11:58:41 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:58:41 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E FE 2D 30 1E 73 25 01 00
                            Feb-10 11:58:41 PM Insteon Received STX 0x50 (Raw Insteon Rec):12 04 2A 30 1E 73 25 01 00
                            Feb-10 11:58:41 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:41 PM Insteon ..My XML buffer begins with: 026212042A05190006025012042A301E7325010002622EFE2D0519000602 502EFE2D301E732501
                            Feb-10 11:58:39 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 01 00
                            Feb-10 11:58:39 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:39 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 01 00
                            Feb-10 11:58:39 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:39 PM Insteon ..My XML buffer begins with: 026231FE4A05190006025031FE4A301E732501
                            Feb-10 11:58:38 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:38 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:38 PM Insteon Received STX 0x50 (Raw Insteon Rec):02 62 2E D7 70 05 19 00 06
                            Feb-10 11:58:38 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:38 PM Insteon ..My XML buffer begins with: 02622ED77005190006025C2ED770301E732319
                            Feb-10 11:58:36 PM Insteon Received a Direct ACK from 37.57.3E: 37 57 3E 30 1E 73 25 05 00
                            Feb-10 11:58:36 PM Insteon Received a Direct ACK from House IO Linc (3B.97.AB): 3B 97 AB 30 1E 73 25 00 00
                            Feb-10 11:58:36 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:58:36 PM Insteon Received STX 0x50 (Raw Insteon Rec):37 57 3E 30 1E 73 25 05 00
                            Feb-10 11:58:36 PM Insteon Received STX 0x50 (Raw Insteon Rec):3B 97 AB 30 1E 73 25 00 00
                            Feb-10 11:58:36 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:36 PM Insteon ..My XML buffer begins with: 02623B97AB0519000602503B97AB301E73250000026237573E0519000602 5037573E301E732505
                            Feb-10 11:58:31 PM Insteon PLMBuffer_Clean - Cleared 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
                            Feb-10 11:58:31 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:31 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:31 PM Insteon ..My XML buffer begins with: 027F0006
                            Feb-10 11:58:30 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:30 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 88 to locate next possible STX
                            Feb-10 11:58:30 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:30 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:30 PM Insteon Received a Direct ACK from Mhaha Old Lamp Module (12.04.2A): 12 04 2A 30 1E 73 25 01 00
                            Feb-10 11:58:30 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:30 PM Insteon Received STX 0x50 (Raw Insteon Rec):12 04 2A 30 1E 73 25 01 00
                            Feb-10 11:58:30 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:30 PM Insteon Received a Direct ACK from House Micro (2E.FE.2D): 2E FE 2D 30 1E 73 25 19 00
                            Feb-10 11:58:30 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E FE 2D 30 1E 73 25 19 00
                            Feb-10 11:58:30 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:30 PM Insteon ..My XML buffer begins with: 02622EFE2D0519020602502EFE2D301E73251900027F0006026212042A05 190206025012042A301E73250100027F02060262
                            Feb-10 11:58:28 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:58:28 PM Insteon Received a Direct ACK from House Main (32.08.7A): 32 08 7A 30 1E 73 25 19 00
                            Feb-10 11:58:28 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:28 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:28 PM Insteon Received STX 0x50 (Raw Insteon Rec):32 08 7A 30 1E 73 25 19 00
                            Feb-10 11:58:28 PM Insteon Received a Direct ACK from House IO Linc (3B.97.AB): 3B 97 AB 30 1E 73 25 00 00
                            Feb-10 11:58:28 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:28 PM Insteon Received STX 0x50 (Raw Insteon Rec):3B 97 AB 30 1E 73 25 00 00
                            Feb-10 11:58:28 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:28 PM Insteon ..My XML buffer begins with: 02623B97AB0519010602503B97AB301E73250000027F0006026232087A05 190206025032087A301E73251900027F0206
                            Feb-10 11:58:26 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:58:26 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:58:26 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:58:26 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:26 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:26 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:26 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:26 PM Insteon ..My XML buffer begins with: 027F020602622ED77005190206025C2ED770301E73231902
                            Feb-10 11:58:23 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:58:23 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:58:23 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:58:23 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:23 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:23 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:23 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:23 PM Insteon ..My XML buffer begins with: 027F000602622ED77005190206025C2ED770301E73231902
                            Feb-10 11:58:21 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:58:21 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:58:21 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:58:21 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:21 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:21 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:21 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:21 PM Insteon ..My XML buffer begins with: 027F020602622ED77005190206025C2ED770301E73231902
                            Feb-10 11:58:18 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:18 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:18 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:18 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:18 PM Insteon ..My XML buffer begins with: 026231FE4A05190206025031FE4A301E732519
                            Feb-10 11:58:15 PM Insteon PLMBuffer_Clean - Cleared 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
                            Feb-10 11:58:15 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:15 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:15 PM Insteon ..My XML buffer begins with: 027F0006
                            Feb-10 11:58:14 PM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-10 11:58:14 PM Insteon Received a Direct ACK from House Yellow Link (2E.46.25): 2E 46 25 30 1E 73 21 01 00
                            Feb-10 11:58:14 PM Insteon PLM_ProcessInBuffer received STX 0x58 (Group Cleanup Success)
                            Feb-10 11:58:14 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:58:14 PM Insteon Received a Direct ACK from House White Linc Module (2E.49.A4): 2E 49 A4 30 1E 73 25 02 00
                            Feb-10 11:58:14 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E 46 25 30 1E 73 21 01 00
                            Feb-10 11:58:14 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E 49 A4 30 1E 73 25 02 00
                            Feb-10 11:58:14 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:14 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:14 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:14 PM Insteon ..My XML buffer begins with: 027F000602622E49A40519020602502E49A4301E7325020002622E462505 19020602502E4625301E732101
                            Feb-10 11:58:12 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
                            Feb-10 11:58:12 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:12 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:12 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:12 PM Insteon ..My XML buffer begins with: 027F0206
                            Feb-10 11:58:11 PM Insteon Received a Direct ACK from House Outdoor (27.E0.DB): 27 E0 DB 30 1E 73 26 19 FF
                            Feb-10 11:58:11 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8A to locate next possible STX
                            Feb-10 11:58:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 E0 DB 30 1E 73 26 19 FF
                            Feb-10 11:58:11 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:11 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:11 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:11 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:11 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:58:11 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:11 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:11 PM Insteon ..My XML buffer begins with: 02622ED77005190206025C2ED770301E73231902027F0006026231FE4A05 190206025031FE4A301E7325190015027F000602
                            Feb-10 11:58:07 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:58:07 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:58:07 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:58:07 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:07 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:07 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:07 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:07 PM Insteon ..My XML buffer begins with: 027F020602622ED77005190206025C2ED770301E73231902
                            Feb-10 11:58:03 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:03 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 to locate next possible STX
                            Feb-10 11:58:03 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:58:03 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:58:03 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:03 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:03 PM Insteon ..My XML buffer begins with: 027F0206026231FE4A05190206025031FE4A301E7325190015
                            Feb-10 11:58:02 PM Insteon Received a Direct ACK from House Outdoor (27.E0.DB): 27 E0 DB 30 1E 73 2B 19 FF
                            Feb-10 11:58:02 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:58:02 PM Insteon Received STX 0x50 (Raw Insteon Rec):27 E0 DB 30 1E 73 2B 19 FF
                            Feb-10 11:58:02 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:58:02 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:58:02 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:02 PM Insteon ..My XML buffer begins with: 027F0006026227E0DB05190206025027E0DB301E732B19FF
                            Feb-10 11:58:00 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
                            Feb-10 11:58:00 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:58:00 PM Insteon PLMBuffer_Clean - Cleared 27 E0 DB 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:58:00 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:58:00 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:58:00 PM Insteon ..My XML buffer begins with: 026227E0DB05190206025C27E0DB301E73231902
                            Feb-10 11:57:58 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
                            Feb-10 11:57:58 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:58 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:58 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:58 PM Insteon ..My XML buffer begins with: 027F0206
                            Feb-10 11:57:57 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:57:57 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:57:57 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:57:57 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:57:57 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:57 PM Insteon Received a Direct ACK from 02.7F.00: 02 7F 00 06 02 62 2E D7 70
                            Feb-10 11:57:57 PM Insteon PLMBuffer_Clean - Cleared 05 19 to locate next possible STX
                            Feb-10 11:57:57 PM Insteon Received STX 0x50 (Raw Insteon Rec):02 7F 00 06 02 62 2E D7 70
                            Feb-10 11:57:57 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:57 PM Insteon ..My XML buffer begins with: 027F000602622ED77005190206025C2ED770301E73231902
                            Feb-10 11:57:55 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:57:55 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:57:55 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:54 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:57:54 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:57:54 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:54 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:54 PM Insteon ..My XML buffer begins with: 026231FE4A05190206025031FE4A301E7325190002622ED7700519020602 5C2ED770301E73231902
                            Feb-10 11:57:51 PM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-10 11:57:51 PM Insteon PLM_ProcessInBuffer received STX 0x58 (Group Cleanup Success)
                            Feb-10 11:57:51 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:57:51 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:57:51 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:57:51 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:57:51 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:51 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:51 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:51 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:51 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:51 PM Insteon ..My XML buffer begins with: 026231FE4A05190206025031FE4A301E73251900027F020602622ED77005 190206025C2ED770301E73231902
                            Feb-10 11:57:45 PM Insteon PLMBuffer_Clean - Cleared 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 to locate next possible STX
                            Feb-10 11:57:45 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:45 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:45 PM Insteon ..My XML buffer begins with: 027F0006
                            Feb-10 11:57:45 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 6C
                            Feb-10 11:57:45 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:57:45 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:45 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 11 01 01 CF 06 00 Debouncing repeat.
                            Feb-10 11:57:45 PM Insteon Received a Direct ACK from Mhaha Old Lamp Module (12.04.2A): 12 04 2A 30 1E 73 2A 01 00
                            Feb-10 11:57:45 PM Insteon PLMBuffer_Clean - Cleared 30 1E 73 40 11 01 to locate next possible STX
                            Feb-10 11:57:45 PM Insteon Received a Direct ACK from House Micro (2E.FE.2D): 2E FE 2D 30 1E 73 25 19 00
                            Feb-10 11:57:45 PM Insteon Received STX 0x50 (Raw Insteon Rec):12 04 2A 30 1E 73 2A 01 00
                            Feb-10 11:57:45 PM Insteon Received STX 0x50 (Raw Insteon Rec):2E FE 2D 30 1E 73 25 19 00
                            Feb-10 11:57:45 PM Insteon PLMBuffer_Clean - Cleared 50 32 08 7A 30 1E 73 25 19 00 to locate next possible STX
                            Feb-10 11:57:45 PM Insteon ..My XML buffer begins with: 5032087A301E73251900027F020602622EFE2D0519020602502EFE2D301E 73251900026212042A05190206025012042A301E
                            Feb-10 11:57:36 PM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-10 11:57:36 PM Insteon PLM_ProcessInBuffer received STX 0x54 (Button Event Report): 00
                            Feb-10 11:57:35 PM Insteon Received a Direct ACK from House IO Linc (3B.97.AB): 3B 97 AB 30 1E 73 2A 00 00
                            Feb-10 11:57:35 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:57:35 PM Insteon Received STX 0x50 (Raw Insteon Rec):4A 67 63 30 1E 73 41 13 01
                            Feb-10 11:57:35 PM Insteon Received STX 0x50 (Raw Insteon Rec):3B 97 AB 30 1E 73 2A 00 00
                            Feb-10 11:57:35 PM Insteon PLMBuffer_Clean - Cleared 01 CF 13 01 to locate next possible STX
                            Feb-10 11:57:35 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:35 PM Insteon ..My XML buffer begins with: 02504A6763000001CF130102623B97AB0519010602503B97AB301E732A00 0002504A6763301E73411301
                            Feb-10 11:57:34 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:57:34 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:34 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:34 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:57:34 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:57:34 PM Insteon PLMBuffer_Clean - Cleared 00 06 to locate next possible STX
                            Feb-10 11:57:34 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:34 PM Insteon ..My XML buffer begins with: 02622ED77005190206025C2ED770301E73231902027F000602622ED77005 190206025C2ED770301E73231902027F0206
                            Feb-10 11:57:30 PM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-10 11:57:30 PM Insteon PLM_ProcessInBuffer received STX 0x58 (Group Cleanup Success)
                            Feb-10 11:57:30 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:57:30 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 00
                            Feb-10 11:57:30 PM Insteon PLMBuffer_Clean - Cleared 2E D7 70 30 1E 73 23 19 to locate next possible STX
                            Feb-10 11:57:30 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 5C
                            Feb-10 11:57:30 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:30 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:30 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:30 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:30 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:30 PM Insteon ..My XML buffer begins with: 026231FE4A05190206025031FE4A301E73251900027F020602622ED77005 190206025C2ED770301E73231902
                            Feb-10 11:57:23 PM Insteon Received a Direct ACK from Mhaha Old Lamp Module (12.04.2A): 12 04 2A 30 1E 73 25 01 00
                            Feb-10 11:57:23 PM Insteon PLMBuffer_Clean - Cleared 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 to locate next possible STX
                            Feb-10 11:57:23 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:23 PM Insteon Received STX 0x50 (Raw Insteon Rec):12 04 2A 30 1E 73 25 01 00
                            Feb-10 11:57:23 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:23 PM Insteon ..My XML buffer begins with: 026212042A05190206025012042A301E73250100027F0006
                            Feb-10 11:57:22 PM Insteon WARNING: Attempt to unbuffer more data than available in [PLMBuffer_Consume]. We had 2 and tried to consume 3.
                            Feb-10 11:57:22 PM Insteon PLM_ProcessInBuffer received STX 0x58 (Group Cleanup Success)
                            Feb-10 11:57:22 PM Insteon Received a Direct ACK from House Main (32.08.7A): 32 08 7A 30 1E 73 25 19 00
                            Feb-10 11:57:22 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 to locate next possible STX
                            Feb-10 11:57:22 PM Insteon Received STX 0x50 (Raw Insteon Rec):32 08 7A 30 1E 73 25 19 00
                            Feb-10 11:57:22 PM Insteon Received a Direct ACK from Blue Bath Blue Module (31.FE.4A): 31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:22 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 06
                            Feb-10 11:57:22 PM Insteon PLM_ProcessInBuffer - Unknown command followed STX, Discarding 02 7F
                            Feb-10 11:57:22 PM Insteon Received STX 0x50 (Raw Insteon Rec):31 FE 4A 30 1E 73 25 19 00
                            Feb-10 11:57:22 PM Insteon Sending http://10.0.1.22:25105/1?XB=M=1
                            Feb-10 11:57:22 PM Insteon ..My XML buffer begins with: 026231FE4A05190206025031FE4A301E73251900027F0206026232087A05 190206025032087A301E732519
                            Feb-10 11:57:00 PM Insteon Manual Add Selected
                            Feb-10 11:56:53 PM Insteon Saved ini file. msecs=56
                            Feb-10 11:56:49 PM Insteon Saved ini file. msecs=65
                            Feb-10 11:56:12 PM HSTouch Server Debug 11:56:12:1119 ~ Value change ref:547 Address:22.6F.8B:1 NewVal: 100OldVal: 0
                            Feb-10 11:56:12 PM Event Event Trigger "MK 1 Maids Door"
                            Feb-10 11:56:12 PM HSTouch Server Debug 11:56:12:0688 ~ Value change ref:474 Address:OMNI-Q88 NewVal: 100OldVal: 100
                            Feb-10 11:56:12 PM HSTouch Server Debug 11:56:12:0430 ~ Value change ref:318 Address:4A.67.63:1 NewVal: 100OldVal: 0
                            Feb-10 11:56:12 PM Event Event Trigger "MK 1 Golden Globe Open"
                            Feb-10 11:56:11 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go ON
                            Feb-10 11:55:32 PM Insteon Received Mhaha Golden Globe Occupancy Sensor: (4A.67.63) Go OFF
                            Feb-10 11:55:24 PM HSTouch Server Debug 11:55:24:0702 ~ Value change ref:172 Address:2E.46.25:1 NewVal: 0OldVal: 100
                              36 E5 CC
                              36 E5 CC is the 6 character Insteon code for the first of the two Open/Close sensors that I have tried to configure into HomeSeer. They both read into Insteon's app without a problem and both are able to be the controller for othr units.
