Jun 19 Insteon HUB update 1016 will break the plugin
This topic is closed.
    I am back on line. thanks
      I am still NOT ONLINE
        I checked last night after sending the email and I was flashed back to 1015 (June 20th), but then it must have somehow reverted back to 1016 (June 8th) shortly afterwards. I've sent another email and still waiting....
          can you give me your hub insteon id, and i will check
          Mark
          HS3 Pro 4.2.17.0
          Platform: Windows Server 2022 Essentials, i5-12600K/3.7GHz/10 core, 16GB RAM, 500GB SSD
            45.5C.6A
              where do I find the hub id
                its on the bottom of the hub. you need to include this in the email mentioned in post #146 above to get the fix
                Mark
                HS3 Pro 4.2.17.0
                  HUB ID IS
                  3C BF 62
                  Dont know why I didnt think to look on the box!
                    HUB ID IS
                    3C BF 62
                    have you already sent an email per post #146
                    Mark
                    HS3 Pro 4.2.17.0
                      problem is no one has replied from Insteon.
                        i will submit the id to my POC. i just needed to make sure you sent an original email
                        Mark
                        HS3 Pro 4.2.17.0
                          Thank you Mark!
                            FYI.... I just got a phone call from Insteon (thanks) informing me that once rolled back to 1015 the nightly check should not update to 1016 for anyone on the email list. I'm guessing we're filtered out of those automatic updates on their end (?). However, if you perform a force update or "check for update" via the Insteon App, it will override that filter and update you to 1016 (which is what happened to me after the initial downgrade last night).
                            I'm now back to 1015 and working again. Thanks Mark and others who posted!
                              Hi Mark,
                              I have sent the email no updates until now. I have 3 hubs, here are the IDs:
                              45:52:C5
                              49:ED:B4
                              49:EA:67
                              Thanks!
                                Originally posted by papapitufo View Post
                                Hi Mark,
                                45:52:C5
                                49:ED:B4
                                49:EA:67
                                Thanks!
                                i submitted this to my POC
                                Mark
                                HS3 Pro 4.2.17.0
