Jun 19 Insteon HUB update 1016 will break the plugin
This topic is closed.
    Has anyone else noticed any issues with the recent HUB update?
    My HS is unable to connect. But HUB is working fine standalone with app.
    Been troubleshooting for hours. Getting "403 Forbidden: SSL Required - use HTTPS" when I open a browser to IP:25105 of the hub. Before update I used to get a login.
    Looks like they updated this to require HTTPS for the API connection. Mark, any chance we can get an update on the plugin or a way to enable HTTPS to the control hub?
      I have the same issue, plug-in gives errors during start-up. Log attached.
        i will take a look
        Mark
        HS3 Pro 4.2.17.0
        Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
          Thank you very much Mark. I hate automatic updates in almost everything. Now I have a light I can not turn off without getting a ladder... Should have thought of that I guess. Oh well.
            please try 3.0.6.39 from the beta section of the Updater.
            you will need to shutdown the plugin and add the following to your insteon.ini
            [Hub]
            HttpProtocol=https
            Mark
            HS3 Pro 4.2.17.0
              [Hub]
              HttpProtocol=https
              tried that, still not connecting. restarted. no go
                beta section of updater
                I have experienced same issue. Thanks for quick reply.
                I have not used the beta section of the updater before. Where do I find it?
                  my hub was offline so i didn't get the update;yet.
                  can you check the url via a browser?
                  https://x.x.x.x:25105
                  replace x.x.x.x with your hub's ip
                  you should get a login prompt
                  Mark
                  HS3 Pro 4.2.17.0
                    the updater is at the bottom of the Manage Plugin page
                    Mark
                    HS3 Pro 4.2.17.0
                      thanks for the updates Mark.
                      I need to find a way to shut off the automatic updates! I added the extra Hub https section to the ini. I assume the ini is the one in the config directory? Still not working:
                      Insteon Plug-in Error Log Generated 6/20/2018 07:13:26
                      -----------*Error Message*----------------
                      Error: Forced error / log generation -- 6/20/2018 07:13:26
                      --------*Initialization Log*--------------
                      6/20/2018 07:13:03 - Host System: 10.215.81.4 (House) 3.0.0.435
                      6/20/2018 07:13:03 - Plugin HSPI_Insteon.exe version: 3.0.6.39
                      6/20/2018 07:13:03 - Insteon Support library (Insteon.dll) version: 1.0.6.39
                      6/20/2018 07:13:03 - RegisterCallback Completed
                      6/20/2018 07:13:03 - Enter InitIO
                      6/20/2018 07:13:03 - Enter InitPlugin
                      6/20/2018 07:13:03 - Global initialization of plug-in required, starting up.
                      6/20/2018 07:13:03 - Initializing Insteon hardware interface...
                      6/20/2018 07:13:03 - In ProcessRawReceiveThread
                      6/20/2018 07:13:03 - Initializing Interface...
                      6/20/2018 07:13:03 - In PLMBuffer_ProcessBufferThread
                      6/20/2018 07:13:03 - Sending https://10.215.81.130:25105/1?XB=M=1
                      6/20/2018 07:13:03 - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                      6/20/2018 07:13:04 - Sending https://10.215.81.130:25105/3?0260=I=3
                      6/20/2018 07:13:05 - The underlying connection was closed: An unexpected error occurred on a send.
                      6/20/2018 07:13:07 - ..did not receive a response from the Interface
                      6/20/2018 07:13:07 - ..Retry #1 required. Pausing 250ms for Interface to clear...
                      6/20/2018 07:13:07 - Sending https://10.215.81.130:25105/3?0260=I=3
                      6/20/2018 07:13:07 - The underlying connection was closed: An unexpected error occurred on a send.
                      6/20/2018 07:13:09 - The underlying connection was closed: An unexpected error occurred on a send.
                      6/20/2018 07:13:10 - ..did not receive a response from the Interface
                      6/20/2018 07:13:10 - ..Retry #2 required. Pausing 300ms for Interface to clear...
                      6/20/2018 07:13:10 - Sending https://10.215.81.130:25105/3?0260=I=3
                      6/20/2018 07:13:11 - The underlying connection was closed: An unexpected error occurred on a send.
                      6/20/2018 07:13:13 - The underlying connection was closed: An unexpected error occurred on a send.
                      6/20/2018 07:13:13 - ..did not receive a response from the Interface
                      6/20/2018 07:13:13 - Insteon hardware interface initialization failed.
                      6/20/2018 07:13:13 - Exit InitIO
                        please see post #9 above and try it and report back
                        i wonder if the port number changed
                        if so we need to figure that out and change in the plugin config page
                        Mark
                        HS3 Pro 4.2.17.0
                          so with https cannot connect.
                          http shows:
                          adding https://IP:25105
                          on safari:
                          safari cannot open page
                          on mozilla:
                          An error occurred during a connection to 192.168.1.11:25105. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
                          on chrome:
                          192.168.1.11 sent an invalid response.
                          ERR_SSL_PROTOCOL_ERROR
                            Tried in Chrome from a Mac
                            Got this:
                              port number is same as before. i used the ios app to check the ip/settings, ect and you can set the port number there. it was still same
